Old 01-05-2011, 01:22 PM   #11 (permalink)
Okay there is nothing new about his idea....
Same problem exists too. Turbos spin at 100,000+ rpm. Alternators spin at 6000 rpm max.
There is a company that is marketing a design and the only way they are getting around the problems is a custom alternator driven by a rather large turbine.
Couldn't it just be geared down?
Old 01-05-2011, 01:25 PM   #12 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
You can buy geared down turbos meant to be used as 'superchargers', as well.
Old 01-05-2011, 03:18 PM   #13 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
It could but you will loose efficiency
Old 01-05-2011, 04:27 PM   #14 (permalink)
Gears that withstand 100,000 rpms are not garden variety.
Old 01-05-2011, 05:29 PM   #15 (permalink)
Zerohour's Avatar
Pooparu - '01 Subaru Outback Limited
90 day: 28.12 mpg (US)
Cop Car - '94 Chevy Caprice Interceptor 9C1
Last 3: 18.48 mpg (US)
Mini - '11 Mini Cooper
90 day: 37.63 mpg (US)
Gramps - '95 Subaru Legacy Postal
90 day: 23.18 mpg (US)
I knew there was a reason I hesitated on posting this up. I know there are alot of nay-sayers about such an idea. But there are 50+ other variables that go into the rate of rotation...
...So does anyone know of any posts/documents about a completed unit? or semi-feasible prototype?
Old 01-05-2011, 05:43 PM   #16 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
No offense but why does an electric producing body have to be an alternator?
An antique solid state magneto like device could make current at very hi RPM and be built into the shaft, no brushes = better
The Following User Says Thank You to rmay635703 For This Useful Post:
Zerohour (01-05-2011)
Old 01-05-2011, 06:33 PM   #17 (permalink)
NHRABill's Avatar
Tahoe - '95 Chevrolet Tahoe LT
90 day: 13.22 mpg (US)
SRX - '04 Cadillac SRX AWD
XL - '05 Harley Davidson Sportster XL
90 day: 49.97 mpg (US)
Alero - '02 Oldsmobile Alero GLS
Corvette - '75 Chevrolet Corvette Stingray
No need to gear them down when the small engine boost is reduced by using multiple alternators in a serpintine setup the gasses won't create much boost to begin with and will be lessesned by the load an excess can be dealt with via traditional means Blow off valve tube.
you also have to look at the type of turbo being used you can get a sealed unit where it will have more drag due to its internal oiling system as compared to a f low through like in older car models.
1,000 different ways and no one has actually done it yet and talked about it at least ...
Good topic for discussion my 1st comment is because I thought that it needs to be tied that is why I try and not draw too much attention to it untill I did it myself and then let the criticism come out.
2012 Chevrolet Traverse *active*
2002 Oldsmobile Alero GLS *active*
2002 S10 2wd p/u 139,000mi. *active*
1975 Corvette Stingray *active*
1994 Camaro Z28 Convertible 149k *Sold 2013*
1998 Blazer ZR2 189k *Sold 2012*
1995 Tahoe LT 250k *Sold 2011*
The Following User Says Thank You to NHRABill For This Useful Post:
Old 01-05-2011, 07:59 PM   #18 (permalink)
IamIan's Avatar
I know this one from a company founded in 1966 ... been building Turbo-Alternators sense 1980.
Barber-Nichols: Engineering, Manufacturing, & Testing Climatics Test Chamber Blowers
The Following User Says Thank You to IamIan For This Useful Post:
Old 01-14-2011, 01:18 AM   #19 (permalink)
the green machine :P - '97 Jeep Grand Cherokee ZJ
90 day: 20.92 mpg (US)
Thee s10 - '00 Chevy S10
90 day: 24.27 mpg (US)
Freedom - '05 Kawasaki Ninja 250EX
90 day: 75.55 mpg (US)
just put like a 1 inch gear on the turbo and a 6 inch gear on the alternater it's about a 36 to 1 gearing i think, if i did the math right so then thats about 2777 rpm on the alternater and at that gearing it should have quit a bit of torque, don't you think??? and you only need to have about a 16 to 1 gear reduction if the turbo hits 100000 rpm and make sure it doesn't take to much power from the engine from to much back pressure(at 36 to 1 gearing you could have it to where 4 pounds of exhaust pressure equals 144 pounds of torque on the alternater then a gain i could be wrong??? anyone???)
Old 01-14-2011, 01:31 AM   #20 (permalink)
Yep, you could be wrong.
