Old 04-04-2009, 11:26 PM   #21 (permalink)
Lurking footless halls
Silveredwings's Avatar
Dark Horse - '16 Ford Mustang GT convertible Premium
Gutless Beauty - '19 Toyota Corolla SE
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
Old 04-05-2009, 08:56 AM   #22 (permalink)
93 Metro Streamliner
AeroMetro - '93 Geo Metro
Originally Posted by basjoos View Post
Right now I'm thinking about some sort of 2" diameter flexible duct running through the engine bay from the grill inlet to the vent air inlet plenum. That would be taking air from the one high pressure region remaining in my car's aerodynamics and any water sucked in would be dumped into the inlet plenum that is already designed to separate water from the incoming.air flow. There would be a slight drag increase, but it should be very minimal.
Sounds like the best idea to me, but I'd use 3".
Old 04-05-2009, 10:29 AM   #23 (permalink)
Use a computer-type fan. It would use very little power.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 04-05-2009, 04:15 PM   #24 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
What is the proper name for a "valve" that would allow an air inlet to be turned on or off?
I am thinking of adding a naca duct with some type of valve that will close off entry of both water and air, and maybe design in some kind of water separation chamber. I have not had much luck with google trying to find examples.
air valve?
Here is an example of a water separation chamber, known in boating as a Dorade:
Nissan Versa Aeromods
Old 04-05-2009, 04:54 PM   #25 (permalink)
All that is already designed into the factory intake.
Old 04-05-2009, 06:09 PM   #26 (permalink)
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
Cool
Already recommended too. I checked my intake yesterday and the piping from my lower intake runs up to the airbox and a separate house runs into the exhaust. There is a simple one way limiting valve in the exhaust connector it's just wider on one side and smaller side to limit backflow. I know I have water leaking in my engine but it's not coming from my intake.
-Allch Chcar
Old 04-06-2009, 11:46 AM   #27 (permalink)
ALS
I installed a SNOW cover on my cowl intake and it dropped my air flow by at least 75%. Even though it looks like an air scoop it lies below the boundary layer thus no ram effect. Plus with the top completely covering the cowl intake the high pressure area at the base of the windshield is totally useless.
Old 04-06-2009, 11:56 AM   #28 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
i suppose it would work better if teh scoop was on the other way round
Old 04-06-2009, 01:21 PM   #29 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
The one on my Jeep is turned around with the opening facing the windshield. Works wonders.
When it's turned around it works just like a cowl induction hood.
Old 04-06-2009, 04:41 PM   #30 (permalink)
Wok Master
Die Grau Geist - '95 Jeep Cherokee Sport
90 day: 17.74 mpg (US)
Send a message via AIM to Scheißeglück
Cowl style air induction vent cover
I've been meaning to invest in an after market cover for the air induction vent on my Jeep for awhile now. Most owners of Jeeps in my area (and there are a ton of them) always face them with the cowl opening facing the away from the windshield, because they mostly drive at slower speeds, being city driving or off road. At slower speeds the air moves into the cowl by the movement forward, but at higher speeds the air will "dam" up the opening, just causing air to not enter the cowl as freely. For higher speeds, with a taller cowl cover facing the windshield, this is going to keep the air from damming the opening, and because the taller cowl is going to create turbulence, much like that of air passing over a car with a wide, blocky rear end. The air is going to want to do the same when it passes over the cowl, thus more willingly enter the air vent.
This is an after market one from Bushwacker for a YJ series Jeep Wrangler, but you get the general idea. These are super easy to make as well if you have a plan and know what to get from the hardware store.
Overall, I'de say depending on what driving you do most, depends on which way you want that opening of the cowl to face.
Side mirror drag & effect on fuel economy - quantified MetroMPG Aerodynamics 179 11-10-2022 04:25 PM
aero mods-data-% change or Cd change ( installment # 7-Wheels/Tires/Wheelcovers/etc. aerohead Aerodynamics 5 06-04-2014 01:14 PM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 03:01 PM
Drafting and Cd reduction basjoos Aerodynamics 5 12-06-2008 11:45 PM
aero mods-data-% change or Cd change ( installment #6-underside/bellypans ) aerohead Aerodynamics 1 05-30-2008 11:45 PM
