Really, though, the slightly increased stability of psi may really be the only material advantage. So if your peak psi is a bit higher without the nitrogen it's not going to be doing you $27.80 plus tax better any time soon.
Gotta love the ill chosen name: TireBlast. Heh heh.
"Neglect your tire pressure even more with TireBast!"
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
