Old 02-16-2011, 04:03 PM   #1 (permalink)
Lowest /highest engine on neutral iGPH you've seen on each of your vehicles?
What's the lowest instantaneous GPH you've seen on any of your vehicles while your engine has been on and in neutral? Please no 0.0 responses; I think it would be interesting to see how much idle GPH can vary between and within our rides. Of course, the more info you can include about when you saw the numbers, the better, but even if you just give highs, lows, and your vehicle, that'll do. I'll start.
On my '95 Tercel, the highest I've seen it is around .78 or so right after starting the car on sub-freezing days where both IAT and engine coolant temps were showing 5F. The lowest I've seen so far is around .21 or so after driving around town during some of our slightly warmer days here with my radiator block installed. I bought the car in the late fall, so I'm not sure how low it can get. As spring arrives, I hope to see it drop below .2.
So short version:
Car: 1995 Toyota Tercel, AT.
High: .78
Low: .21
As you can see, that's quite a spread. 10mph at .78gph is 12.8mpg, while 10mph at .21 is 47.6 mpg. It really drives home how much of a role engine and air temps play in efficiency.
The Following User Says Thank You to bluejoey For This Useful Post:
SentraSE-R (02-17-2011)
Old 02-16-2011, 04:52 PM   #2 (permalink)
I think the lowest i've seen is .20GPH.
Old 02-16-2011, 05:36 PM   #3 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
lowest i've seen on my Jeep (3.7L V6) is 0.34, highest was around 0.8 (but it wasn't fully warmed up at that point)
Old 02-16-2011, 06:38 PM   #4 (permalink)
darcane's Avatar
2003 Silverado. 4.8L V8
Low: .44
High: ~2.75
It fluctuates a lot when I first start it up, but when it's cold, it uses a lot of fuel, even just idling. But it comes down pretty quick, it's under 1.0 within 10 seconds, and then gradually approachs the low as it warms up.
AC bumps it from .44 to .50.
Mike
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 02-16-2011, 06:56 PM   #5 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
I only have a SG on my VW.
It reads 0.10 when warmed up, cold it can go as high as 0.22.
I'm not coasting, I'm shifting slowly.
Old 02-17-2011, 12:02 AM   #6 (permalink)
Wink 7200lbs of hypermiling heaven
On my '05 Ford Excursion 6.8L V-10 my Ultra-Guage reads 2.85 at 15 degrees F and the lowest I've seen it is .83 Obviously not the ideal commuter car but it does get used some depending on weather (bad) and my work schedule vs her schedule. We try to share the Honda CR-V (1.6 cold and .31 warmed up) for our winter commutes and save the big Ex for towing the race trailer and camper.
Old 02-17-2011, 12:15 AM   #7 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Lowest .08
Highest.21
I make no claims to the accuracy of my scanguage.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 02-17-2011, 12:30 AM   #8 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
2006 Scion xB, 1.5 liter engine
0.67 gph at cold start (40 degrees F)
0.11 gph at idle when fully warmed up
0.14-0.15 gph is more typical for warm idle. I see those numbers 4 times out of 5, with the 0.11 gph seen 1/5 times
My 2002 Nissan Sentra SE-R Spec V with 2.5 liter engine
0.22 gph at warm idle
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 02-17-2011, 05:59 AM   #9 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
More info here:
How's your idle?
Old 02-17-2011, 08:28 AM   #10 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
1.5 upon starting from cold (open loop) quickly settles to less than 1.0
.15 when fully warmed.
