Old 08-05-2010, 01:56 PM   #11 (permalink)
I've never actually made it, so no pictures.
Old 08-05-2010, 02:45 PM   #12 (permalink)
90 day: 29.78 mpg (US)
What gains did you experience with a full grill block? How are your temps?
Old 08-05-2010, 02:58 PM   #13 (permalink)
Its very hard to say. I never did ABA testing. Also, I put it on in fall when the temperatures were dropping so it was very hard to tell as my mileage was dropping. The one thing I noticed was a slight hill I go down. In winter I used to slowly loose speed going down it. With the grill block I was able to maintain speed going down it. Also, warm up time was reduced a fair amount.
Old 08-05-2010, 03:28 PM   #14 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Interesting idea. How about a hood made of aluiminum that acts as a heat sink? The problem I see with both of these ideas is the lack of air movement when a fan needs to run to cool things off. My question is, how much can one gain by entirely blocking off the grill?
I believe this is a no go. Vehicle manufacturers have to adhere to certain codes, one of which says that exterior parts of automobiles can not get above a certain temperature. I am sure that pumping 200F+ coolant up near the hood would burn someone that happened to touch your hood. Safety first!
Old 08-05-2010, 03:55 PM   #15 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Actually the best way would be to use the radiator to reduce drag. The P51 did this and actually gained thrust from this technique above 300 mph.
two papers on the subject
http://naca.central.cranfield.ac.uk/...rc/rm/2147.pdf
http://naca.central.cranfield.ac.uk/...rc/rm/2302.pdf
Old 08-05-2010, 04:20 PM   #16 (permalink)
What about a black car on a sunny day? And what about the exhaust?
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 08-05-2010, 04:25 PM   #17 (permalink)
You are really making the idea appealing now. People that touch my hood should have something remind them not to be touching my hood. Scalding temperatures should do the trick. I always liked the look of the unpainted Delorean, so maybe brushed aluminum would give the car character. Anyone know the MPG penalty for a flux capacitor?
Interesting... so I just have to go 300mph and have a jet engine to implement this fuel saving trick. I've got a few mods to make...
Old 08-05-2010, 04:26 PM   #18 (permalink)
Black paint won't scald nearly as badly as aluminum backed by 200+ degree water. It has to do with thermal capacity.
You bring up a good point about exhaust. My motorcycle has a very exposed exhaust that will give an instant 3rd degree burn if you aren't careful. If I ever figure out how to cost effectively implement an aluminum hood, I'm all over it.
Old 08-05-2010, 04:37 PM   #19 (permalink)
DieselMiser
ConnClark's Avatar
no yo don't need a jet, you need something that will expel heat through a radiator. Using this technique you will experience reduced drag at lower speeds and a possibly positive thrust above 300mph if you do it right.
Old 08-05-2010, 07:01 PM   #20 (permalink)
DieselMiser
ConnClark's Avatar
One more paper
http://naca.central.cranfield.ac.uk/...rc/rm/1683.pdf
Heat Pump Temp Lockout Settings to Gas Backup RH77 Saving@Home 3 03-11-2012 09:41 AM
The Homemade Heat Pump Manifesto... AC_Hacker Introductions 23 11-08-2010 08:08 PM
Mini-split ductless question.. Xringer Saving@Home 50 05-25-2010 04:01 PM
Mini-split heat pump end of season review Forty Two Saving@Home 0 03-28-2009 12:42 PM
Fun with Voltage Controller Heatsinks Dradus Fossil Fuel Free 14 05-02-2008 03:16 PM
