Old 08-05-2010, 07:16 PM   #21 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
one thing to remember the Daox hinted at is that the lower drag will reduce the engine load and reduce the amount of work required and reduce the amount of heat dissapation required. Which would make your radiator a bit oversized for the job.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 08-05-2010, 10:37 PM   #22 (permalink)
3dplane's Avatar
14 Mirage - '14 Mitsubishi Mirage DE
90 day: 68.74 mpg (US)
Wow thanks to all your responses and ideas!
I think before I further investigate this, I will go to the extreme and just
tape up the whole front of the car including all the little gaps around the
lights,bumper,grill,hood ONLY for a few comparative high speed coast down tests.
If I can't show any considerable measurable difference going to the extreme,I will not risk overheating with grill blocks. I've done a LOWER grill block on my truck once and it over heated on me which was surprising because I thought
as long as the top grill is open where the real heat is I can't get in trouble...
( WRONG! )
Bicycle Bob hinted about the lack of effectiveness using tubes attached to
aluminum under belly plate etc. Come to think of it on SUVs and vans with
rear a/c and heat,there are these long aluminum lines going from the front to all the way in the rear to the heater and evaporator cores and the manufacturers don't even bother insulating them yet they still function so
that's a pretty good indicator what a tremendous amount of heat is being created by the engine and how good an actual radiator is really that it can handle getting rid of all the excess!
I like the hood idea as well! Could double as a large frying pan too! Go camping,crack a few eggs on the hood...throw a wet T-shirt on it to dry in seconds
Old 08-06-2010, 04:45 PM   #23 (permalink)
90 day: 29.78 mpg (US)
For those that found the hood as a heatsink idea interesting-
Source
The following is a partial list of manufacturers who use aluminum body panels.
Acura – NSX (all), RL (hood, decklid, fenders and trunk)
Aston Martin – Vanquish (body panels), DB9 (hood)
BMW– Z8 & 7 series (body panels), 6 Series (hood, doors, body panels)
Buick – LeSabre (hood), Park Avenue (hood), Rendezvous (liftgate)
Cadillac – CTS (hood), Deville (hood), Escalade (liftgate), Seville (hood)
Chevrolet – Suburban (liftgate), Tahoe (liftgate), Venture (hood)
Chrysler– Concorde, LHS, Pacifica (hoods)
Ferrari – 360 Modena (body panels)
Ford – Expedition (hood & liftgate), Explorer (hood and fenders), F-150 (hood), Lincoln Navigator (hood & liftgate), Lincoln LS (hood, fender & trunk lid), Ranger (hood), Lincoln Town Car (hood), GT (body panels), Mustang GT (hood)
GM – Yukon, Yukon XL (liftgates)
Honda – S2000 (hood), Insight (body panels)
Infiniti – Q (hood & trunk lid) I (hood & trunk lid)
Jaguar – XJ, S-type (hood)
Lancer – XJ, S-type (hood), Evolution VIII (roof)
Lexus – SC430 (hood)
Lotus – Elise Sport 190 (body panels)
Mercedes – CL500, SL500
Mercury – Mountaineer
Nissan – Altima, Maxima (hoods & trunk lids)
Oldsmobile – Aurora (hood & trunk lid), Silhouette (hood)
Opel – Speedster (body panels)
Panoz – Roadster (body panels)
Peugeot – 407 (hood)
Porsche – Cayenne (hood), 911 (hood)
Plymouth – Prowler (hood, doors & trunk lid)
Pontiac – Bonneville, Montana (hoods)
Range Rover/Land Rover – hoods, doors, side panels
Saab – 9-2X (hood)
Subaru – 9-2X (hood), GT (hood), Legacy (hood, bumpers, sunroof)
Volvo – (hoods & trunk lids)
Old 08-06-2010, 09:03 PM   #24 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
The Ford Mustang V-6 also has an aluminum hood. It's not limited to the GT. I verified it with a magnet.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
Old 08-06-2010, 09:15 PM   #25 (permalink)
insane in the propane
Cloud Car - '96 Dodge Stratus ES
90 day: 39.15 mpg (US)
my idea would be to use the high pressure area at the bottom of the windshield to flow air into a radiator. you would have to do extensive ducting though. but since most of you ecomodders do not have a/c , have it but its broken, or just never use it, then use the louvered area where the climate control system gets its fresh air from. which is the area right under the windshield. since this area is high pressure, you would be foprcing air into ducting and out of the radiator. also since this is a high pressure area and you are relieving the pressure, it might even have an aerodynamic improvment. i would be wrong though. but i know for sure that the area under a windshield is a high air pressure area. why not use some of that pressure to our advantage, instead of squandering it on nothing.
96 stratus "es" v6 auto-stick
supplementary propane injection
injector kill switch, alternator kill switch
Charging system voltage increased to 15.5V
secondary and tertiary 12v batteries in the trunk
on-board battery charger
lights converted to led's
potentiometer controlled tps for ign timing
welded straight pipe in place of cat-cons
removed egr
3 inch body drop
90psi fuel rail & -50% low volume injectors
run 15% diesel 85% gas
Old 08-06-2010, 09:51 PM   #26 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
Just make sure not to try this with an old Saturn. The plastic would probably melt
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 08-06-2010, 10:48 PM   #27 (permalink)
...beats walking...
...what about "surface" radiators like those used on the British Supermarine racing seaplanes back in the 1930's? Of course, they might interfer with door openings (wink,wink).
Old 08-07-2010, 09:40 PM   #28 (permalink)
skate - '92 Toyota Paseo
90 day: 48.56 mpg (US)
Originally Posted by PaleMelanesian View Post
Keep the radiator and resize the inlet and outlet.
http://ecomodder.com/forum/showthrea...bums-3541.html
what if you were to use this low drag cooling system and run the duct work all the way back the car and let the air exhaust through the rear bumper. could you get enough air out the back to help reduce the negative pressure back there?
Old 08-07-2010, 10:06 PM   #29 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
On a sunny day, a car hood can get up close to maximum coolant temperature just parked, so there would not be much left for cooling. A belly pan, OTOH, is safer and cooler but more prone to damage. AFAIR, the 1911 Napier Railton was the first and last surface-rad car, with copper tubes surrounding the engine and leaving only top access for quick service.
Theoretically, one could run a big duct through the car to raise pressure at the back, but the overall effect is to make the car bigger for the same useful volume, with more surface area.
The air pressure at the base of the windshield is generally lower than at the front grille. Leaving it alone is not a waste, unless you use a fan to grab low-pressure air for ventilation elsewhere. There might be a small gain to letting air flow slowly through the interior, since even a rough duct has little drag at low speed.
Old 08-07-2010, 10:20 PM   #30 (permalink)
...beats walking...
A) a similar approach to cooling round, reciprocating, air-cooled-cylinders of aircraft engines, through the use of controllable cowl flaps.
B) exactly the same approach was used to cool engine oil on both P-51 and C-69/121 propellor aircraft.
Heat Pump Temp Lockout Settings to Gas Backup RH77 Saving@Home 3 03-11-2012 09:41 AM
The Homemade Heat Pump Manifesto... AC_Hacker Introductions 23 11-08-2010 08:08 PM
Mini-split ductless question.. Xringer Saving@Home 50 05-25-2010 04:01 PM
Mini-split heat pump end of season review Forty Two Saving@Home 0 03-28-2009 12:42 PM
Fun with Voltage Controller Heatsinks Dradus Fossil Fuel Free 14 05-02-2008 03:16 PM
