03-03-2018, 11:01 AM
#11 (permalink)
One "aggressive" start would have been enough to de-glaze it?
(I put it in quotes, because it was probably a normal start for a lot of drivers.)
03-03-2018, 11:28 AM
#12 (permalink)
plot thickens... friction point thins
wdb, you just reminded me of one other (rare) symptom when the clutch was acting like garbage:
Sometimes (maybe half a dozen times) the razor thin friction point would move.
Meaning, I usually found it when the pedal was a couple of inches off the floor, but every once in a while, it would surprise me because it was right near the floor. Screws with muscle memory!
That support your theory too?
03-03-2018, 12:25 PM
#13 (permalink)
...beats walking...
A "broken" finger (or two) on the diaphragm?
03-04-2018, 10:52 PM
#14 (permalink)
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab 90 day: 20.98 mpg (US)
Right, that kind of thing. Or a stray bolt or one that backed itself out. Could also affect the actuation point.
03-04-2018, 10:54 PM
#15 (permalink)
lurker's apprentice
Then again, hmmm. How about a loose friction pad that finally fell all the way out.
03-06-2018, 07:21 PM
#16 (permalink)
Good news:
I drove the car again today -- first time in about a week -- and the clutch is still acting in its new, normal way. Somehow it seems even quieter than before. (Probably my imagination.) But a pleasant surprise.
The car is 75% less annoying to drive!
03-06-2018, 09:22 PM
#17 (permalink)
Master Ecomadman
Probably a bad or malinstalled throw out bearing.
- Tony
03-07-2018, 02:32 AM
#18 (permalink)
Furry Furfag
Originally Posted by MetroMPG
Would glaze have caused the clutch to be noisy when engaged and driving along? It was definitely transmitting some vibrations before.
Maybe I should do some more hard launches!
Absolutely. You will get clutch chatter, squeaking, inconsistent clutch engagement, and general 'rough' clutch feel.
03-07-2018, 02:33 AM
#19 (permalink)
Furry Furfag
Yes. You are essentially knocking the glaze off of the clutch.
03-07-2018, 11:51 AM
#20 (permalink)
Cyborg ECU
Seems tough to explain loud clanking with clutch glazing, I think. I like the idea of searching through the underside clutch/flywheel cover. I'd suggest a check sooner rather than later so you are more likely to find a small object before it possibly slips out a crack. My Civic's underside service-check cover is not an absolute tight fit. Little spring bits may already have dropped through.
