11-29-2012, 04:08 AM
What works with 1995 Buick Century OBD1?
The ECM in the 1994 and 1995 Buick Century with 3100 V6 is apparently unique to that application. It's OEM number is 16196387
The inventory software that salvage yards use claims that the ECM from the 94 and 95 Oldsmobile Cutlass Ciera will work, but that's the only place I've seen that so I really don't trust it. (It has plenty of errors, such as claiming major body parts from the Chevrolet Corsica are the same as the Oldsmobile Acheiva.)
I was looking into getting one of Innova's OBD1&2 scanners, downloaded the manuals and guess what? The 94 and 95 Century is NOT supported.
What also doesn't work is any sort of jumper at the ALDL to make it blink out codes.
There must be something I can plug into this thing and at least get a trouble code number!
Digging around various web fora, the difference seems to be that other applications of the 3100 in 94 and 95 had an O2 sensor for each bank along with a MAP sensor and MAF, where the Century has only one O2 and no MAP, plus its MAF is combined with the throttle body instead of being a separate piece like other GMs of the 90's. Why would GM make a different setup for the Century instead of using the same as all the other uses of the 3100? Perhaps they were compensating for never changing the design of the dash between 1982 and 1996? Logic and automotive engineers seem to part ways quite often!
Since changing the engine (which thanks to GM's hinky engineering got collapsed piston skirts at the slightest hint of overheating) with another that has only 66,000 miles (1,000 less than the failed one) it wants to run hot too.
So I changed the 195F thermostat for a 180F one. Runs great but in traffic, even when it's cool and raining, the temp gauge will go up almost to the red, the fan kicks on then it drops down to just below halfway. Wash, rinse and repeat.
I'd like to reprogram the fan turn on temperature down a ways to work better with the lower temp thermostat. I don't care about it supposedly being more efficient running hotter, I care about the engine not self destructing because it simply cannot tolerate running near the limits of a 16 PSI cooling system, thanks to GM's too tight piston tolerances. It has a second fan in front of the radiator that is supposed to come on when the temp hits the bleeding edge of blowing the radiator hoses off, but it didn't work when it overheated and ruined the engine. I'd like to program that one to come on at the temp the main fan is set for. The fans will work, I've tested the relays and there's power to them, jumper the relay plugs and they run. I've also installed new ECT and temp gauge sensors.
Another thing it needs is reprogramming the inaccurate from the factory speedometer. It reads up to 3MPH faster than the actual speed, checked with GPS. Yes, it has the correct size tires, with only 5,000 miles.
12-01-2012, 02:28 AM
eco-scrapper
The simple (albeit inelegant) solution to getting the fan to come on sooner is to just wire it into a "hot when key in run" source of 12VDC.
If you want the second fan to operate at the same temp as the first, the simple (and reasonably elegant) solution is to splice and solder so that both fans share a common source of electricity.
5% optimistic speedometers seems pretty "industry standard" to me...most vehicles I've owned were in the 3-6‰ range.
12-01-2012, 04:48 AM
Simple, and would make it run too cool in winter.
Going by the inaccurate odometer it gets around 26 MPG in highway/freeway driving, but since it's reading less miles than actually traveled, it's getting better than 26 MPG. How much better? Dunno. Would be nice to have it closer to reality.
12-02-2012, 12:40 PM
eco-scrapper
Constant-on fan should'nt "cause the car to run too cool in winter": that's why cars have thermostats. Constant-on fans driven off the serpentine belt have been around for darn near a century and constitute "proven technology."
(Obviously not the most efficient approach, but you did say you were primarily interested in saving the motor here...)
A slightly more elegant solution would be to adjust the temp sensor to tell the computer the coolant is slightly warmer than it actually is: 195F when its actually 180. IIRC, the sensor is a variable resistor, and you'd need to slightly tweak the Ohm rating.
As for odometer issues, a 5% optimistic speedometers does NOT necessarily correspond to a 5% optimistic odometer. (Usually sppedos read slightly fast, on purpose, to discourage speeding.)
To calibrate your odometer, "zero" it on an interstate, right at a mile marker (MM 120, for example). Then drive a fixed number of miles (say 20, to MM 140). If your odometer reads 20.3, you know it's 1.5% optimistic.
(A little math seems much easier than hacking an OBDI system, but hey, if that's what snaps your girdle, who am I to tell you not to? Just trying to be practical.)
12-02-2012, 02:17 PM
Chief - '06 Pontiac Grand Prix 90 day: 25.8 mpg (US) SF1 - '12 Ford Fiesta S 90 day: 22.87 mpg (US)
On my car (06 GP) the operating range 194 to 225. The cooling fans with the AC off, won't come on until the temp reaches 220 degrees then turn back off at 197degrees, via the u gauge. The factory temp gauge acts very similar to your description, this appears to be normal operation as the temperature stays within the specified operating range.
Read this for some insight on factory instrumentation:
http://http://ecomodder.com/forum/sh...ges-19568.html
An alternate method of checking the engine temperature may be in order.
12-03-2012, 07:28 PM
MC SBX - '95 Chevrolet Monte Carlo LS Last 3: 29.75 mpg (US)
yay, something i'm an expert on....
the 94-95 3100 A-bodies have an ECM that is unique to them, so any other 94-95 3100 A-body ECM will work.
you can build or buy an ALDL cable to communicate with the ECM via a laptop using tunerpro RT. i've built the definition for it and it's been tested by a few people to work correctly.
the A-body is unique in that the 94-95 3100s use an integrated MAF and no MAP sensor. the other 94-95 3100s don't use a MAF sensor. they still all use 1 O2 sensor. the A-body also uses an older style MEMCAL ECM, the other platforms used a module that is equipped with flash ROM.
i could reprogram the MEMCAL from your ECM to whatever thermostat you want to run, but it would probably take around a week to ship it from you to me, me reprogram it, then send it back to you.
the speedometer being off could be one of two things: goofy calibration from GM (would not be the first time) due to one calibration having to fit multiple scenarios, such as different wheel/tire options or it could be that the speedometer itself is the issue. if the odometer is reading correctly and the speedo seems off, then the calibration is fine. if the odometer reads incorrectly, then the calibration is at least one problem.
i actually have the calibration used on the 94-95 A-bodies listed as having fan 1 and 2 on at:
106 *C (223*F)
112 *C (234*F)
then, they turn off when they reach:
102 *C (216*F)
108 *C (227*F)
12-03-2012, 09:58 PM
<clip>
106 *C (223*F)
112 *C (234*F)
102 *C (216*F)
108 *C (227*F)
Got a link to software and plans for the cable?
234F is too @#%%# hot, especially for the pre-1997 3100. That's right at the limit for a 16 PSI system, and the early 3100 doesn't have the polymer coated piston skirts. By the time the 2nd fan comes on the engine is eating itself, if not before the 2nd fan comes on.
GM knows they screwed this up*. Sometime in 1996 they started putting the coating on pistons 5 and 6, by 1997 they put it on all the pistons. All new 3100 pistons are polymer coated, and rather expensive.
I've checked the odometer against mile markers, it's off as much as the speedometer.
I assume the MEMCAL chip has to be removed, erased (UV lamp or is it EPROM?) then the edited code loaded?
*If you think the too tight pistons in the 3100 are screwy, how about some of the newer GM V8's? They're designed so the pistons just hit the heads at operating temperature. A knocking sound during warm up is carbon deposits getting knocked off the edges of the pistons and combustion chambers. Let one of those get too hot and it's broken pistons and heads. A GM dealer service manager (who's been such for near 40 years) told me that and about the 3100's issues. "That sound that sounds like the engine is beating itself to bits? That's normal."
12-03-2012, 10:41 PM
software: TunerPro and TunerPro RT - Professional Automobile Tuning Software i prefer V5, though if your computer can't support it, V4 will still work. then you'll need the ADX (V5) or ADS (V4) for your application, i can email or put them on a file server for you.
cable will depend on if you want to make a USB or serial version, depending on what your computer has. if you have the option, go USB, it's much simpler. the serial version would require a MAX232 circuit to convert the TTL signals to RS-232 specs so that the computer will play nicely. a USB version only requires a USB to TTL converter, which takes all of 2 wires to connect (i'll expand upon this later, if necessary).
yes, the stock temps are way too high... running a 195*F thermostat, i run either a 205 or 210 *F on temp for fan 1, depending on how sticky the thermostat tends to be. then slightly higher for fan 2. i rarely see/notice the fans on, but i never see the temp guage creep into uncomfortable territory.
i know all about 3100s and their tendacy to make noises implying immediate death... lifters and piston skirts are responsible for that, but i've had it happening for over 60,000 miles now and it still runs great otherwise.
since the odometer and speedo seem to be off by the same amount, i'd say the calibration is compromised due to GM not wanting to support another calibration.... so with your wheel/tire combo, it reads slightly too fast, but with another offered combo, it reads slightly too slow. not too big of a deal to compensate for, though if i were you, i would check the speedometer against what the ECM is commanding it to be in the datastream.
while the stock EPROM can be erased via UV, they're nearing their end-of-life date, so i replace them with EEPROMs that have a 100 year rating. that and 1.5 second erase times compared to ~10 minutes is a no-brainer.
12-04-2012, 01:15 AM
#9 (permalink)
If you could e-mail the info to g_alan_e@yahoo.com I'd appreciate it. I can find the EEPROM easily if I know the chip's part number.
I used an inspection camera to have a look in the cylinders on the original engine after I got it out. It wasn't very nice inside anymore. Parts of the piston tops looked like they may have melted a bit.
The "new" engine's piston tops were nearly completely buildup free and the cylinder walls were shiny. Still makes a bit of noise until it warms up. So did the original until after it got hot enough to blow coolant out (and the 2nd fan never came on) it clattered all the time and had no power and would overheat going up the slightest grade. Most likely the knock sensor was making it always retard the timing.
It overheated going up a 4,200+ foot high mountain pass. I don't want that to happen to it again.
12-04-2012, 03:32 PM
#10 (permalink)
is that email without or without the underscores?
knock sensor being oversensitive is a possibility, i've certainly ran into that before as well.
