Old 01-09-2009, 09:01 PM   #1 (permalink)
Tracy - '00 vauxhall corsa
wheel covers: corugated plastic or taped hubcaps?
hi
my corrugated plastic wheel covers are causing problems. i took them off because the center of the wheel sticks out and the tight cable ties caused them to bend which looked weird after a while. now with slacker ties there is a gap between the covers and the wheel. this seems like bad for aero? taped budget hubcaps would be better i think?
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
Old 01-09-2009, 09:40 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Another option is to heat up the plastic and try to form it so it's "dished". You can shape coroplast to a certain extent if it's warmed carefully (it'll melt if you're not) with a paint stripper. Or maybe with a torch, held at a distance ?
Old 01-10-2009, 10:08 AM   #3 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
I will be installing my 13 inch wheels soon.
I got some 13 inch hubcaps from the boneyard and I am going to try and cover them in aluminum flashing.
I will post the process in my build thread;
http://ecomodder.com/forum/showthrea...hing-4181.html
Which will re-start today.
L8R,
S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
Old 02-08-2009, 02:18 AM   #4 (permalink)
hi all.
any one can help me.
i find find pdf file format regarding the rear wheel cover.
and then how the drag force will reduce by the rear wheel cover.
please mail to me if anyone can help.
dhanush8653@yahoo.com
thank you.
Old 02-08-2009, 07:54 PM   #5 (permalink)
order99's Avatar
I've ended up taping my wheels with Gorilla Tape so far-the '93 Festiva has Axel Caps rather than Hubcaps, so I need serious curvature! Pizza pans just won't do the trick on this one...
When I have more time(and better weather) i'll try cut-n-gluing Coraplast into a Moon Cap just deep enough to clear the axel ends...until then, taping is cheap and effective.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
how to make skirts for plastic wheel arches? modmonster Aerodynamics 6 01-22-2009 11:06 PM
Universal Flat wheel Covers trikkonceptz EcoModding Central 14 06-28-2008 11:29 PM
Modded wheel covers to make them smooth MetroMPG Aerodynamics 1 11-27-2007 08:43 PM
