Old 06-02-2008, 09:14 PM   #1 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
Crank pulley removal
So I'm trying to get my crank pulley off and so far I've accomplished the following:
1) Wear myself out
2) Bend the hell out of my biggest screwdriver
3) Nearly break my 3/8 rachet.
And still the crank pulley remains firmly attached to the car.
I have been attempting to hold the pulley still with my big screwdriver (jammed into one of the holes, holding against the oilpan flange)
Meanwhile a helper applies force to the crankshaft pulley bolt using my 3/8 rachet and a 2' cheater bar.
Once force is applied, I tap on it with a hammer. (cheap impact driver)
So, does anyone else have any suggestions for me?
I'll probably end up buying a 1/2 breaker bar tomorrow. But I'd really like to avoid having to rent a impact wrench and air compressor.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 06-02-2008, 09:31 PM   #2 (permalink)
Curious....
koihoshi's Avatar
DoesNotHaveANickname - '99 Ford Escort ZX2
Without immobilizing the crank about the only way to do it is with a strong impact gun. They're never in there anything beyond "OMG THIS IS HARD TO GET OFF!" which is some ungodly amount of ft lbs. I had to use a strong impact gun to get mine out. You're taking it off ENTIRELY? Are you taking off alternator/powersteering/ac entirely too?
Old 06-02-2008, 09:37 PM   #3 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Air powered impact is the only way to win. It also helps to put a small amount of silicone on the bolt when re-installing it to prevent any oil leakage.
GeoMetroforum.com - got mpg?
Old 06-02-2008, 09:50 PM   #4 (permalink)
AndrewJ's Avatar
I'm just taking it off to get at my leaky water pump. It'll be going right back on once that's all taken care of.
Grrr. That's what I was afraid of. That's gonna set me back....
I'm almost contemplating driving it to a shop to have that one stinkin' bolt removed. It's not like I even need the crank pulley to drive it back home (I am running the alternator beltless after all)
Old 06-02-2008, 09:51 PM   #5 (permalink)
Johnny is right on. An impact is pretty much necessary. If you don't have access to an air compressor electric impacts work alright too. Maybe they rent them locally?
Old 06-02-2008, 09:53 PM   #6 (permalink)
Red
Red's Avatar
An impact gun is the only way I've seen them come off
Old 06-02-2008, 10:29 PM   #7 (permalink)
90 day: 51.82 mpg (US)
I'm lucky my local garage has been pretty good about stuff like this - I've dropped by once or twice with uncooperative nuts/bolts and they've run the air hose out and freed it for me on the spot. Must be my puppy dog eyes.
Old 06-02-2008, 10:36 PM   #8 (permalink)
Hi-Tech Redneck
Yes! An electric impact would also do the job!
Old 06-03-2008, 12:53 AM   #9 (permalink)
EcoModding Seige Tank
digitaldissent's Avatar
yarii - '07 Toyota Yaris 4dr (auto)
90 day: 41.37 mpg (US)
Bullet Bill - '07 Toyota Yaris 2dr hatch
90 day: 36.19 mpg (US)
don't drive it with the bolt out, if that pulley moves and the timing belt jumps you have bent valves on your hands.
I have replaced a few Honda heads in my time, pretty easy but when your paying it costs money
and yeah as johnny said I have only seen those come off with an impact gun
I am not trying to save the planet, just trying to hurt it a little less
Yaris build thread
what is... http://en.wikipedia.org/wiki/COINTELPRO
Old 06-03-2008, 08:04 AM   #10 (permalink)
adam728's Avatar
Mazda3 - '08 Mazda 3 S
90 day: 29.65 mpg (US)
DR650SE - '13 Suzuki DR650SE
90 day: 46.16 mpg (US)
Wife's - '12 GMC Terrain SLE-2
Impact, or a BIG breaker bar. I've done em on 2 Toyota trucks with a large 1/2" breaker bar and a 3 foot cheater pipe. Hard to get enough room to swing the whole thing though. 200+ ft-lbs plus Michigan rust equals "damn that's tough!".
Muffler removal DifferentPointofView EcoModding Central 31 06-16-2008 10:39 AM
CVCC crankshaft s2man Off-Topic Tech 6 03-03-2008 12:19 PM
