Old 09-05-2008, 02:55 PM   #11 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
Your analysis aside, I think big rigs get better mpg per pound because they have to. Meaning their purpose is to haul in order to make money, passenger cars are simple transportation for individuals.
Therefore the industry put forth much more effort to make those monsters more fuel efficient in an effort to reduce operation costs. Same would hold true for trains. There is less pressure to make improvements in those fields because it serves the greater good, product and services. Whereas commuter cars are expendable and simply a profit center from which to reap benefits.
This also translates to replacement parts. More passenger cars are repaired at shorter intervals than tractor trailers. My guess is for the same reason.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 09-05-2008, 03:02 PM   #12 (permalink)
greenitup's Avatar
Truck - '97 Ford Ranger
90 day: 30.32 mpg (US)
well the frontal area is bigger but isn't 10 X bigger, also when you have 8 gears (think that is the amount) you don't get high rpm's
Old 09-05-2008, 03:09 PM   #13 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
gearing varries... up to 14, i think.
Old 09-05-2008, 03:14 PM   #14 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Originally Posted by Gregte View Post
The fact is, cars are already geared as they need to be to most efficiently do their job, as are trucks.
Trucks I agree with, but passenger vehicles are seldom geared to efficiently do their job. They're often geared to make them seem peppier or smoother. Only those marketed as fuel efficient are actually geared properly for efficiency.
Old 09-05-2008, 03:59 PM   #15 (permalink)
Neon1 - '97 Plymouth Neon highline
90 day: 27.26 mpg (US)
The inline engines are actually still used because of reliability. The 7 main bearings in an inline 6 supports the abuse better than the 5 in a V-8. Of course an inline 8 would have 9, but the length of the engine becomes an issue and they do not produce that much more torque for the weight added. The higher compression of a diesel does also add a higher amount of force on most all of the rotating parts
Jim
Old 09-05-2008, 04:02 PM   #16 (permalink)
Wildfire - '96 Ford Bronco XL
90 day: 14.88 mpg (US)
Blackford - '96 Ford Bronco XLT
90 day: 20.26 mpg (US)
Y2k - '00 Honda Insight
Gen-1 Insights
90 day: 73.98 mpg (US)
Redford V10 - '01 Ford F250 Lariat
90 day: 15.64 mpg (US)
FireFly - '00 Honda Insight DX
90 day: 69.43 mpg (US)
LittleRed - '00 Honda Insight
They are more aerodynamic.
Old 09-05-2008, 04:07 PM   #17 (permalink)
Wicked Wanda - '99 VW Beetle GLS
90 day: 29.59 mpg (US)
Green Monster - '99 Ford Explorer Sport
90 day: 16.73 mpg (US)
Dad's Taxi - '99 Honda Odyssey EX
90 day: 24.23 mpg (US)
Some Road Ranger trannys have 18!
Old 09-05-2008, 08:37 PM   #18 (permalink)
GMC Sonoma - '94 GMC Sonoma
90 day: 36.97 mpg (US)
Well then why don't we ecomodders raise, or lower, our final drive gear ratios by changing differential gears?
Trucks have more gears because diesels have a much more limited RPM range. And once you are up to hiway speed the only gearing that matters is your final drive gear. More gears has nothing to do with hiway driving for a car unless your terrain is so hilly that you would actually be downshifting on the hiway.
Old 09-05-2008, 10:19 PM   #19 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
If I had RWD, I would, but I don't know enough about FWD transmissions to comfortably replace the gear.
Old 09-05-2008, 11:08 PM   #20 (permalink)
IIRC, the ones I used to drive (decades ago) had about 20 speeds: 10 in the gearbox, plus a 2-spd rear end.
This is another reason why trucks get better fuel economy. The large number of gears means the engine can be run closer to its optimum efficiency. In addition, long-haul trucks just get out there on the highway and cruise at a steady speed for hours, which is a lot more efficient than the typical passenger car pattern.
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 05:53 AM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 09:24 PM
Looking for a fuel efficient solution. I've got a few ideas. CuriousOne EcoModding Central 41 03-28-2009 02:46 PM
Big Surprise: Fuel efficient cars are holding their value better than other cars SVOboy EcoModder Blog Discussion 2 09-19-2008 08:52 AM
