09-23-2018, 10:17 PM
#131 (permalink)
I'm going to keep the heat pump. I installed a wood and coal furnace, to reduce winter heating costs I have a gas dryer that I don't use I will convert it over to propane this is more of an off grid thing and want to get a propane stove.
So far I have three 100lb propane tanks I bought used and had filled for the price of 1 new tank filled.
Then this year I plan on also getting a little wood stove or pellet burner for the other end of the house.
The only drawbacks to propane that I am aware of are a smell, and perhaps some soot. Both related to improper combustion. I expect that you will have that covered.
Propane is quite a bit more money than natural gas here, but I guess that's related to how much you use.
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
09-24-2018, 08:46 AM
#132 (permalink)
The problem with natural gas is I can use 0 and it still costs $25.
At that rate natural gas is way more expensive.
With the summer surcharges I could buy 400 pounds of propane.
10-05-2018, 06:34 PM
#133 (permalink)
Another 1,000 wind turbines going up in NM under the corona wind project.
Start date, probably next week, all turbines on line in 2020.
10-05-2018, 07:33 PM
#134 (permalink)
It looks like they are only allowed to pump 22Mw on the grid...
10-05-2018, 09:30 PM
#135 (permalink)
10-05-2018, 09:48 PM
#136 (permalink)
I'm a bit indifferent. In 50 years we'll all be on nuke power, so wind for now might help get us there.
10-05-2018, 11:01 PM
#137 (permalink)
On the radio they said 22Mw, twice.
I know we got wind here. They send wind turbines here to wear them out in 10 years.
They could build a 2Gw line but it would be gigantic. With 140 miles of materials and 140 miles of right of ways the price tag would be even more gigantic.
10-06-2018, 07:53 AM
#138 (permalink)
There is no sense putting in 2.2 GW of turbines if you don't run at least a 1.5 GW power line. The plan is to wire 160 miles to Albaquerque to turn left on the Sunzia 3 GW line 520 miles to Arizona. $2 Billion. But it is still held up over bird safety at the Rio Grande crossing at Escondida.
https://www.abqjournal.com/1208591/s...-up-again.html
And people think we will have 2,000 mile TeraWatt level transmission lines running from country to country after we electrify all energy.
10-06-2018, 10:45 AM
#139 (permalink)
10-06-2018, 11:11 AM
#140 (permalink)
I'm skeptical. The premise is vertical mixing. The blades are removing energy not adding it, so where does the vertical component come from?
.You can't be wise and in love at the same time. -- Bob Dylan
