Old 10-22-2011, 07:10 PM   #1 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Winterizing the White Whale
Well things are getting chilly here in Indiana this time of year, so I thought I's take some steps to see what I can do to help my warm up times. I've been using by block heater and an upper grill block, but have been wanting more.
So on Friday morning I added a full radiator block. I took a piece of sheeting and cut a piece big enough to cover the whole radiator and zip tied between the radiator and intercooler. It was about 40 deg F outside and even with leaving it plugged in all night and with the radiator block and the upper grill block, it still took around 10 miles for my coolant temp to get fully warmed (~200 F). Even so, I think the radiator block helped some--the last few days the temps were about the same and it was taking 11-12 mi to warm up. At this point I must stop and admit that, YES, my engine is extremely oversized for how I use it!
So today, I finally got an opportunity to install the oil pan heater that I bought a while back. Ahh yes, my idea of a perfect Saturday afternoon in October is lying under my truck sanding the paint off my oil pan (sad, but I'm serious). I just got em on there and they look pretty sweet. I got 2 150-watt pad heaters. I sanded the paint off, stuck em on, and sealed up the edges with some RTV. I put one each side of my oil pan sump. If people are interested I may take some pics and upload them too. Stay tuned for results...
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 10-22-2011, 08:14 PM   #2 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
sounds like a good idea.
Old 10-22-2011, 10:26 PM   #3 (permalink)
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
I added a oil pan heater to go along with my block heater last winter and I think it has helped a bit. Diesels are cold blooded at the best of times since they are a more efficient engine. I'm sure anything you can do to warm it faster will help you out. Have you added a front belly pan? It would help keep the heat in and help the aero. as well.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
Old 10-23-2011, 07:10 AM   #4 (permalink)
No, no belly pan yet. That definitely is on my to-do list though. Eventually I want to do pretty much a full belly pan. The truck has a huge amount of area down there that looks very bad for aero. I think it's probably even worse than it is for a car too, because my truck sits so far off the ground there is much more air flow too.
Eventually I should get around to it. Every so often when I'm under the truck, I find myself looking around--hmm, I could attach here and here and...
Diesel Dave
Old 10-23-2011, 08:26 AM   #5 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
I've always wondered if they would help on the tranny as well ?
Mines a manual so I haven't had a test bed.
How much were the pad heaters ?
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 10-23-2011, 10:15 AM   #6 (permalink)
I'm considering putting one on the tranny. Why wouldn't you put one on a manual?
Pad heaters were $26 each including shipping on Amazon: Amazon.com: Kat's 24150 150 Watt 4"x 5" Universal Hot Pad Heater: Automotive
Diesel Dave
Old 10-24-2011, 12:23 AM   #7 (permalink)
JasonG's Avatar
Didn't think I would see a difference. I have heard of pumpkin temps being recorded and change noted. Of course that has 90W in it and my tranny only 30W......... I think........ some old ones did use 90W........... time to climb under and check !
I guess for $50 I could try both and win all around. Thanks for the ideas !
Old 10-24-2011, 04:32 PM   #8 (permalink)
Some preliminary results....
So on Sunday I ran with basically no block heater or oil pan heaters and I watched my oil pressure gauge. I don't have an oil temperature gauge. It was in the high 40's outside. It took about 7 miles for my idle oil pressure to go to 40 psi ("normal" warm range).
This morning I plugged the block heater in overnight and the oil pan heaters were on about 5 hrs. Temps this morning were about the same, high 40's. This time my oil pressure went down to 40 psi in only about 3 miles. I'm not sure, however, how much of that may be the block heater--obviously that would help the oil warm up faster too. Maybe sometime I'll try plugging in only the block heater or only the oil pan heaters. Coolant warm up seemed to be helped too-about 8 mi to get to 200 F.
So, it does seems to be helping my warm up. Too early to tell the FE benefit. Today's trip read 37.3 mpg on the lie-o-meter, which is about my average, maybe a tick under. But the roads were wet and I had a slight headwind. Gotta collect some more data...
Diesel Dave
Old 10-24-2011, 10:09 PM   #9 (permalink)
puddleglum's Avatar
It amazes me that you can pull that kind of mileage from a full size truck. I know diesels are efficient, but that is impressive
Old 10-25-2011, 11:55 AM   #10 (permalink)
Thanks, but realize that 37.3 mpg was from the in-cab display, which is appropriately nicknamed the lie-o-meter. In my experience, it reads ~15% high.
Diesel Dave
