Old 05-13-2010, 03:30 PM   #111 (permalink)
X-Frenchy: very
groar's Avatar
scenic - '01 renault scenic
90 day: 43.09 mpg (US)
megane - '97 renault megane classic
Diesel
90 day: 72.53 mpg (US)
dennisius - '06 Toyota Prius
90 day: 69.27 mpg (US)
Originally Posted by PaleMelanesian View Post
1108 miles on a single tank
13.82 gallons
80.2 mpg!
Congraaaaaaaaaaaaaaaaats
I hope to reach the 1100mi this summer (now the 1111.1 but I'll never reach the 80mpg, my mpg goal is only low 70s which is enough with a 15.85 gal tank.
Your new pb is so incredible, noticeably for a nearly stock car.
Are your tires always at 60psi and what is their max sidewall ?
Do you always use 5w20 oil ?
What is your commute and techniques like ?
Thanks in advance,
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving:
  • 5725.5 kg CO2 (5342.6+382.9)
  • Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
Old 05-13-2010, 04:14 PM   #112 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Tires are down to 60 now. I had them higher a few months ago, but they've drifted down. I don't find any benefit above 60.
I always use Mobil1 5w20. This car calls for 5w30, but I use the lower weight for less friction. It's also what the other car calls for, so I use the same in both. Easier to stock only one in the garage.
My commute is rolling hills, 50-100 feet elevation change up and down. 10 miles, with a mix of 35, 45 and 55 mph speed limits. 3 stop signs and 4 traffic lights. I choose this particular route because most of it is multi-lane roads and I don't hinder traffic from going past.
I do Pulse & Glide (eoc) with a 25 to 40 mph spread (Scangauge says 25 mph average, but that's counting stops). I adjust that a little higher and lower in certain spots and for traffic. I drive as if I have no brakes - my best run I touched the pedal 5 times (including when I parked at work). That involves anticipating the light cycles so I can roll through on the green.
There's one spot, on a flat hilltop, where I roll along at ~10 mph for half a mile. Those neighbors give me looks.
Old 05-13-2010, 05:24 PM   #113 (permalink)
X-Frenchy: very
groar's Avatar
Diesel
Thanks Andrew for this reply.
I simply keep my tires at sidewall (51psi), I may try more this summer when the min temps will be more stable.
I'm also using a lower weight oil : synth 5w30 instead of 10w40.
I'm a big fan of DWB (Driving without brakes / driving with buffer) but with the exits and entries on my commute roads the speed is very variable and except during holidays, good brakes are a must
I should try to count my number of break touches, this may be a good parameter
I'll permit me to not count my very light break touches I do when I begin to coast so people behind me know that I'm slowing down.
Last summer my records were beaten with P&G (EOC). On French roads people accept people driving slowly, but not variable speed. As I'm blind (no real time fuel consumption display) this year I prefer using DWL with a speed at around PSL-20km/h (12mph) when PSL>=90km/h (56mph).
I'm always using EOC, noticeably in the morning during the first 8 km (5mi) between lights and round about.
My car is given more and more looks, but for different reasons
Denis.
Old 05-15-2010, 10:08 AM   #114 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
30 MPG on the freeway, 28 with a mix of conditions. I'm trying hard to get consistent tank averages at or above 30!
Maybe I'll switch to 5w20 instead of 30 and see what that gets me.
In Reason we Trust
New personal best mpg in my Xantia ecoxantia Success Stories 4 08-04-2009 08:24 AM
My personal Drama (caution, LONG) metroschultz The Lounge 13 01-12-2009 01:01 AM
Two World Speed Records CobraBall Aerodynamics 5 09-28-2008 01:24 PM
