Old 10-08-2016, 01:28 AM   #91 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
You should be able to find a Swift center panel, they are red and can be lit for extra brake
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
The Following User Says Thank You to me and my metro For This Useful Post:
MPGeo (10-23-2016)
Old 10-08-2016, 02:28 AM   #92 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Some Metros had the red center panel too.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
MPGeo (10-23-2016)
Old 10-08-2016, 04:35 AM   #93 (permalink)
MPGeo's Avatar
MPGeo - '93 Geo Metro Base
90 day: 67.51 mpg (US)
I knew about the red center panel... But i didn't know it was translucent. I actually like the Swift tail lights & dash better than the Metro setup.
Will keep that in mind
Old 10-10-2016, 05:53 PM   #94 (permalink)
MPGeo's Avatar
LED Headlights
LED headlights are in... and they work Great
PICTURE OF LOW BEAM 6-3wbulbs = 18w per side
Had to spend quite some time t/s why lights wouldn't work properly... and as of now they are patched - Only Low Beam working. I'm working on a fix, and once fixed I will update as the why and hows.
ID:	20670   Click image for larger version
ID:	20671   Click image for larger version
ID:	20672   Click image for larger version
Old 10-10-2016, 06:34 PM   #95 (permalink)
90 day: 39.99 mpg (US)
Looks pretty good. I never thought I'd say this (or anyone would say this), but I'm jealous of your Metro.
Old 10-11-2016, 10:32 AM   #96 (permalink)
MPGeo's Avatar
Well thank you...
But I must admit that I never thought anyone would say that either
Just to be fair, I'm jealous of your mpg
Old 10-20-2016, 07:22 PM   #97 (permalink)
MPGeo's Avatar
So I finally was able to test and implement my FIX for the LED Headlight Conversion... I wrote a How-To thread on it explaining the why's and hows to make it work properly.
LED Headlight How-To
It's quite interesting if you ask me
The Following User Says Thank You to MPGeo For This Useful Post:
Joggernot (10-21-2016)
Old 10-21-2016, 12:57 PM   #98 (permalink)
MPGeo's Avatar
3rd brake light update
So it's been a week or so since I've installed the LED 3rd brake light, and I have made three changes to the setup.
1 - Modified wiring to include a brake light controller for added visibility.
This allows it to blink 4 times fast, 4 times slow, and then steady until reset.
2- I added a rubber hose to upper end of bracket to cushion bracket against window and eliminate road vibration chatter against glass.
3- Had to add a ground jumper from main body to hatch door. The 3rd brake light would sometimes come on and and sometimes it would not... T/S and found improper grounding through hinges, and grounding through latch. Jumper wire provides constant ground and eliminated the issue.
3rd brake light mod is now officially compete
ID:	20768   Click image for larger version
ID:	20769   Click image for larger version
ID:	20770   Click image for larger version
Old 10-22-2016, 09:11 PM   #99 (permalink)
MPGeo's Avatar
Cool Fuel #s In - Let the Mods Begin
So I've already managed to put little over 2,000 miles since engine rebuild, and have gone through 5 tanks, driving until empty and filling up every time and keeping track of all my #s and so on..
And to be honest I'm somewhat disappointed by my baseline results.
So far my overall mpg is 46.7, with a best tank of 50.46.
I know my driving speeds don't help me much, but I was really counting on that 3.52 tranny to push me into mid 50's... But I guess I still don't know if it's really a 3.52 (I haven't lifted it yet to count revs and verify - but that's another story)
I've been somewhat holding back so that I could create a baseline... Well #s are in. It's now time to knock out some of the low hanging fruit and really start getting into it and see what it can do.
I know from the tools provided on this site how that most of my inefficiencies come from aero drag... And since I had some time I decided to go after the biggest bang for my time.
It helps that my parts car already had a kammback
With kammback removed I proceeded to paint both sides
This is my new look
While I was at it I removed the passenger wiper arm
And also removed the "cold-air" section of the intake, this should in theory allow for relatively warmer air intake.
That's all I managed to do to it today. I looked into removing my passenger side mirror and antenna today, but I wasn't sure how I was going to cover the exposed holes. I'll have to see what everyone else is doing for ideas. But I do have a parts car to use as a template so I'll do that at a later time.
The next few things to come will be as mentioned side mirror & antenna delete, but also grill blocks, and headlight covers.
ID:	20775   Click image for larger version
ID:	20776   Click image for larger version
ID:	20777   Click image for larger version
ID:	20778   Click image for larger version
The Following 2 Users Say Thank You to MPGeo For This Useful Post:
Ecky (10-22-2016), freebeard (10-22-2016)
Old 10-22-2016, 10:15 PM   #100 (permalink)
The tail lights are always a problem. What would you think of getting some taillights off a late model Volvo station wagon, those half-crescent ones?
I think if you aligned the bottom to the bumper they would reach about half-way up the Kamm-back. Then you could add bumper guards underneath to 'Kamm-back' the outer corners of the bumper.
MPGeo (10-22-2016)
