Old 03-01-2014, 11:18 PM   #71 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
What boat tail ....... ������������������
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 03-03-2014, 11:31 AM   #72 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Nice work redneck. Keep us apprised of results. Do scrupulously strignent records so you wind up with solid gold bragging rights.
Actually no truth in advertising.
When you said "boat tail redneck style" I had visions of an old crapped out bass boat flipped over and held on by duct tape.
Your work is way better than you let on.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
redneck (03-03-2014)
Old 03-04-2014, 08:55 PM   #73 (permalink)
AeroGuy
eco_generator's Avatar
Outback 14 - '14 Subaru Outback Limited
90 day: 23.1 mpg (US)
This was awesome.
And way too clean to be redneck.
I was thinking the exact same thing before I clicked on the thread, lol!
Old 03-04-2014, 10:01 PM   #74 (permalink)
Don't think it hasn't been done. And I think redneck is a perfectly cromulent descriptor, esp. given your handle. People talk like it's a bad thing.
Old 03-04-2014, 10:09 PM   #75 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Phil (Aerohead's) actually done it. Modified sailboat/dinghy hull on the back of his Toyota.
Old 06-06-2014, 01:51 PM   #76 (permalink)
Update...
It's been a year since I installed the boat tail and I'm pleased to say that it has held up and performed well. However, there is still room for more improvement. Not to mention, the lack of any type of eye appeal whatsoever.
It's time to kick it up a notch or two.
I'll use this for inspiration.
First, I needed to address the uneven air flow on the sides.
(tires, body roll, front and rear bumpers)
So, here's what I have to work with.
This will give you an idea of the amount of body roll in the original design.
It will be plumb and vertical when finished. With the entire front wheel slightly recessed within the wheel arch.
Time to get to work.
So, with my trusty 1/2" foam insulation board and a razor. I cut and shaped some body panel fillers.
First things first, the door panels.
The foam that you see in the wheel arch is there to gauge how much the side needs to come out to be vertical. It will be left in and used as a front wheel arch gap filler. (there's also a piece of foam in the rear wheel arch)
Next, a piece to bring out the rocker panel was fabricated. Along with the pieces that are needed behind the front wheel.
(note the section left out on the door panel and the quarter rounded piece on the floor. These are needed in order to open the door)
Next.
Rear fender cover and skirt.
When I built the tail it was a rushed job and I didn't take fully into account the rear bumper. It stuck out past the side of the boat tail slightly so I took a piece of aluminum flashing and tried to cover it up.
Not very pretty.
So, I fabricated a full fender panel that would cover the problem area and blend the tail and side of the car together. Plus, allow for a full skirt.
(this was a pattern used for initial mock up only)
Final version installed on the car.
(note tabs for mounting skirts)
Now, on to the under belly of the beast.
And again, the inspiration...
What I'm working with.
From the front.
From the rear.
I built the under pan out of foam, with stucco screen in the high heat exhaust areas. The screen also helps to remove hot air from the engine compartment.
Front view.
Rear view.
Screen for exhaust and cooling.
Wheel spats.
VW XL1 uses full boat tail wheel spats front and rear. (you can see them in the above pic from vw)
If there good enough for VW, there good enough for the Metro...
Building them was easy. Just cut the pieces out and glue them together.
If you look at the under pan pictures, you can see them. However, I'll try to take some better pics this weekend.
Next, the front bumper.
Here's a pic of what it looked like to begin with.
I made a 3 piece wrap that covers most of the bumper. It also ties into the belly pan and the new side profile.
And last but not least, some pics with the rear skirts installed.
Well, that's about it.
Except...
I think it's time to rename "little blue".
Before...
After... (with a little paint)
Well, that's my redneck inspired version of a Geo XL1...
Which, now.
Is it's new name...
So, what's it like driving now...???
Stay tuned...
The Following 31 Users Say Thank You to redneck For This Useful Post:
23baseball3 (06-06-2014), AbramWagner (05-09-2015), aerohead (06-06-2014), BabyDiesel (03-10-2015), BamZipPow (06-07-2014), bikeprof (05-18-2015), bondo (06-06-2014), California98Civic (06-06-2014), Cd (07-05-2014), COcyclist (10-08-2014), Eastwood (06-07-2014), Ecky (01-17-2015), elhigh (06-06-2014), Fat Charlie (06-06-2014), Frank Lee (06-07-2014), Gasoline Fumes (06-07-2014), HHOTDI (06-07-2014), Insight for life (06-07-2014), mcrews (06-06-2014), MetroMPG (06-06-2014), mikeyjd (06-06-2014), NickelB NL (01-19-2015), planetaire (06-02-2015), pletby (10-01-2014), slowmover (06-08-2014), SoobieOut (06-06-2014), Sven7 (06-23-2014), The donkey CRX (06-07-2014), UltArc (06-06-2014), Weather Spotter (06-28-2014), whatmaycome14 (07-06-2014)
Old 06-06-2014, 02:19 PM   #77 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Wow.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
redneck (06-07-2014)
Old 06-06-2014, 02:35 PM   #78 (permalink)
Wow indeed. Nice work!
The Following 2 Users Say Thank You to Daox For This Useful Post:
mcrews (06-06-2014), redneck (06-07-2014)
Old 06-06-2014, 05:21 PM   #79 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Wicked.
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
The Following User Says Thank You to UltArc For This Useful Post:
Old 06-06-2014, 05:34 PM   #80 (permalink)
mods
Add me to the WOW list!
One thing comes to mind,and it's because of my experience with the CRX at Bonneville.
Where the nose pan angles down is an area which is really significant.Even with the full belly pan,we still don't want to encourage any air to go under the car.
Ford used an active air dam on it's Probe-IV,which lowered on the highway to block off this flow.
I made a flexible chin spoiler from polyurethane floor pad from BIG-LOTS which deforms at curbs.It slices the airflow off from the belly pan.And without the pan,I'm still seeing some of my highest-ever mpg.
I think you'd like it if you did it.
Fabulous project! It will be hard to wait on your new mpg numbers.
The Following 7 Users Say Thank You to aerohead For This Useful Post:
BamZipPow (06-07-2014), ECONORAM (02-12-2015), HHOTDI (06-07-2014), mikeyjd (06-11-2014), MobilOne (05-30-2015), redneck (06-07-2014), whatmaycome14 (07-06-2014)
