04-23-2017, 05:00 PM
#711 (permalink)
Permanent Lurker
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k) 90 day: 47.08 mpg (US)
Or call Arcimoto people? They have a drivetrain OK. All they need is a real body. (I know itīs a tricycle, but its FWD so it doesnīt matter, and their "powerpack" seems to be quite compact, so it could fit in.
04-23-2017, 06:31 PM
#712 (permalink)
I'd say it's the other way 'round.
I've inspected and sat in the SRK and the 'airframe' is good, but the 'powerplant' is suspect. Twin 20hp motors (which is good) but they have replaced the geartrain vendor and are reporting 'really good results' with the current one.
If I get one and have any problems, as soon as it's out of warranty I'd drop in the 98lb 68hp axle from Lexus LX400h. Even though it's an open diff.
Else the 2017 Toyota RAV4 has a twin motor, electronic differential like the Arcimoto. You're more likely to shake the parts you need out of Toyota (or eBay).
04-24-2017, 12:23 PM
#713 (permalink)
Thanks for the feedback. I am probably going to get the Quonset hut pretty soon - which hinges on my brother building an addition on his garage and entry porch (which I will probably be helping him with).
I am interested to hear the details about the A2 tunnel. That is certainly a LOT closer to me.
Another possibility is to build a more accurate 1/4 scale model on my CNC. The challenge there is redoing the "slices" in CAD, based on the exact thickness of the foam I would use. I would possibly be able to test this at the MIT Wright Brothers 2X atmosphere wind tunnel, which is very close and convenient.
04-24-2017, 02:27 PM
#714 (permalink)
Well... Thanks for mentioning the Quonset hut. I have relevant experience.
When I was in the one-time Republic of South Vietnam, I hung out with Catholic and Buddhist relief NGOs (I was a civil affairs officer). Oh, and I lived next door to the Quakers.
The Catholic school in Long An province made a library from a Quonset hut, and they put it on a stem wall about 2ft high. It made a world of difference in the interior space. Then I came back to The World and was making geodesic domes on stem walls.
Also, I designed and built a garage for a retired Colonel in Cedar Grove, OR; the building department there gave me a detail for the slab and [post and beam] wall. Sink 4x4 or 6x6 posts for the [stem] walls. Nail form boards to the inside and outside of the posts. Pour the slab and stem wall monolithically, and strip the forms.
The only thing I would do additionally is paint the posts with epoxy just before you pour the concrete, to prevent water penetration. Other than that it worked great.
04-25-2017, 01:00 PM
#715 (permalink)
I am going to use helical anchors, like this:
They are cheap, and they work well in my soil.
04-25-2017, 08:20 PM
#716 (permalink)
Dirt floor then? roto-till in some ox blood and tamp it level.
04-25-2017, 10:08 PM
#717 (permalink)
Since it's not meant for off-roading, what would be wrong with an open diff?
04-26-2017, 12:48 AM
#718 (permalink)
Black ice.
04-26-2017, 10:58 AM
#719 (permalink)
If wind tunnel time is pricey look around for someone with a camera drone. You could do tuft testing on a lonely road with the drone.
04-26-2017, 12:06 PM
#720 (permalink)
Black ice.
Then the hub-motors arrangement with torque vectoring does sound better. Either this or a locker diff.
