Old 07-24-2020, 09:47 PM   #91 (permalink)
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
California98Civic,
I will try to post progress as I go. Observe away, but don't expect any metal shaping as good as the photos you shared.
Aerohead,
I will have to look up that book, I don't have any such books so it would be nice to have a reference.
Freebeard,
I don't yet have a nylon hammer, I will have to add that to the list to keep an eye out for.
Everyone,
Made some more slow but steady progress, I could obviously cut things apart faster but I am more concerned about how things are going to go back together and am letting that guide how things come apart. Which just takes longer.
I managed to get the roof split away from the side panels, made the cuts right where the first roof ridges start. Got the inner roof bracing removed, will shorten and reinstall it. I removed the lower quarter panels, I don't need them with my current plans for a custom wraparound bumper. I have a plan now for how to do the remaining cuts.
Once it is cut apart I will be pulling it in at a 1 in 10 slope, which is an additional 5.71 degrees, putting the sides at about 6.15 degrees after the 6 to 8 inch compound curve transition.
Edit: I was actually quite surprised during the disassembly how much adhesive/caulk was used to seal and hold the vehicle together. I plan to use welding on as many of the surfaces as I can on reassembly. I got a tube of some good 3M panel adhesive for the surfaces for which that is impractical.
ID:	28807   Click image for larger version
The Following 3 Users Say Thank You to aardvarcus For This Useful Post:
aerohead (07-29-2020), California98Civic (07-25-2020), freebeard (07-24-2020)
Old 07-29-2020, 10:16 AM   #92 (permalink)
adhesive
Originally Posted by aardvarcus View Post
California98Civic,
Aerohead,
Freebeard,
Everyone,
3M makes an automotive adhesive specifically for your type of application. It's only available, retail, through automotive refinishing supply outlets, and is over $20 a tube. Body shops use it to bond aerodynamic kit parts. If you can stomach the price, you'll be delighted in its performance.
Also, if the chassis was electro-plated with zinc, for corrosion protection, be very careful to ventilate your welding area. The vapors won't hurt spot-welding robots on an assembly line, but they will kill you!
aardvarcus (08-01-2020)
Old 07-31-2020, 09:41 PM   #93 (permalink)
aardvarcus's Avatar
Had some time today to make some progress, I had previously gotten the side clearanced to bend in without binding, today I was able to make final adjustments, flange the roof seam, mark and clean the weld areas, and begin welding the side back to the floor and roof. I still have lots of little detailed areas to address via welding and forming, but overall good progress.
ID:	28839   Click image for larger version
ID:	28840   Click image for larger version
The Following 2 Users Say Thank You to aardvarcus For This Useful Post:
aerohead (08-05-2020), California98Civic (08-02-2020)
Old 07-31-2020, 10:50 PM   #94 (permalink)
Once you've unlocked that achievement, what do you plan for the rear wheels and underbody. That could be ±25% on the improvement.
Two wrongs don't make a right, but three lefts do.
Old 08-01-2020, 08:43 PM   #95 (permalink)
aardvarcus's Avatar
Current plan is for the rear bumper to be positioned behind the upper part of the rear tires, also fore and after conveyor belt tire spats on all 4 wheels and tires. I have stock stainless wheel covers I plan to mount on the wheels with dzus fasteners, but wheel well covers arent out of the question. Current plans for the under body is a 100% belly pan made out of bent and welded aluminum, except under the exhaust.
aerohead (08-05-2020), freebeard (08-01-2020)
Old 08-02-2020, 02:34 PM   #96 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Looking good, hey! It is gonna catch a few eyes on the freeway. Start a few conversations at lights and in parkinglots.
aardvarcus (08-09-2020)
Old 08-02-2020, 03:48 PM   #97 (permalink)
Underlined needs a pic. Here's how I'd do conveyer belting spats:
U-shape belting and U-shape metal bracket fastened only on their long edges
Moon disks?
aardvarcus (08-09-2020), aerohead (08-05-2020)
Old 08-05-2020, 10:37 AM   #98 (permalink)
Air would find those to be plenty tasty!
Old 10-24-2020, 10:08 PM   #99 (permalink)
aardvarcus's Avatar
It's been a few months, a few small odds and ends have gotten done since I last posted on reinforcing and welding up the drivers side. Many other things have taken precedence over the suburban project so it has been on a bit of a back burner, but I had a basically full day to work on it. I was able to get the other side severed, binding spots clearanced, the side angled over, and tack welded in place. Attached are some photos of the progress.
Next thing on the agenda is final welding of the various parts, making patch panels, building outer fender wells, and then building a new hatch/door for the back.
ID:	29424   Click image for larger version
ID:	29425   Click image for larger version
aerohead (10-28-2020), freebeard (10-24-2020)
Old 10-24-2020, 10:11 PM   #100 (permalink)
Did the second side go faster than the first? Usually does.
aardvarcus (10-24-2020)
suburban diesel 4x4 gmc
