Old 01-30-2010, 05:24 PM   #51 (permalink)
The PRC.
Hi,
I'm interested in your intake mods - have they generated more power or FE? I don't have the same car but the same engine (130 hp + 6sp ?) in a smaller car.
Some with a vRS claim that fitting the intake from a PD150 (e.g SEAT Cupra) makes their car better in terms of HP and FE, but never seem to have firm figures.
How is your V6 intake doing ?
Cheers
A.
Old 01-30-2010, 06:51 PM   #52 (permalink)
Bio Deezler (sold) - '03 Volkswagen Jetta GLS TDI
90 day: 50.78 mpg (US)
The Beast. - '03 GMC Sierra 2500HD SLT
90 day: 12.86 mpg (US)
COcycler, thanks. I am impressed with your pump-duese fuel economy! I'm guessing you are a patient driver. You've got some nice mods, too.
Arragonis, the full intake mod definitely helped power a bit. Not much, mind you, as my ALH engine came with the little VNT15 turbo and 90 HP rating. Fuel economy improvement was not measurable (had a lot of other changes going on at the same time though), but there's no way reducing intake restriction on a turbo diesel is going to hurt! The only parts of the intake tract that is from a V6 are the mass airflow sensor housing and upper airbox lid though.
The Following User Says Thank You to Deezler For This Useful Post:
Arragonis (07-01-2010)
Old 02-01-2010, 07:57 PM   #53 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
I've got a question for you. What angles are you running your vortex generators at? I noticed your video showed beautifully smooth airflow, but I'm getting rather large counter-rotating vorticies on my rear window.
In Reason we Trust
Old 02-02-2010, 04:14 PM   #54 (permalink)
Hmm. That's hard to answer. I started by trying to follow the recommendations from vortekz : Vortekz.com: Vortekz Generators
However I also wanted to follow my roof to glass line evenly for aesthetic reasons. Since its not exactly straight, I had to ad-lib a little bit. I think they do taper from about 15 degrees in the middle of the car to still holding 5 degrees by the outer edges.
Old 03-06-2010, 05:10 PM   #55 (permalink)
Not much changing these days. Trying to keep my coolant/oil pan pre-heater use up, but it's easy to forget... Enjoying the spring-like weather and now it's time to think about new aero-mods for the year!
In any case, new vehicle milestone; first 800+ mile tank. Not my highest mpg tank though, so clearly I could have been going this far before, too.
My winter B20 pump:
Old 03-06-2010, 05:43 PM   #56 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 53.2 mpg (US)
Deezler, Congratulations on your 800 mile tank. Have you done the Ventectomy mod? (gives VW diesel owners almost an extra 2 gallons capacity)
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 03-07-2010, 10:11 AM   #57 (permalink)
COcyc,
Yes, definitely had to do the ventectomy. I think the stock tank rating is, what, 14.5 gallons, so you can see from my 15.3 gal fill-up that I was depending on it for the range.
Having over 16 gallon capacity on a vehicle that gets over 50 mpg = fantastic range. I can drive from Michigan to Florida on one tank... or across the entire country only stopping twice...
Old 02-14-2012, 06:20 PM   #58 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
any updates?
Past Present Future?
Old 02-14-2012, 06:55 PM   #59 (permalink)
Only bad ones (eco-modding wise). I completely changed direction with my car and life. My wife and I decided to take action to get our own farm and (mostly) off-grid home going right away, after finding a terrific deal on a vacant parcel of land I have been watching for years now. Bank finally wanted to just get rid of it and I was lucky enough to qualify for the new financing.
But as per the car.
I was sick of the rough ride and road scraping. It was pretty awesome while it lasted, and I have no regrets, but I was done with "low".
So instead of 2.5" lower vs. stock ride height, it's now 1.7" taller. About 4" higher than I used to drive around. That was quite a shock.
My new direction for the car was a goal of UTILITY. This diesel engine has such a tasty amount of torque and efficiency, that it's quite palatable to accept some minor fuel economy losses in order to open a whole new range of capability.
Once I get some bulk free time (ha!) I plan to build a front light setup just like this:
And a trailer hitch is quickly moving up the priority list of next mods. My buddy has a 5x8 utility trailer that I can use. That's going to ruin my rear diffuser mod.... and my other underpanel came off last winter on a 1000 mile snowboarding trip (didn't fly off, but I had to make a roadside rip-out).
Between the vehicle lift, oversized snow tires, worse aero, no engine heater use (new house has no garage) and less highway commuting, I am pulling only around 44 mpgs these days. Far below my old road trip peaks of 55+ and daily use of ~50... that feels like a long time ago.
All my money and research right now has led me to the purchase of this type of tractor:
So that I can get started clearing my new parcel of overgrown land. Trying to get a permaculture garden going asap!
I still want to add some significant aero-mods to the TDI, but the priority is quite low, to be honest. Maybe someday...
The Following 3 Users Say Thank You to Deezler For This Useful Post:
alohaspirit (02-15-2012), Cd (12-01-2014), COcyclist (02-15-2012)
Old 02-14-2012, 11:58 PM   #60 (permalink)
Originally Posted by Deezler View Post
My new direction for the car was a goal of UTILITY. This diesel engine has such a tasty amount of torque and efficiency, that it's quite palatable to accept some minor fuel economy losses in order to open a whole new range of capability....
Thats the ballance us non-commuters are always trying to find.
I say don't worry about ride hight.
My engineer friend commutes in a 2001 sunfire. He put new struts on all 4 wheels and raised the car nearly 2 inchs. He said the effect on fuel milage is slightly more than only effecting the rounding error but still well with in the standard deviation.
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1499 12-22-2019 07:24 PM
Daox's 2003 Matrix Build Thread Daox EcoModding Central 76 01-11-2016 01:47 PM
Build Thread: 1996 Ranger 2.3L 5spd 2WD XVTer EcoModding Central 18 05-27-2012 08:39 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
