08-03-2014, 10:42 PM
#311 (permalink)
Master Ecomadman
The weight limit is for braking in a safe distance, not going. I suppose the trailer wheel could have a brake. An origami trailer-tail, or, if you want to fold it up like a tent, maybe fabric.
- Tony
08-04-2014, 11:30 AM
#312 (permalink)
08-05-2014, 04:14 AM
#313 (permalink)
Wonder what one could do with this concept applied to the template ...
Foldable setup, I would try to have roof and sides hinged to the rear door with the quarter circles angles meant to lock it in place when unfolded.
What's the target length of the setup ?
08-12-2014, 12:05 PM
#314 (permalink)
Wiki Mod
The dreaded happened last night.
The tail came off. It was easy on the top but the lower end we had to undo the u bolts and remove the tail from the draw bar then heat the draw bar up to glowing orange to remove.
The car looks short and odd.
Now I get to plan version 2.0 !!!!!
The Following User Says Thank You to Weather Spotter For This Useful Post:
08-12-2014, 12:18 PM
#315 (permalink)
RIP, boat tail.
08-12-2014, 12:22 PM
#316 (permalink)
Wiki Mod
I also took of the back end belly pan off and that and the tail were hooked together.
08-16-2014, 12:18 PM
#317 (permalink)
Wiki Mod
pics
The Following 3 Users Say Thank You to Weather Spotter For This Useful Post:
08-16-2014, 01:32 PM
#318 (permalink)
Only a boattail, but one more is gone...
08-16-2014, 01:41 PM
#319 (permalink)
Wiki Mod
I know, its sad. its harder to find my car in the lot now
I am planning how to make tail 2.0...... I want to keep leaks out so I might make it attached to the OEM tailgate, It could also have a bottom section that could be raised up for towing access. Ideas are floating around and I have not given up. After 3.5 years the tail needed major rework so its time to take it off and plan another one
08-17-2014, 12:28 PM
#320 (permalink)
No pain, no gain.
Ideas? Skegs that pivot just behind the rear wheel and have a skateboard wheel at the tip that normally float 3 1/2" off the ground but lift to a reasonable departure angle on impact?
My only boattail so far:
For the final v1.0, I will use Polymetal or equivalent. Rolled simple curves with flanged curved edges, riveted internally. The result will be sort of pseudo-compound curves and a rigid monocoque that should need minimal internal bracing, likely a trunk floor.
