Old 08-03-2014, 10:42 PM   #311 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
The weight limit is for braking in a safe distance, not going. I suppose the trailer wheel could have a brake. An origami trailer-tail, or, if you want to fold it up like a tent, maybe fabric.
- Tony
Old 08-04-2014, 11:30 AM   #312 (permalink)
http://psipunk.com/sunred-solar-moto...-solar-panels/
Old 08-05-2014, 04:14 AM   #313 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
Wonder what one could do with this concept applied to the template ...
Foldable setup, I would try to have roof and sides hinged to the rear door with the quarter circles angles meant to lock it in place when unfolded.
What's the target length of the setup ?
Old 08-12-2014, 12:05 PM   #314 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
The dreaded happened last night.
The tail came off. It was easy on the top but the lower end we had to undo the u bolts and remove the tail from the draw bar then heat the draw bar up to glowing orange to remove.
The car looks short and odd.
Now I get to plan version 2.0 !!!!!
The Following User Says Thank You to Weather Spotter For This Useful Post:
aerohead (08-12-2014)
Old 08-12-2014, 12:18 PM   #315 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
RIP, boat tail.
Old 08-12-2014, 12:22 PM   #316 (permalink)
Wiki Mod
I also took of the back end belly pan off and that and the tail were hooked together.
Old 08-16-2014, 12:18 PM   #317 (permalink)
Wiki Mod
pics
here are some pics
last ones i took with tail on:
pics of the attachment points on top and seal between car and tail (leak points):
taking off the belly pan:
pan after 2 years:
tail is off:
rip tail version 1:
with all the old stickers and old mpg stats (43 mpg? thats old):
how the car looks now:
The Following 3 Users Say Thank You to Weather Spotter For This Useful Post:
aerohead (08-16-2014), BamZipPow (08-16-2014), ECONORAM (08-18-2014)
Old 08-16-2014, 01:32 PM   #318 (permalink)
Only a boattail, but one more is gone...
Old 08-16-2014, 01:41 PM   #319 (permalink)
Wiki Mod
I know, its sad. its harder to find my car in the lot now
I am planning how to make tail 2.0...... I want to keep leaks out so I might make it attached to the OEM tailgate, It could also have a bottom section that could be raised up for towing access. Ideas are floating around and I have not given up. After 3.5 years the tail needed major rework so its time to take it off and plan another one
Old 08-17-2014, 12:28 PM   #320 (permalink)
No pain, no gain.
Ideas? Skegs that pivot just behind the rear wheel and have a skateboard wheel at the tip that normally float 3 1/2" off the ground but lift to a reasonable departure angle on impact?
My only boattail so far:
For the final v1.0, I will use Polymetal or equivalent. Rolled simple curves with flanged curved edges, riveted internally. The result will be sort of pseudo-compound curves and a rigid monocoque that should need minimal internal bracing, likely a trunk floor.
BOAT TAIL Drag Reduction Estimates aerohead Aerodynamics 12 01-30-2016 04:08 PM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 9 01-19-2014 09:59 AM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph MetroMPG Aerodynamics 500 05-10-2012 10:30 PM
collapsible curved folding 10mm coroplast boat tail miket Aerodynamics 5 08-12-2010 01:58 PM
Subaru Outback Prototype Boat Tail Test Results brucey Aerodynamics 10 10-02-2009 05:03 PM
