07-21-2015, 09:55 AM
#11 (permalink)
hypermiler
Welcome Aerosonoma. I for one would like to see some pictures of your truck mod.
UltArc, you're a mathematical wizard. You and Cowmeat make me want a 2000 Insight so bad. I'm so jealous.
"I may be going to Hell in a Bucket, but at least I'm enjoying the ride." 🚗
The Following User Says Thank You to snakester For This Useful Post:
07-21-2015, 10:32 AM
#12 (permalink)
Not bad for a machine
welcome buddy! we have the same drivetrain.
07-21-2015, 01:10 PM
#14 (permalink)
Originally Posted by UltArc
I would advise AGAINST that indy thing. IF it ever comes to fruition, 25k is a low number. After you buy the kit, you get to buy all the internals, and then assemble. Ran some quick numbers, just did a screen shot. 3k is a bit high for an Insight if you sold your truck, but wanted to make sure I wasn't being too biased on the G1. I know the fun of taking an inefficient vehicle, and making it fuel efficient, so that journey is always a blast! The only reason I even say otherwise, is that very rarely do my modifications pay for themselves. You said 140 miles per day, I inferred 5 days a week. I can send you the Excel sheet, but just a quick write up on my phone.
*Note the Insight calculations are for 50 MPG, not the easily attainable 60-70, or modified 70+. But I'd rather see you mod the truck!
Your calcs are based on 20mpg for the Sonoma. OP indicated he currently averages 28mpg w/o hypermiling (and no mods? That's not clear to me).
At 28mpg, his 2-year fuel cost is only $8400 based on your assumptions.
At his 40mpg goal, his 2-year fuel cost is only $5880 based on your assumptions.
The auto doesn't help, but I'd like to see how he does with the truck. I was fond of my old '98 S10 (2.2L/5-spd); they are good little trucks.
aerosonoma, do you have pics of your aerocap?
07-21-2015, 06:51 PM
#15 (permalink)
Hydrogen > EV
Good call Darcane! It was late last night, my apologies. Made a few adjustments
07-21-2015, 07:30 PM
#16 (permalink)
what's the. cd of the pickup?
07-24-2015, 12:16 AM
#17 (permalink)
Lean Burn Cruiser!
The Cd of his 96 S10 is 0.42, straight from S10forums.com
Extensive aero mods will be the bee's knees to this build.
07-26-2015, 10:18 AM
#18 (permalink)
Alright well thank you all for your replies!So based I have done some calculations on my own and the reason I want to go with the Sonoma build is I bought it for 900 dollars, it has no rust, and I just rebuilt the engine and transmission for it. I have probably 2500 total including the price of the truck. I would rather buy a cruise eco or a tdi but if 40 or even 35 mpg is possible it will never be with it to buy a newer car if you consider car payment, higher insurance, cost of diesel, higher cost of parts, etc. S10 parts are cheap and they are easy to work on. So, I will be sticking with the Sonoma build. I should be finishing by aero cap todayactually. I'll post pictures later in the aerodynamic threads. I did it a little different than what I've seen so I'm hoping for some constructive criticism. Haha also is there any software out there to help me determine the CD after I have made my mods? I know there are lots of cfd programsb it how about some suggestions?
07-26-2015, 04:31 PM
#19 (permalink)
stay in the torque converter above 32MPH.
throttle at 80% LOD or 58 TPS.
stay in neutral as much as possible.
we do not have DFCO so hit the brakes in neutral if you need to slow down.
I have .38 cd and I'm willing to bet AC on is better than windows down but mines not working.
hopefully you have a few tips for me.
07-26-2015, 11:56 PM
#20 (permalink)
Not banned yet
Blue - '03 Chevy S-10, LS
Originally Posted by dirtydave
......willing to bet AC on is better than windows down.......
i know this is still in debate but in the jetta, using UG, i see my FE go down a lot using AC. i normally don't use it and hit close to 60. using, low 50's.
driving wifes Traverse, just pulled into SD and is a lot cooler to me so i turned off the AC. watching the graph, i can see the drain AC has while using. i will try to not use it all the way to Canada.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
