04-30-2018, 12:43 PM
#3211 (permalink)
PaulH
thingstodo, did you get the updated software I sent a couple weeks ago (april 11)? It's the updated code, but with the through-hole board incorporated into it.
Yes I would very much like to do nissan leaf board. I have a leaf board, and have been figuring out the pinouts, and am almost done. I could get a board working pretty quickly. I just need to do a prototype. I'll do that this month. Well, next month. it's the 30th haha.
04-30-2018, 12:59 PM
#3212 (permalink)
I read the email ... but didn't download or install the firmware or source code
I will do that! Likely tomorrow.
Still a bit confused by why the controller did not use the old settings to try starting the Polaris motor though. All I should need to do is power up and hit the throttle ... right? The encoder pulses rise to 3.9 VDC and fall to 0.2VDC .. that should be good for a 5V input?
I didn't get the logs loaded last night. Will get that part done tonight - hopefully
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
The Following User Says Thank You to thingstodo For This Useful Post:
04-30-2018, 01:02 PM
#3213 (permalink)
PaulH
Could you do:
stream-poscnt 1
data-stream-period 100
then slowly turn the motor shaft by hand to see if you get smoothly changing position. That will show that the encoder is working properly.
The Following User Says Thank You to MPaulHolmes For This Useful Post:
04-30-2018, 01:06 PM
#3214 (permalink)
Could you do:
stream-poscnt 1
I can do that! I could not remember which variable to turn on to check on the encoder. The mechanical rpm seems to be a random number generator when the output of the controller is not on
That will likely happen tonight as well
04-30-2018, 03:27 PM
#3215 (permalink)
That would be great Paul, I will defiantly buy one if/when you produce them. here in the UK the breakers/dismantlers only sell leaf motor complete
If in the future you can hack the charging and the DC/DC convertor you will be onto a real winner
04-30-2018, 11:52 PM
#3216 (permalink)
Results for April 28, 29, 30
I attached the raw logs. I typed a few notes while hyperterm was capturing. see if they make sense. I'll go through them a bit more tomorrow night, but I found out I have training tomorrow night so I only have about an hour.
Didn't get the firmware loaded in.
stream-poscnt 1 is a not a valid command, so I guess I need to load the firmware to get that command.
At the end of the April 30 log I rotated the wheels by hand. First back and forth several times. Lastly in the same direction for several seconds and it looks like I seem to have gotten a consistent direction and speed.
I think the encoder signal is coming through OK.
I still can't figure out why the controller is not putting out current when I move the throttle signal. Weird.
The base config from Andrew's siemens AC motor is in the logs in a couple of places. It should at least TRY to rotate! SIGH!
Reason: Attach logs ;)
05-01-2018, 06:48 PM
#3217 (permalink)
Hmmm I might be having a problem along the same lines as thingstodo
Could you do:
stream-poscnt 1
I tried this but still only saw 0s. I was able to get my hands on a scope, so I hooked it up to the resolver and then encoder outputs, captures of which I've attached. From what I can tell, the encoder output seems to be fine (90deg shift between QEA-QEB, 0-5V, Index pulse every 1/4 turn, etc).
However, this was done without current sensors or throttle connected, so there were faults triggered. Are these faults preventing the "poscnt" variable from being updated/streamed properly? Or can there be another issue at play here?
The Following User Says Thank You to wootwootman For This Useful Post:
05-01-2018, 10:33 PM
#3218 (permalink)
PaulH
If the motor type is set to 1 (induction motor), streaming poscnt won't do any good. if the motor type is like 3 (leaf nissan leaf), then stream-poscnt should work. What motor do you have? I am sick today and can't think straight, and am still trying to help my job transition smoothly to being without me, so I won't be much use for a couple more days.
05-02-2018, 01:43 PM
#3219 (permalink)
I verified that it's a 2013 Nissan Leaf motor (EM57), so it should be compatible. As far as the motor-type, I haven't looked at the config settings in a while so I'll take another look at them this evening after work.
Going over the schematic again, I don't think I populated C8,C9, or C10 (the LPF caps before the I/QEA/QEB inputs on the PIC). This would leave the signals basically unfiltered, but since I'm not running the motor or any voltage higher than board level (24VDC), I don't think this is the issue.
I'll be sure to populate them before I start powering the motor, just gotta choose the right values.
512ticks/rev * 10,000rpm (max EM57 rpm) = 5.12Mticks/min ~= 85kticks/sec
Since the encoder signals are square waves (which i believe need fast rise/fall times?), I'll raise the cutoff frequency like....four times? So 340kHz. Since there's already a 1k resistor, that leaves me with ~470pF for a cap value. Someone please correct me if I'm wrong
05-02-2018, 01:58 PM
#3220 (permalink)
PaulH
I never use caps there but it wouldnt hurt if they were sufficiently small capacitance. The chip has a noise rejection feature built into the QEI module.
