Old 05-10-2017, 12:43 PM   #1 (permalink)
tire sizing questions for a truck
Before I ask, yes I have done some reading/searching. Still have questions
The stock tire size for my 01 2wd s10 is 205/75/15. Everything I've looked at was talking more about cars than trucks. So my question is, would running a 205/70/15(5% shorter sidewall) be a benefit or not?
Old 05-10-2017, 01:32 PM   #2 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Your speedo will be out by that much. And you'll be revving that much higher, therefore wasting that much more gas. If you went the other way, you might have some FE gains.
Your cheapest bet is to pump the tires up a good % over recommended, within the max pressure printed on the sidewall of your tires. But you'll probably gain the most by switching to a Low Rolling Resistance tire, if they make them for trucks in your size.
The Following User Says Thank You to Stubby79 For This Useful Post:
canadian_yeti (05-11-2017)
Old 05-10-2017, 02:35 PM   #3 (permalink)
Don't put smaller tires on anything unless you are going to also lower the drive axle ratio.
When the first gen prius came out they advertised that it had smaller tires for better fuel economy ever since then people were convinced that putting smaller tires on their vehicle would help them too.. But the transmission gearing in the prius was designed around this smaller tire.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
canadian_yeti (05-11-2017), Fingie (05-10-2017)
Old 05-10-2017, 07:10 PM   #4 (permalink)
Dark Egg - '12 VW Touraeg
Smaller wheels often help, the craze for 20, then 22, then 24" wheels was terrible for performance in almost all aspects, economy, acceleration, ride, braking. Maybe handling could be benefited but probably not because they would losen up the rest of the suspension so the ride wouldn't kill you. Usually a low profile tire with a big diameter wheel will weigh more than a high profile tire and small diameter wheel that has the same overall outside diameter.
Smaller overall could help but as pointed out will raise rpm at equal speed. Smaller would lower the truck and reduce frontal aera. Some 2wd guys will run the smaller tire on just the front lowering the front end. Overall that wouldn't change the frontal aera and a lower airdam would have the same effect.
Overall I doubt the difference in a 205/75 vs a 205/70 would even be detectible. It looks like the 70 series less per tire and has low rolling resistance versions available which could be noticible.
The Following User Says Thank You to Hersbird For This Useful Post:
Old 05-11-2017, 12:23 PM   #5 (permalink)
i definitely will be lowering my axle gear ratio. my truck is currently 4.10 gears with drum brakes. i plan on going down to a 3.73 or 3.42 ratio and disc brakes using a rear axle from a blazer/jimmy. direct bolt in, lower ratio, better braking. win win. thanks guys
Old 05-11-2017, 02:35 PM   #6 (permalink)
darcane's Avatar
Does this matter?
When the S10 was designed, it shared more parts from the cars of the time than the trucks... It's basically the GM G-body with the largest trunk.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 05-11-2017, 04:08 PM   #7 (permalink)
Originally Posted by darcane View Post
Does this matter?
very true lol. never even considered that. although i did think last night that the stock tire size is the exact same size as whats stock on my grandpa's '05 buick century, so my truck falls more into the car category.
Old 05-11-2017, 09:14 PM   #8 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I would move up to a 225 or 235 section width. The more air a tire can hold the less the tire will deform.
Old 05-12-2017, 08:08 AM   #9 (permalink)
Tire Geek
CapriRacer's Avatar
First, read my webpages on the subject:
Barry's Tire Tech - Fuel Economy and Rolling Resistance
Barry's Tire Tech - Fuel Economy and Rolling Resistance2
Short version: Tire sizing plays a small role in rolling resistance. Better to spend time in the selection process (meaning make and model of tire).
As a general rule, larger tires are better for RR than smaller tires - BUT - see the statement above. Also, there are other tire properties where going larger is an advantage.
In your case, it is a bad idea to go from a 75 series to a 70 series. That's going smaller.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
Old 05-12-2017, 12:41 PM   #10 (permalink)
a wider section width would mean that much more rubber touching the road. more surface area means more friction and more material to push. correct me if im wrong, but i would need to have a really good LRR tire set to max pressure just to break even compared to the same parameters for a 205 tire
