Old 01-16-2014, 10:41 AM   #11 (permalink)
Here is that last idea expressed on a Toyota Supra (different year than Wolf_TM's Supra).
Toyota Supra - Type Cars
It appears to be a corner scoop, yet vented like an "air curtain" to perhaps prevent excessive pressure build up while turning into corners.
Yes, the Fast & Furious Supra uses the Bomex front bumper.
Is usually the zone in front of the front wheel a low pressure one or not?
Thanks
Wolf_Tm250 [Silat-Kali] - Parma (Italy)
Suzuki Gsx-R 600 naked
Toyota Rav4.1 Torsen: 240hp 3SGTE swap in progress
Toyota Celica Gt-Four ST205 Snowy White [2.34kg/hp - 600Nm@4950rpm]
EFI University Advanced Tuner
Old 01-16-2014, 11:34 AM   #12 (permalink)
What does the research I suggested you do reveal?
Please post your results.
Note: I think you are on the right track in not assuming all vehicle front ends are pressurized exactly the same.
Old 01-16-2014, 12:04 PM   #13 (permalink)
CFECO
CFECO's Avatar
X-Car - '11 Homemade 2+2
Velbly1 - '17 Toyota Camery XSE
90 day: 29 mpg (US)
Velbly2 - '13 Toyota Tundra
90 day: 18.03 mpg (US)
Porsche moves the radiators to the front for airflow and car balance, if I had a Free Hand in this case I'd try the Porsche plan. Put NACA ducts in front of the rear wheels, move the radiators there and vent the air into the Low Pressure area at the center rear of the car. Then fill in and round the openings at the front. For low drag, the best are always "Smoooooth".
Old 01-16-2014, 12:25 PM   #14 (permalink)
TheCav - '04 Chevy Cavalier LS
Why would you want to slam air into a vent only to slam it into the front of your rotating tire? That makes absolutly no sense.
http://www.barrett-jackson.com/stagi...nt_3-4_Web.jpg
Where is the air vent in the above photo? Why would you do it if Nascar is not?
Old 01-16-2014, 12:55 PM   #15 (permalink)
It's a Porsche thing, on the water cooled 911's it's radiators, and on the air-cooled / oil/cooled 911's it's oil coolers dumping hot air on to the tires.
They build long lived cars and have won more races than any other make, must be doing something right, right?
Fighting Aerodynamic issues - A car thread... - ADVrider
I'm not sure we want to get into why a 200 mph race car is different and compare it to a street car which might get stuck in traffic.
That's a big subject.
More P-car photos:
Boxster
http://www.ggoodwin.net/2010/02/fron...-clean-up.html
Appears to be a wheel well liner.
The Panamera Design: Porsche throughout as it slips through the air
http://www.eurocarnews.com/54/0/217/...h-the-air.html
Old 01-16-2014, 01:22 PM   #16 (permalink)
^ I know this. I am talking about why the OP wants to redirect the air to his tires for no reason. He stated he will not be using it for any reason other than "attempting" to move it to a lower pressure area or trying to make a nice looking air vent that would actually do more harm than good for his aero.
At stated previously his best bet would be if he just smoothed and closed that area since he already stated:
I already catch the air for brakes with 2 duct beside the central intercooler
Old 01-16-2014, 01:34 PM   #17 (permalink)
The orginal post minus the images:
Hi All,
I need to move the engine and trans oil radiators away, so I'd like to know if these are points of *GOOD* pressure, assuming that I'll open an exit for the air in front of the wheel....................
PS: engine bay is separate from these vanes
Thank you.
I don't know why he wants to move anything, but your deduction may be true.
Still waiting to hear why he "needs" to move anything.
There is a difference between "need" and "want", maybe he meant "want"?
Old 01-16-2014, 02:16 PM   #18 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.92 mpg (US)
Post #9:
I need to increase the oil cooler size, removing the current one in front of the engine radiator.
Now the question is why the OP needs to increase the oil cooler size.
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 01-16-2014, 03:44 PM   #19 (permalink)
Originally Posted by jeff88 View Post
Post #9:
Thanks Jeff, I missed that somehow.
Maybe he added a turbo?
I looked it up, found this:
Cooling Components - 1993-98 Supra
Your stock oil cooler is a joke...its a tiny water-cooled device sandwiched between the oil filter and engine block.
I think most people just put aftermarket oil coolers in front of the stock radiator.
Oil Cooler Design Basics | How to add an oil cooler to a car
The best place to install an Oil Cooler is where it can receive a maximum amount of airflow, there by making the cooler as efficient as it can be.
So it already looks like the above image?
Don't the aftermarket ones have more fins and are more efficient?
Old 01-16-2014, 07:22 PM   #20 (permalink)
First of all, thanks all for your interest.
Seems that I need to add some informations.
I'm an engine builder and an efi ecu mapper.
My car is originally turbo, but later it was upgraded (power, cooling, etc) for mountain roads races.
From the logs during races, I see that oil temp has a wide range, that I'd like to narrow to activate specific ecu strategies.
And to reduce the temps' range, I absolutely need a bigger oil cooler.
Only place in front of the car to fit a bigger oil cooler is that vane under the headlight, but, obviously, i'm going to fit it there only if it's going to work well there... that is to say if i'm going to get good air pressure to feed it and low pressure behind it.
Thanks
The Following User Says Thank You to Wolf_Tm For This Useful Post:
ChazInMT (01-17-2014)
