10-13-2013, 06:29 PM
Alternator efficiency
Stumbled across this paper.
http://www.delcoremy.com/documents/h...ite-paper.aspx
Some intereting info, they indicate alternator efficiency is highest at 30-40% load and 2,000 - 2,500 rpm.
So maybe gearing down to 1:1 to engine and only activating alternator above say 1,800 rpm may improve overall efficiency.
The Following User Says Thank You to Tesla For This Useful Post:
10-13-2013, 07:10 PM
Lots of Questions
That is an interesting paper. It makes sense, just good to see it in one cohesive argument. Is there a way to determine the efficiency of your current alternator? I assume you can use a multimeter for the output, but how do you determine the amount of energy going into it?
I wonder if one wanted to have a more efficient alternator at a higher RPM, what would need to be done to make that work. More/heavier coils, lighter stator, domething else?
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
10-14-2013, 01:23 PM
I too much driving at 800 engine RPM, where the alternator is barely keeping up with the base electrical load. That's 25 MPH in fifth gear.
I'd have to put in a deep cycle battery if I re-ratioed the alternator. I'd be better off to do a full alternator delete with a switch for those long trips.
10-14-2013, 01:34 PM
Lots of Questions
Is there a way to do a pulley clutch? Like an A/C or hydraulic fan, but instead of the clutch forcing it off of the drive belt, it would just change over to a different size pully. Then at idle speeds, you can have 2:1 or 3:1and at higher speeds it will "clutch" to 1:1.
I guess that wouldn't really possible, since it would change the size of the belt needed to function properly.
Best EM Quotes:
10-14-2013, 01:40 PM
EcoModding Lurcher
Please note the alternator efficiency is at alternator RPM:
On all the cars and trucks I've seen the alternator sheave is much smaller than the crankshaft sheave, maybe 1/4 as big for old Chryslers.
-mort
10-14-2013, 02:15 PM
MC SBX - '95 Chevrolet Monte Carlo LS Last 3: 29.75 mpg (US)
not only the size of the belt, but also the angle at which it would run. serpentine belts don't like being run like that at all.
10-14-2013, 02:44 PM
Lots of Questions
Originally Posted by mort
It looks like, according to this graph, the alternator is not even producing current until around 1200 RPM. So what is happening during idle? Does the efficiency go down because it has to convert high voltage down to 14 volts?
Can anybody answer my original questions: how to determine your alternator's efficiency and how to make an alternator more efficient at a higher speed?
Best EM Quotes:
10-14-2013, 02:55 PM
#9 (permalink)
that 1200 might have been the first test point. assuming a 2:1 pulley ratio(which is pretty slow compared to a lot of the units i've had), that's a 600RPM idle. assuming 3:1(which is pretty realistic for my applications), that's 1800 alternator RPM, which is 40 amps or so.
10-14-2013, 04:36 PM
#10 (permalink)
Originally Posted by Frank Lee
Did you ever get a feel for the ballpark % efficiency gained from stripping all of those accessories out and running reduction ratios?
