Go Back   EcoModder Forum > AltModding > Saving@Home
Old 04-21-2011, 08:05 PM   #1 (permalink)
Bread rising - AKA Duh!
I like to make my own bread. Part of making it is letting it rise, which is best done somewhere warm - 80F or above. But I like to keep my house about 65, so there's always been this problem of how to find a warm enough spot for the bread. In front of the woodstove? Yeah, but it gets too hot on one side. In the oven on low? Even low's too warm.
So yesterday I had a thought, and I'm kicking myself for not having thought of it years ago. It's sunny, the car warms up pretty well, why don't I just put it out in the car? Why did it take me so long to figure this out?
Old 04-21-2011, 08:41 PM   #2 (permalink)
darcane's Avatar
Silverado - '03 Silverado W/T
Pickups
90 day: 18.7 mpg (US)
Ninja 650R - '06 Ninja 650R
90 day: 52.02 mpg (US)
Here's an idea:
My wife uses "warm socks" for helping to soothe achy muscles. It's just a thick sock filled with rice and tied off. Throw it in the microwave, zap it for a minute, and it stays warm for a while (20-30 minutes).
Make one (or something similar) zap it in the microwave for a bit. Leave it in the microwave and put your dough in the microwave. Shut the door. Don't turn on the microwave.
The warm sock should put off enough heat to keep things warm in a small enclosure (microwave) but not too much so it would cook the dough.
Mike
2003 Silverado:
Aero Mods
Old 04-22-2011, 01:34 AM   #3 (permalink)
A place I used was along side the water heater.
It is an insulated container but it was also somewhat warmer than the rest of the house being under the stairs and surrounded on all sides.
Peter.
Old 04-22-2011, 09:22 AM   #4 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
You can also try the top of the fridge, if you don't want to take your bread dough outside, the fridge is also right there in the kitchen, the compressor and coils tend to keep the fridge warm.
I personally like using a heavy ceramic bowl that holds the heat in and I warm it up by using water that is a bit to warm at first so the bowel gets warmed up while cooling the water, then tossing a towel over the top helps as well.
Old 04-22-2011, 09:51 AM   #5 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Ahhh, the smell of fresh bread every time you step into your vehicle.
Old 04-22-2011, 12:24 PM   #6 (permalink)
Thanks for the ideas, but the microwave's too small for the amount of dough I usually make, and the refrigerator's too efficient to put out much heat.
Old 04-23-2011, 03:09 PM   #7 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
I just drooled on my keyboard
The Wife made bread today - She wrapped it up in about 3 fleece blankets and put it on the window in the sun. The multiple layers help to spread the heat more evenly.
Piwoslaw's Peugeot 307sw modding thread
Old 08-02-2011, 11:49 PM   #8 (permalink)
pletby's Avatar
The Car... - '98 Contour GL
Team Ford
90 day: 30.94 mpg (US)
GS400E - '83 GS400E E
I like to put a medium mixing bowl that's full of boiling water on the bottom rack of the oven, then place the bread on the middle rack. Perfect temp.
Best trip: 42.6mpg
Best tank: 32.39mpg
Old 08-05-2011, 10:40 AM   #9 (permalink)
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
You could take it one step farther.
Raise the dough in the car, then BAKE it ON the ENGINE!
I haven't read it yet, but I hear the book MANIFOLD DESTINY is pretty good. All about cooking on your engine.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 08-05-2011, 11:46 AM   #10 (permalink)
60+ mpg at posted speeds
California98Civic's Avatar
Black and Green - '98 Civic DX Coupe
90 day: 64.83 mpg (US)
I like the car idea, but I generally put my dough on top of the fridge. Not only is it warmer--as was mentioned above--but even in a 65* home, the air higher up will be a little warmer. BTW, my heater broke last winter and I decided not to fix it, so it's chill in this house too.
Black and Green will be rebuilt over decades as parts die--until it becomes a different car. Goal is only 60-70 mpg at posted speeds. I'm not trying for highest possible mileage.
Calculators: standard deviation, Ohms Law, & drag HP losses.
