Old 01-30-2010, 05:24 PM   #51 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
Hi,
I'm interested in your intake mods - have they generated more power or FE? I don't have the same car but the same engine (130 hp + 6sp ?) in a smaller car.
Some with a vRS claim that fitting the intake from a PD150 (e.g SEAT Cupra) makes their car better in terms of HP and FE, but never seem to have firm figures.
How is your V6 intake doing ?
Cheers
A.
No longer here. Bye, and good luck to all.
Old 01-30-2010, 06:51 PM   #52 (permalink)
Bio Deezler - '03 Jetta GLS TDI
90 day: 50.78 mpg (US)
COcycler, thanks. I am impressed with your pump-duese fuel economy! I'm guessing you are a patient driver. You've got some nice mods, too.
Arragonis, the full intake mod definitely helped power a bit. Not much, mind you, as my ALH engine came with the little VNT15 turbo and 90 HP rating. Fuel economy improvement was not measurable (had a lot of other changes going on at the same time though), but there's no way reducing intake restriction on a turbo diesel is going to hurt! The only parts of the intake tract that is from a V6 are the mass airflow sensor housing and upper airbox lid though.
The Following User Says Thank You to Deezler For This Useful Post:
Arragonis (07-01-2010)
Old 02-01-2010, 07:57 PM   #53 (permalink)
AeroModder's Avatar
Darwin - '96 Aspire 4 door
Team Ford
90 day: 44.82 mpg (US)
I've got a question for you. What angles are you running your vortex generators at? I noticed your video showed beautifully smooth airflow, but I'm getting rather large counter-rotating vorticies on my rear window.
In Reason we Trust
Old 02-02-2010, 04:14 PM   #54 (permalink)
Hmm. That's hard to answer. I started by trying to follow the recommendations from vortekz : Vortekz.com: Vortekz Generators
However I also wanted to follow my roof to glass line evenly for aesthetic reasons. Since its not exactly straight, I had to ad-lib a little bit. I think they do taper from about 15 degrees in the middle of the car to still holding 5 degrees by the outer edges.
Old 03-06-2010, 05:10 PM   #55 (permalink)
Not much changing these days. Trying to keep my coolant/oil pan pre-heater use up, but it's easy to forget... Enjoying the spring-like weather and now it's time to think about new aero-mods for the year!
In any case, new vehicle milestone; first 800+ mile tank. Not my highest mpg tank though, so clearly I could have been going this far before, too.
My winter B20 pump:
Old 03-06-2010, 05:43 PM   #56 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 Golf
90 day: 51.68 mpg (US)
Deezler, Congratulations on your 800 mile tank. Have you done the Ventectomy mod? (gives VW diesel owners almost an extra 2 gallons capacity)
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
Old 03-07-2010, 10:11 AM   #57 (permalink)
COcyc,
Yes, definitely had to do the ventectomy. I think the stock tank rating is, what, 14.5 gallons, so you can see from my 15.3 gal fill-up that I was depending on it for the range.
Having over 16 gallon capacity on a vehicle that gets over 50 mpg = fantastic range. I can drive from Michigan to Florida on one tank... or across the entire country only stopping twice...
Old 02-14-2012, 06:20 PM   #58 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.57 mpg (US)
Silver Surfer - '02 Jetta TDI
90 day: 35.93 mpg (US)
any updates?
Past Present Future?
Old 02-14-2012, 06:55 PM   #59 (permalink)
Only bad ones (eco-modding wise). I completely changed direction with my car and life. My wife and I decided to take action to get our own farm and (mostly) off-grid home going right away, after finding a terrific deal on a vacant parcel of land I have been watching for years now. Bank finally wanted to just get rid of it and I was lucky enough to qualify for the new financing.
But as per the car.
I was sick of the rough ride and road scraping. It was pretty awesome while it lasted, and I have no regrets, but I was done with "low".
So instead of 2.5" lower vs. stock ride height, it's now 1.7" taller. About 4" higher than I used to drive around. That was quite a shock.
My new direction for the car was a goal of UTILITY. This diesel engine has such a tasty amount of torque and efficiency, that it's quite palatable to accept some minor fuel economy losses in order to open a whole new range of capability.
Once I get some bulk free time (ha!) I plan to build a front light setup just like this:
And a trailer hitch is quickly moving up the priority list of next mods. My buddy has a 5x8 utility trailer that I can use. That's going to ruin my rear diffuser mod.... and my other underpanel came off last winter on a 1000 mile snowboarding trip (didn't fly off, but I had to make a roadside rip-out).
Between the vehicle lift, oversized snow tires, worse aero, no engine heater use (new house has no garage) and less highway commuting, I am pulling only around 44 mpgs these days. Far below my old road trip peaks of 55+ and daily use of ~50... that feels like a long time ago.
All my money and research right now has led me to the purchase of this type of tractor:
So that I can get started clearing my new parcel of overgrown land. Trying to get a permaculture garden going asap!
I still want to add some significant aero-mods to the TDI, but the priority is quite low, to be honest. Maybe someday...
The Following 2 Users Say Thank You to Deezler For This Useful Post:
alohaspirit (02-15-2012), COcyclist (02-15-2012)
Old 02-14-2012, 11:58 PM   #60 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
Originally Posted by Deezler View Post
My new direction for the car was a goal of UTILITY. This diesel engine has such a tasty amount of torque and efficiency, that it's quite palatable to accept some minor fuel economy losses in order to open a whole new range of capability....
Thats the ballance us non-commuters are always trying to find.
I say don't worry about ride hight.
My engineer friend commutes in a 2001 sunfire. He put new struts on all 4 wheels and raised the car nearly 2 inchs. He said the effect on fuel milage is slightly more than only effecting the rounding error but still well with in the standard deviation.
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1487 05-22-2012 12:57 PM
Daox's 2003 Matrix Build Thread Daox EcoModding Central 74 09-17-2009 08:22 PM
Build Thread: 1996 Ranger 2.3L 5spd 2WD XVTer EcoModding Central 15 08-06-2009 06:58 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
