Just received my EWP today! It is a EWP80 from Davies, Craig.
Planning to install it as soon as i'm getting a rendez-vous with my mechanic.
The plan is to replace the old HP stealing mechanic water pump for a Manually Controlled Fan & Electric Water Pump. I did not buy this to save money, only for pure fuel economy. It is also part of my belt-less engine project.
Here is its caracteristics as it is ritten on the box :
EWP80 Electric Water Pump Specifications :
Operating Voltage : 3V DC to 15V DC
Maximum Current : 7.5A
Maximum Flow : 80 L/Min, 21 Gallon (US)/Min at 13.5V DC
Operating Temperature : -40°C to 130°C (-40°F to 266°F)
Pump Design : Clockwise Centrifugal
Motor Life : 6000 hrs at 80°C (176°F) and 12V DC
Pump Weight : 900 grams (2.0 Lbs)
Pump Material : Nylon 66%, 30% Glass Filled
Seal : Ceramic Face Seal
Burst Pressure : 350 kPa (50 Psi)
Fan Digital Controller Technical Specifications :
Input Voltage : 12V DC to 15V DC
Output Vge olta: 5V to 15V
Maximum Current : 12A
Operating Temperature : -20°C to 60°C (-5°F to 140°F)
Targeted (Set) Temperature : 75°, 80°, 85°, 90°, 95°C (167°, 176°, 185°, 194°, 203°F)
Controller Type : PCB with Micro Processor
Sensor Type : Thermister in Waterproof Housing
Fan Cut-In Temperature : 3°C (5.4°F) Above Set Temperature
Time Out : 2 Min. (Or Set : 5°C/23°F) After Ignition OFF
Indicator LEDs : Temperature, Power ON, Pump Mode, Test and Fan
Weight : 90 grams (3.2 oz.)
Dimensions (Metric) : 101 mm (L) x 95 mm (W) x 35mm (D)
Dimensions (Imperial) : 4" (L) x 3-3/4" (W) x 1-3/8" (D)
Here are some pictures of the EWP (Note that this post will be updated.) :
This is the box it was delivered in.
This is the EWP & Fan Digital Controller.
Combo Pack pieces.
EDIT :
Sorry for the head exercising pictures...
