Old 09-17-2014, 11:08 AM   #21 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
I changed these today and might as well show them here.
screen 1 ~ main screen on all the time
[ MAP ] [ trip average mpg ]
[ short fuel trim ] [ instant mpg ]
[ intake temp ] [ battery voltage ]
[ coolant temperature ] [ trip miles ]
screen 2 ~ only by manual ~ all stats recorded at fill ups
[ miles overall ] [ o2 sensor bank 1 ]
[ gallons overall ] [ trip mph ]
[ average mpg overall ] [ trip time ]
[ average mph overall ] [ level gallons ]
I used to use % engine load but switched to MAP (manifold absolute pressure),
go to 90 MAP on pulses, and make sure to not exceed matching RPMs when shifting.
The Following User Says Thank You to j12piprius For This Useful Post:
SilverCrown9701 (10-03-2014)
Old 09-19-2014, 12:33 AM   #22 (permalink)
SilverCrown9701's Avatar
SilverCrown - '01 Toyota Camry LE
90 day: 35.32 mpg (US)
Originally Posted by johnlvs2run View Post
I switch mine around but am using these currently.
[ MAP ] [ instant mpg ]
[ mph ] [ average mpg ]
MAP = intake manifold absolute pressure
I used to use % engine load but switched to MAP, and make sure it doesn't go into open loop, which is a little hard because the foot throttle is not easy to attenuate.
Sometimes I have used 3 screens on auto every 20 seconds, and just change the trip miles to something else, for example battery voltage or bank 1 oxygen sensor 1.
I'm just figuring out that I can use manual screen change with the down button, instead of auto, so I can switch to a more complete second screen just periodically, instead of having them change automatically. Normally though I just use the one screen.
I guess it's vehicle dependent, but are these gauges the best to use to provide feedback for increasing fuel economy other than the instant and average MPG??
Also, how much of a difference does enabling VE (Volumetric Efficiency) make in terms of fuel economy accuracy??
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
Old 09-19-2014, 01:01 AM   #23 (permalink)
Liberty Lover
j12piprius's Avatar
I use primarily pulse, and dwl combined with either dfco or engine on coasting, depending on terrain. I use MAP for acceleration and DWL, and Instantaneous MPG for DWL and coasting. My goal is to keep increasing the trip average mpg so I keep watching that too. I watch mph for a general guide to my speed. Coolant temp is for any adjustments to keep temperature in a narrow range and to keep the the fan off. I tried VE (Volumetric Efficiency) and didn't find it to be useful. I don't keep track of fuel used on a gauge, as I don't drive much except on trips and always fill up in plenty of time. I keep a record of when I get gas and fillups. Instantaneous gallons per hour seems a useful gauge but I've not used it much.
Old 09-19-2014, 01:28 AM   #24 (permalink)
Just cruisin’ along
jcp123's Avatar
Beater Echo - '00 Toyota Echo
90 day: 42.67 mpg (US)
Hondizzle - '97 Honda Civic DX
90 day: 46.55 mpg (US)
Shaggin Waggin - '14 Chrysler Town + Country
90 day: 22.56 mpg (US)
I noticed that the lower my Throttle Position, the better my FE. If I keep it below 16, then it boosts my mileage.
However, I also noticed that if I keep the throttle position too low, then I begin to lose speed and risk coming out of overdrive.
Is there a better way to use throttle position than what I'm currently doing??
Throttle position is tricky. Sometimes you have to keep it a bit more open than you'd like knowing there's a climb up ahead.
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
The Following User Says Thank You to jcp123 For This Useful Post:
Old 09-19-2014, 08:59 AM   #25 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
It's not just vehicle dependent, it depends on conditions. No one particular value means higher mpg, as such, in all weather, traffic and road conditions- except instant and average mpg.
You can learn from the other values, but these are the ones you're applying them to get.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
Old 09-19-2014, 05:50 PM   #26 (permalink)
I will have to try MAP. What range using MAP is good for FE??
% Engine load and TPS are very sensitive and I am not sure how much help they're really providing. It's frustrating watching them!
Old 09-19-2014, 06:47 PM   #27 (permalink)
Liberty Lover
j12piprius's Avatar
My aim when accelerating is to stay as close to 90 % engine load as possible, without exceeding it, as above 93% is open loop which uses more fuel.
My plan for MAP is much the same. I'm using the metric MAP gauge which goes up to 100. See here for The donkey CRX's comments about using a (non metric) vacuum gauge. You can choose either one. MAP is a digital vacuum gauge.
Old 09-19-2014, 08:26 PM   #28 (permalink)
I have on occasion used the lower end of % engine load for extending coast distances, and plan to experiment more with this using MAP. However this might not be a viable technique with my engine, because of the higher rpm's.
I have tried accelerating around 80% load in my car but it seems it wants to extend the shift at certain RPM ranges until I lift up slightly on the pedal to cause a downshift.
From a physics standpoint, wouldn't accelerating at target load % for a designated time, which prolongs the downshift, consume more fuel versus accelerating enough to shift through each gear to get into overdrive??
-Extended acceleration with drawn out downshifts @ X-RPMs until target speed.
OR...
-Shortened acceleration with quicker downshifts @ X-RPMs until target speed.
Example: I have accelerated from a stop up to 2,000-2,400 RPMs and held it in that RPM range using a certain throttle pressure until I get into overdrive............is this the wrong way to accelerate?
I may be wrong in that theory, correct me if I am. I know that my car being an automatic is a strike against me in terms of fuel economy but I love challenges and I'm treating like this like a game to get the highest "score" I can to save myself some money.
Old 09-19-2014, 08:57 PM   #29 (permalink)
Just cruisin’ along
jcp123's Avatar
That's why I never used load in anything, most especially my slushbox. It shifts too late and can risk a downshift as well.
Old 09-19-2014, 09:10 PM   #30 (permalink)
Liberty Lover
j12piprius's Avatar
Right. Overdrive is basically a downshift to generate more power at higher rpm's. A more detailed explanation is here.
In my automatic, that has no gauge, I use moderate throttle to get up to the highest gear as soon as possible (lowest mph), continue moderately accelerating in high gear (not overdrive), then shift into neutral and coast. The object is to keep the rpms as low as possible for the speed.
I would probably watch the instant mpg gauge carefully to see how to adjust.
