Old 05-30-2008, 03:32 PM   #21 (permalink)
TheDon's Avatar
Pepper - '87 300D
90 day: 30.42 mpg (US)
Originally Posted by FastPlastic View Post
I just used a piece from a broken picture frame. So it is pretty thin, which makes it easy to curve around bends. If you want to be lazy you could just pick up a picture frame from Wal-mart $10. Otherwise if you have a local hobby store (Hobby Lobby around here). I've seen the same size sheet for about $6. Another reason I choose to do it this way, be it harder because you have 5-7 slots to fill. I can always pop one or two out if I start having heat problems.
cool, I found a bunch of transparency sheets so I'll play with those
Old 05-30-2008, 06:01 PM   #22 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Cherokee
90 day: 15.69 mpg (US)
ZX7R Ninja - '99 ZX7R Ninja
90 day: 39.56 mpg (US)
Ok I went ahead and uploaded more pics of my Jeep to my photo album. I think I'll just post one or two of the main ones here if you'd like more detail feel free to browse my album.
Side View
Messy Front Under Body.
Driver Side Under Body.
Passenger Side Under Body.
And A view From The Back.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 05-30-2008, 07:24 PM   #23 (permalink)
Bumper mods
So for the past 5 or 6 days now it's been raining. So I haven't been able to work on the Jeep. Instead I started looking over photos I took last week to get ideas for what to do next. I've decided the next project is going to address the para shoot they call a rear bumper.
The fuel tank hangs really low on the Jeeps, So do I need to wrap around the tank some with the tray or can I just butt it up against the rear of the tank?
I'm guessing either way would be an improvement from the para shoot I have back there already. Just looking for input.
I just did a post on underside mods.You might want to check it out.'like the grille,happy modding!
Old 05-30-2008, 09:46 PM   #24 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
I believe that all you'll have to do to remove the racks is take some torx bits and unscrew them, then take off the crossmembers if you want to keep the rest on.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 05-30-2008, 10:15 PM   #25 (permalink)
Ok, I'm going to take the advice of most of you and work from the front back. With the exception of the roof rack. I'll save the rear bumper for later.
I think I'll go ahead and take off the cross bars on the roof rack. I'm planning on leaving the tracks because I don't want the roof to leak. Had problems with the last Jeep ceiling so don't want to take any chances.
The other project on the front end I think will be filling the Fog light/Tow Hook holes in the front bumper. Hopefully that will help push a little more air around the Jeep. I know it's not much, but every little bit counts right?
Old 05-30-2008, 11:59 PM   #26 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Civic Sedan LX
90 day: 35.68 mpg (US)
Arrow
Yes, FastPlastic, every little bit should help ... and since you are doing it yourself on a shoe-string, you have practically nothing to lose.
But I have to side with the others here that your roof rack is a killer. I'd remove it ... and if you have bolt holes going into the roof, take the bolts that go into them, give each a dab of RTV silicone on the threads then replace them. They shouldn't leak for 20+ years.
My uncle has a Hyundai Tucson with a long commute he complains he gets only 23mpg. I told him to at least take the cross-bars out of his rack (which is never used) and inflate the tires to 2psi lower than the sidewall maximum ... that might get him to 25mpg ... but I know he won't do it. Some people are funny like that.
--- Bror Jace
Old 05-31-2008, 12:08 AM   #27 (permalink)
Recycling Nazi
Bror Jace's Avatar
Arrow
"Are the fender flares easily removable? Those babies stick out like big air scoops. The early Cherokees didn't have them."
Take the front ones off ... but use the rear flares as starting points for rear wheel well skirts.
--- Bror Jace
Old 05-31-2008, 12:28 AM   #28 (permalink)
Blue - '-1823 P/U
waiting to hear the improvements
Old 05-31-2008, 12:51 AM   #29 (permalink)
Red
Red's Avatar
Send a message via MSN to Red Send a message via Yahoo to Red
The flares and the molding are bolt on, I'm 98% sure since I know some XJ owners install TJ flares to cover their tires
Old 05-31-2008, 01:49 AM   #30 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Neon SE
90 day: 36.28 mpg (US)
S'Crew - '02 F150 Supercrew XLT
90 day: 16.4 mpg (US)
EX - '94 Explorer
90 day: 19.58 mpg (US)
Ranger - '90 Ranger
Last 3: 28.02 mpg (US)
I'd check local laws before covering headlights (even with clear) and before removing the flares. I know in Utah, if the body doesn't cover the tires, you won't pass safety. I also know some that take the flaresoff after passing safety, but that could one stopped by the troopers...
When it comes to Heroes, RENEGADES are mine!
low pressure kills mpg's
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/jeep-cherokee-aeromods-2614.html
Posted By For Type Date
Simple Tips for Saving Fuel During Cold-Weather Driving - Digg This thread Refback 11-11-2011 02:54 PM
Jeep Cherokee Front Bumper - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 02-21-2010 06:01 PM
Aeromods V1.0 trikkonceptz Aerodynamics 50 10-14-2011 12:30 PM
Glides like a Brick Wall (Jeep Cherokee, GMC Pick-up) DonEaston Aerodynamics 22 10-26-2008 05:17 PM
jeep aero mod ideas johnpr Aerodynamics 22 08-27-2008 08:45 PM
mpg + jeep - thinking cap help? tkmd EcoModding Central 6 04-28-2008 10:15 PM
Off-Road Test: '08 Jeep Grand Cherokee (Rally Race) RH77 The Lounge 4 02-25-2008 04:59 PM
