Old 08-13-2014, 10:51 AM   #41 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
For how long have you been painting cars? I have been talking about covering my Civic with Plasti-Dip since before I bought her. I do not have any idea why there are so many black cars in Arizona! My paint is terrible, too, and a fender is banged up. I could pay to repaint the car, but I understand that it would cost at least as much as I paid for the car!
I starting painting cars back in 1986. Man has it been that long. lol
Plastic Dip has really became popular. The aerosol version is pretty easy but the actual Plastic Dip you buy to painted through a spray gun takes some practice and takes a lot of time to spray.
My Talon has taken more time then I thought because there was a lot more body damage then I originally thought there was. I have about 70 hours of "touch time" in body and paint as of right now. Plus there is the challenges of doing this in my own garage that slows the process down a lot.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
user removed (08-13-2014)
Old 08-13-2014, 02:42 PM   #42 (permalink)
Looks great from the photos. Few people outside of those who have painted a car and had the customer tell you it looks better than the day it left the dealer's lot, know how much work it can be.
regards
Mech
pgfpro (08-13-2014)
Old 08-13-2014, 03:02 PM   #43 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
I do not have any idea why there are so many black cars in Arizona! !
https://www.dipyourcar.com/Professional-Car-Kit.html
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 08-31-2014, 01:01 PM   #44 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Update:
Pick up a new turbo to test with my monster BW S475.
New high pressure turbo:
DSM 68HTA
Compressor wheel - 68HTA
Flow rating - 51LB per minute
CW Measurements - 51.2MM Inducer / 68MM Exducer
TW Measurements - 60.8MM Inducer / 54MM Exducer
Compressor Housing - 16G TD05H
Turbine Housing - FP 8CM
CHRA - FP Journal Bearing
Pic
Low Pressure turbo:
BW S475
Compressor wheel - 75 mm ETT
Flow rating - 100LB per minute
CW Measurements - 75MM Inducer / 100MM Exducer
TW Measurements - 96MM Inducer / 88MM Exducer
Compressor Housing BW S400SX4
Frame T6 with a 1.32 A/R
CHRA - BW Journal Bearing
Pic
This combination has be tested and proven with a fellow DSM Talon friend that has gone high 7's at 180mph in the 1/4. He is one of the pioneers in gasoline turbo compound systems.
Here are some data-logs from his runs showing great back pressure numbers.
Back pressure log
Awesome engine delt p numbers as the gates open to bypass around the high pressure turbo!!!
For me HP performance will always be in my blood so the more I can make the better, but I think this combination will help also with back pressure issues at light load and help with FE.
jedi_sol (09-01-2014)
Old 09-01-2014, 07:30 AM   #45 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
It's going to be a fuel sipping MONSTER!
The Following User Says Thank You to jedi_sol For This Useful Post:
pgfpro (09-01-2014)
Old 09-02-2014, 05:14 PM   #46 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Paint work is all done!!!!!
That took forever. All the side and lower moldings make it seem like a much larger car then it is. What a pain!!!
Now I can start the buffing process, then it's back to finishing the mechanical.
Old 09-20-2014, 09:37 PM   #47 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Update:
Buffing is all done!!!
1200 wet dry sanding uck!!!!!!!!
First step using Presta First step #1
Second Stage Presta #2 swirl remover
user removed (09-20-2014)
Old 09-20-2014, 09:39 PM   #48 (permalink)
Slicker than the buttocks of a newborn babe. Wanna paint my Sentra, LOL.
regards
mech
pgfpro (09-21-2014)
Old 09-20-2014, 09:40 PM   #49 (permalink)
Pretty healthy looking gent holding that camera.
regards
mech
pgfpro (09-21-2014)
Old 09-20-2014, 09:42 PM   #50 (permalink)
LOL, I need to go out to my garage and check to make sure my cheap arse harbor freight buffer is not missing. I like the sponge velcro stick on pads.
regards
mech
bio fuel, lean burn, turbo compound
