Old 10-26-2011, 02:19 PM   #1 (permalink)
JJMunoz's Avatar
Seriously? - '94 Civic DX
90 day: 57.26 mpg (US)
Talking My 1994 Honda Civic DX MPGuino Install (w / pics) !
So I got my MPGuino in the mail the other day and decided to install it in the cluster like I saw on another civic on this forum a while ago.
I have a 1994 Civic DX with a 1994 Si cluster installed.
I had no experience with silicon boards so this was a first time thing for me.
So of course, the first and most logical thing to do would be to tear the switches off the MPGuino since I wasn't going to be using them, right?
Yikes.
I tore them off and realized the solder and old pieces of switch weren't going to come out of the board.
So my first experience in soldering was installing 6 wires on the board ( I didn't realize the front of the board was a common ground for all 3 switches), which came out pretty good!
I soldered wires onto 3 switches and put connectors on the end of them.
Then I embarked on grinding away the cluster.
The front portion of the cluster came out good right away.
I cut the bottom of the plastic face on the tach around the bottom of the 8k rpm line.
The mistake I made was using the 1994 DX cluster (without tachometer) and trying to fit the MPGuino in there, thinking the two casings of the DX and SI clusters were the same.
Wrong.
I realized this when I pulled the SI cluster out my car and tried to fit the MPGuino in it and the MPGuino was pressing against the bottom of the tach.
My second problem was that this guys MPGuino was separated into two boards and not two boards glued together like mine.
I had this space discrepancy of a little over an 1/8" to take care of.
This is where my nightmare began because I had to cut a shield off the bottom of the tach and grind down the plastic base of it, which in the Honda tuner world would probably be considered complete sacrilege,
and I had to grind down the MPGuino board, just to fit it on an angle in the cluster ( You can see the grind down point next to the two red connector covers in the picture.).
I heard the MPGuino gets hot so I drilled ventilation holes in the top of the cluster.
I had to grind away portions of the cluster backing for the wires to pass through and a portion of the plastic to the bottom-right of the tach to fit the MPGuino properly.
I drilled 3 holes in the right side of the cluster cover for my switches and began installing it in the car.
The leads on the civic are as follows:
- Green and Black are +12v and Ground as it says on the MPGuino wiki.
- The Cylinder #1 Brown Injector Wire in the engine bay is your injector lead, NOT the brown wire coming out of the first connector in the ECU.
- The only yellow and blue wire coming out of the ECU is your VSS lead. It's in the middle connector of the ECU.
I ran the power off an unused hot at all times terminal in the fuse box and the ground off a bolt near my clutch pedal.
The VSS lead is easily hidden under the carpet but the injector lead was a little harder to hide. This was how I did it. :/
After all said and done, it came out pretty nice.
It was scary, but successful.
The Following User Says Thank You to JJMunoz For This Useful Post:
California98Civic (10-26-2011)
Old 10-26-2011, 05:01 PM   #2 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.96 mpg (US)
Very nice job!
There's a 'Guino installations thread; you should put in a pic of yours and a link to this thread. The Enclosure Thread, Show Yours Off!!
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Old 10-26-2011, 08:40 PM   #3 (permalink)
trustyHX - '97 civic HX
90 day: 50.15 mpg (US)
car does warm up fast brucepick,at least my hx does 374,200miles and counting,make sure you clean the egr ports under the fuel rail helps with FE,I do mine every 100k. Hope your wife gets better.Mike
Old 10-26-2011, 10:38 PM   #4 (permalink)
JJMunoz's Avatar
Originally Posted by brucepick View Post
Very nice job!
Thanks, man! I put it in that thread, too.
Old 10-26-2011, 11:01 PM   #5 (permalink)
60+ mpg at posted speeds
California98Civic's Avatar
Black and Green - '98 Civic DX Coupe
90 day: 64.83 mpg (US)
Really smart. Good looking. Stealthy mod. Inspiring stuff.
Black and Green will be rebuilt over decades as parts die--until it becomes a different car. Goal is only 60-70 mpg at posted speeds. I'm not trying for highest possible mileage.
Calculators: standard deviation, Ohms Law, & drag HP losses.
