Old 07-11-2008, 06:48 PM   #101 (permalink)
The Civic - '99 Civic
90 day: 40.41 mpg (US)
I wonder why I cant get mine to display anything but OBD-II ISO9141-2. My serial monitor just shows "initialization"
Old 07-12-2008, 12:21 AM   #102 (permalink)
N8sPony - '98 Mustang
bleh, plugged it up in the car tonight and turns out I suck, lol. Best as I can tell, I'm going to have to get some transistors to drive the lines, but I still don't know how I'm going to get it to read back the data, because the pulsein() Idea I had isn't working worth crap.I'm going to look into getting samples of some driver chips so I can cheat, lol. I dunno, I think I'm way out of my league on this one, but I'm gonna keep trying. I REALLY wish I had an O-scope to see if the car's responding....
Old 07-12-2008, 09:49 AM   #103 (permalink)
cmags's Avatar
Scoob - '05 Impreza Outback Sport SE
90 day: 25.28 mpg (US)
Well, I think it was posted here before, but here it is again with a direct link to the trunk: Revision 4: /trunk
You might be able to look over their code for some of the basics... GL!
Old 07-14-2008, 03:27 PM   #104 (permalink)
OBDuino coder
Magister's Avatar
Titine - '07 Elantra GL
I tested in my car but after sending the 0x33 at 5 bauds it seems I get no answer from the ECU. I should bring a scope in the car :-/
Old 07-15-2008, 02:43 PM   #105 (permalink)
OBDuino coder
Magister's Avatar
My interface is finally completed, I rewired it with 28AWG instead of 22 (what I had around), it's nicer
On my bench I tested the output of the ISO line of the MC33290 with a scope when I send the 0x33 and it's ok. I am wondering if the 2 grounds in the car are connected or not (pin 1 and 2 of the OBD2 connector). I will do a test with the MC ground on pin 1.
Else I will take an inverter and a scope in the car to test signals.
Old 07-15-2008, 11:21 PM   #106 (permalink)
nice, I wish I had a scope, then I could compare the signals from my usb adapter with those from my arduino. I've all but stopped messing with it atm, because I really am stuck and school's creepin up. bleh.
Old 07-17-2008, 12:57 AM   #107 (permalink)
Wow, nice work on the diagrams magister
Old 07-17-2008, 10:17 AM   #108 (permalink)
OBDuino coder
Magister's Avatar
Thanks
I made some wiki page on the project too
opengauge - Google Code
Old 07-17-2008, 02:16 PM   #109 (permalink)
OBDuino coder
Magister's Avatar
I tested with a scope in my car and when I send the 0x33, all the timings are correct on the K line, but the ECU does not answer, the bus is always high and I see no start bit (active low) coming
I am starting to wonder if my car answer to the slow init or if I need the fast init or the iso init sequence
Old 07-20-2008, 02:09 AM   #110 (permalink)
Under "MAF Sensor" in the list of constants...someone needs to change "4.54" grams per pound to "454" !! This decimal point is lost!
I didn't check the others, but they look OK at a glance. -whitevette
obd2
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 999 12-14-2011 01:18 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 06:35 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 05:57 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-15-2008 12:04 AM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 11:04 PM
