11-02-2010, 10:18 AM
aero guerrilla
The Show Off Your Cockpit Thread
This thread is for anyone who wants to show how they've Feng-Shuied their cockpit to ease hypermiling.
When I started ecomodding a while back I kept wondering about how and where to attach all the buttons, switches and LEDs in a way that is both functional and wife-approved. Luckily, the CD changer under my radio was kaputt, so I removed it to (1) use less electricity, (2) keep it out of the reaches of anyone who might want it. (Actually, I don't mind someone taking it, but I don't want to replace my window in the process.) So I used the space under my radio for my ecomodding console, and now that it's more or less done I'd like to show it off so that others may get some inspiration.
I used the carcass of a dead radio to make sure everything would fit nicely.
Starting from the left: - A mom-off-mom switch for engine starting and stopping,
- An on-off switch for the alternator (not used),
- Two mom-off-mom switches for opening/closing the two active grille blocks,
- An on-off-on switch for the DRLs (on-off-auto).
There is also a small blue LED to signal when the DRLs are on, and a larger blinking red LED that was supposed to signal when the radiator fan kicked in, but now only signals when the engine kill button is pressed. There is still room for another two switches when the time comes.
The insides (pardon the mess) are wired through connectors which allow the whole box to be easily taken out of the car (and worked on in a warm, dry place). I plan to get the mess cleaned up and add a small diagram of which wire show go where, in case my failing memory gets the better of me.
My ScanGauge rests in on the ashtray, under which is the OBD socket.
I'm thinking about a semi-clear piece of plexi, hinged at the top, to cover the buttons from curious eyes and fingers when I'm not driving.
And here's the start/stop button in action.
Piwoslaw's Peugeot 307sw modding thread
The Following User Says Thank You to Piwoslaw For This Useful Post:
11-03-2010, 12:20 PM
X-Frenchy: very
Congrats for the cleanness of your switches box  at least when it's closed
Sadly I don't have a free space to cleanly mount my switch
May I open a "Show off your ugly cockpit" thread ?
Denis.
Save money & CO2 at home : http://ecorenovator.org/
Created and managed by the creators of http://ecomodder.com/
Earth and health are priceless, so are kilotank and AT-PZEV
Best Mégane tank: 1268.9mi @ 77.847 MPG(US)
2008/06-2011/10 saving: - 5725.5 kg CO2 (5342.6+382.9)
- Diesel / Money: 42.17% = 2446.25€ = 3357.26$
megane : thread - kill switch.
11-03-2010, 12:34 PM
...beats walking...
...how does that saying go? "...NEATNESS is next to..."
11-03-2010, 04:18 PM
aero guerrilla
Oh, c'mon Groar. First the Uglyback, then the Uglycover and Uglyteeth, now the Uglycockpit. Where is your self esteem??
11-03-2010, 07:35 PM
Absent without leave.
My travelling environment, glad I gave it a quick hoover last week
Anyone want to play spot the VAG part ? The wheel is an obvious one... Note I drive on the correct side  so the wheel is on the right, and mods seem to be at a minimum. But wait, there is an SG2 poking its head over the steering column.
Why yes, there it is. Note that the SG supplied sticky pad has long since given up so I replaced it with one intended to stick number plates onto the outside of the car, but as you can see the toxic state of my interior has made it fail.
No it wasn't as late as the clock suggests, I must work out how to change it for GMT after BST.
All of this looks neat until...
Yes I did take a Dremel to my dashboard to get the wiring to fit. I actually got fed up of banging my knee on the door to this cubby hole.
I did miss out a pic of the insulating tape holding this cover closed, but you get the idea.
No longer here. Bye, and good luck to all.
11-03-2010, 08:26 PM
Left Lane Ecodriver
@Arragonis:
Ah, so much better.
Here's my toggle switches, which fill space formerly occupied by blanks in all North American Insights. From left to right, it's fuel injectors, clutch switch (assist/regen disable), DC/DC converter, and MIMA enable. The only one I use with any frequency is the one on the far left, which enables EV mode, forces DFCO, or just does light anti-theft duty.
This is the only picture I have of my MIMA display, which is just eleven LEDs wedged between the steering cowl and the dash.
Pictures of my ScanGauge, MPGuino, and BCMGauge will have to wait until the latter two are installed. I also have a momentary kill switch on the gearshift and a MIMA joystick + 2 buttons zip-tied to the handbrake lever.
11-03-2010, 09:22 PM
LOL, Robert you need some gas and juice in that thing.
regards
Mech
11-03-2010, 11:49 PM
Dartmouth 2010
Looking nice guys, hopefully I can dig up a photo of where I left the IRX when I split from the country
11-04-2010, 12:48 AM
#9 (permalink)
NightKnight
I'm still looking for the " Mom-off" switch... where do you find one of those? And do they really work? My Mom can be a bit annoying when I EOC...
11-04-2010, 02:45 AM
#10 (permalink)
aero guerrilla
Originally Posted by RobertSmalls
@Arragonis:
Ah, so much better.
LOL, you beat me to it!!
Actually, the only Mom-off I've heard about is the permanent variety  Notice mine are Mom-off-Mom, so going from Mom to off brings Mom back sooner or later... Mom is never too far away...
