Old 01-02-2011, 10:37 PM   #1 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.57 mpg (US)
Silver Surfer - '02 Jetta TDI
90 day: 35.93 mpg (US)
Cool Toyota Echo Lower Grill Block & Underbody
Was a nice day today (78F) so I decided to tackle some aero work.
Made a lower grill block out of coroplast
notched 3 parts for the stock tabs and then secured it with 2 zip ties
(which are hidden by the plate)
Ill drive it like this to log mpg and monitor temps.
Then, I will fab covers for the front underbody.
There are 2 open air pockets on either side of the bumper
as well as a large pocket around the oil pan.
(hopefully the coroplast will be ok from the heat of the oil pan)
Aw yeah! Post 808!
Past Present Future?
The Following User Says Thank You to alohaspirit For This Useful Post:
CigaR007 (01-02-2011)
Old 01-02-2011, 10:44 PM   #2 (permalink)
Efficiency Aficionado
CigaR007's Avatar
GreenTurtle - '01 Echo Sedan
90 day: 42.53 mpg (US)
Wow. Looks really clean.
I have a 2001 Toyota ECHO too and I have been pondering a grille block for the last few days since I am on vacation !
I am eager to see the gain in FE since we have the same car.
Keep us updated !
Old 01-02-2011, 10:44 PM   #3 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
Looks good!
Let me know how it helps your MPG and I can add the data to our wiki.
Old 01-02-2011, 10:46 PM   #4 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
Be careful with blocking the grille on a car with an automatic transmission. If you reduce the transmission coolers effectiveness you could overheat the fluid and possibly damage the transmission.
That may not be an issue in your case if you are not driving longer distances at higher speeds.
regards
Mech
The Following User Says Thank You to Old Mechanic For This Useful Post:
aerohead (03-08-2011)
Old 01-03-2011, 12:27 AM   #5 (permalink)
Grasshopper
Keep us updated !
Originally Posted by Weather Spotter View Post
Looks good!
It will probably be a couple weeks until I have numbers.
(Im mostly driving the Civic)
But I promise to report my findings
Old 01-03-2011, 12:28 AM   #6 (permalink)
Grasshopper
regards
Mech
Will monitoring the engine temp via scanguage be enough?
Old 01-03-2011, 12:38 AM   #7 (permalink)
Wiki Mod
Yes, that should be enough. If the fan comes on too much then reduce the grill block.
Old 01-03-2011, 12:46 AM   #8 (permalink)
CigaR007's Avatar
No pressure. Besides, I intend on finishing the lower grille block installation on my ECHO tomorrow. The upper grille block has been on for a few days already. Should report my findings soon enough.
Old 01-03-2011, 01:25 AM   #9 (permalink)
Grasshopper
Personally, I have a feeling the heat will go up
(tropical weather after all)
Sounds good. Im interested in how you made your grill blocks.
How are those miata rims treating you?
Old 01-03-2011, 01:55 AM   #10 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
I didn't know that you could order custom signed coroplast from EcoModder
Piwoslaw's Peugeot 307sw modding thread
