04-19-2011, 01:24 PM
#22 (permalink)
The road not so traveled
Im not a pro-tuner, but
You were adjusting the long term fuel trim right?
So what was the short term fuel trim?
04-19-2011, 01:28 PM
#23 (permalink)
Originally Posted by richard_lyew
lol im not trying. i have done it. its there. and im not trying to convince anybody of anything or to do anything or to buy anything.
You should be happy then because you haven't convinced anyone thus far.
im a pro tuner. only person can answer the tuning side of this video is another pro tuner.
Somebody call up that other pro tuner because you're doing an awfully poor job of explaining anything.
04-19-2011, 01:29 PM
#24 (permalink)
Empty Pocketed Ecomodder
i saw the correction factor at -50%, and i then saw the rpm at 388 RPM (according to his meter) and yet his tach showed about double that. so let's see, 780RPM Idle reduced by 50% (hence the "-") and you get 390 RPM. seems to me like he did the equivilant of calibrating his SGII to read that he was hardly using any fuel when he was using the normal amount.
The Following User Says Thank You to Joenavy85 For This Useful Post:
04-19-2011, 01:36 PM
#25 (permalink)
And just to be clear on a couple of things,
SAE did research hydrogen to support leaner fuel trims. Their findings were yes it worked, but that the savings weren't worth the extra complexity.
If you had claimed a 2%, 5% or even 10% improvement some people here might be more inclined to believe you. But a 3X improvement.... no. Your going to have to really show some good proof.
Does anyone know if an O2 sensor will give readings on H2? Or does it have to be a hydrocarbon?
04-19-2011, 01:47 PM
#26 (permalink)
Originally Posted by TheEnemy
SAE did research
Now you did it, now this guy is going to denounce SAE saying that they aren't Pro Tuners
04-19-2011, 01:57 PM
#27 (permalink)
Everyone knows the bigger the lie, the more likely people are going to believe it.
Seriously.
And an O2 sensor measures oxygen in the exhaust. Hydrogen will not affect it.
"We think B20 is for suckers" N. Cowell, Denver B100
"Climate change denial is a conclusion in search of a rationalization" labman57
04-19-2011, 02:45 PM
#28 (permalink)
Pokémoderator
richard_lyew -
I would assume that you can use your APEXi to datalog. Can you output sensor data into a CSV file for importing into Excel?
CarloSW2
04-19-2011, 08:02 PM
#29 (permalink)
Originally Posted by cfg83
richard_lyew -
CarloSW2
CVS? i want one of those little computers that you guys use to measure MPG so i can connect it to the output signal of my AFC which the car's ECU is getting so you guys can see.
where do i get one of these devices?
04-19-2011, 08:05 PM
#30 (permalink)
this car dont have a back o2 sensor and im porting my HHO after the MAF right at the main intake right next to the idle intake. the idle intake for this car is a hole right above the main intake butterfly, shown here idle air intake - SaturnFans Forums
