Old 09-12-2014, 02:42 PM   #1 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Active grill shutters at the dollar store!
These vents have a pair of plastic shutters that are actuated by a small DC motor. Perfect for an automated grill block! But being a motor, they need only a short electrical pulse to move. You can't feed them continuous power. The timer takes 2 AAA batteries, so I assume the motor gets about 3 volts. It works fine on 1.2v. I wouldn't try 12v! Some weatherproofing for the motor will be necessary. The shutter area is about 4" x 9". I'll try one first, maybe that'll be enough airflow. I usually have a smaller grill opening than that.
I bought a bunch. I'll make a post in the classifieds if anybody else wants to play with one. Or if you're in Upstate NY, look for Real Deals Dollar Stores!
ID:	15799   Click image for larger version
ID:	15800   Click image for larger version
ID:	15801   Click image for larger version
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following 17 Users Say Thank You to Gasoline Fumes For This Useful Post:
aerohead (03-31-2015), BamZipPow (09-15-2014), Cd (09-13-2014), CigaR007 (03-30-2015), Daox (09-12-2014), fusion210 (09-13-2014), gumby79 (06-30-2015), jeff88 (09-12-2014), mcrews (09-12-2014), MetroMPG (10-02-2014), ME_Andy (09-12-2014), mikeyjd (09-13-2014), mpg_numbers_guy (03-15-2018), Occasionally6 (09-12-2014), shankar_roy (11-24-2015), SwamiSalami (10-16-2014), UltArc (09-14-2014)
Old 09-12-2014, 02:44 PM   #2 (permalink)
Nice find! I wanna see them on your car now.
Old 09-12-2014, 03:08 PM   #3 (permalink)
http://www.amazon.com/Vent-Miser-91663-BR-Programmable-Energy-2-Inches/dp/B000WAGVRY
$7.89 for 2" x 12", $5.99 + $2.99 shipping for 4" x 10"
The Following 6 Users Say Thank You to Xist For This Useful Post:
Daox (09-12-2014), Gasoline Fumes (09-12-2014), mcrews (09-12-2014), mikeyjd (04-06-2015), mpg_numbers_guy (03-15-2018), Occasionally6 (09-12-2014)
Old 09-12-2014, 03:30 PM   #4 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
It would look something like this. That's just a normal vent that I never figured out how to reliably actuate. Luckily the new vent is the same size as the first one I bought! It's a 4" x 12" vent.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following 4 Users Say Thank You to Gasoline Fumes For This Useful Post:
aerohead (03-31-2015), Daox (11-28-2017), j12piprius (12-25-2015), SwamiSalami (10-16-2014)
Old 09-12-2014, 05:20 PM   #5 (permalink)
If I buy you black paint, will you use it?
The Following 4 Users Say Thank You to Xist For This Useful Post:
bikeprof (11-24-2015), Cd (09-13-2014), Fat Charlie (09-13-2014), Gasoline Fumes (09-12-2014)
Old 09-12-2014, 07:42 PM   #6 (permalink)
That's f#$%ing perfect! It's pretty much as I had envisaged fabricating. Sooo much easier to use off the shelf parts.
I think it will be better without the white vent cover and with a fabricated duct.
A regulated 3V (from "12V") is almost trivial to achieve.
I'm also thinking an aero profile on the blocking slats for when they are open .
And, can something useful be done with the timer/clock?
Old 09-12-2014, 08:49 PM   #7 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
I did paint it black. It's not actually even on the car, I currently have the license plate over the hole. And I have to constantly adjust the location of the plate to keep the radiator fan off. I can't wait to get this new vent working.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Old 09-12-2014, 08:53 PM   #8 (permalink)
Interesting..... And someone on kick starter had one that you operate by bluetooth. Sounds like too much work, Ill stick to my little 4x4 inch opening.
Old 09-13-2014, 01:55 AM   #9 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
I wonder if one of those would provide enough airflow for a 2000 insight in 104F Weather fully opened? This definitely is worth looking into if I can get my overheating problem fixed.
Old 09-13-2014, 02:18 AM   #10 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
For hotter climates, I'd probably use two of them.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
