Old 07-25-2014, 09:39 PM   #41 (permalink)
The rear corners work better than I expected. i guess I was thinking of a '56 Ford pickup bed.
Are you going to tighten up the top half of the gap at the cab?
Old 07-26-2014, 12:08 PM   #42 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Today, I will travel about 360 miles with this truck, on business. Prior to leaving, I will top off the tank.
Originally Posted by California98Civic View Post
Those numbers and that picture tell the story well. So if the numbers hold when you get better instrumentation hooked-up you just gave yourself somewhere between a 10% or even 20% increase in FE. That would be pretty amazing.
Yah, I surely hope so. We shall soon see.
Yes, after I come up with the hinge mechanism for the cap itself. I figured that I could live with the slight reduction in efficiency due to the gap. There's already a comparably sized gap between the truck bed and the cab section. *shrugs*
The Following 2 Users Say Thank You to t vago For This Useful Post:
aerohead (07-26-2014), BamZipPow (07-26-2014)
Old 07-26-2014, 02:01 PM   #43 (permalink)
some Dakota mpg's
The 2001 Dakota Quad Cab was reported @:
11.3 mpg (worst)
13.6 mpg (average)
15.5 mpg (best)
in a long-term test by maybe Road and Track,I'd have to look.
*The 1986 2WD Dakota's Road Load was measured @ 19.0 hp @ 50 mph
*The 1989 Shelby Dakota Road Load was measured @ 19.0 hp @ 50 mph
*------------------------------------------------ @ 41.0 hp @ 70 mph
*The 1992 4X4 Dakota's Road Load was measured @ 25.0 hp @ 50 mph
BamZipPow (07-27-2014), t vago (07-26-2014)
Old 07-27-2014, 09:09 AM   #44 (permalink)
MPGuino Supporter
t vago's Avatar
Result's from yesterday's trip -
Distance: 354.6 miles
Time: 5 hrs, 21 minutes
Average Speed: 66.3 MPH
FE: 19.6 MPG
I am going to perform another ~250 mile trip today - this time, I will re-install the performance tune that I had removed a few months ago.
The Following User Says Thank You to t vago For This Useful Post:
aerohead (07-28-2014)
Old 07-27-2014, 12:38 PM   #45 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
ABA testing?
Originally Posted by t vago View Post
Result's from yesterday's trip ...
Any chance for ABA testing? Maybe a coast down test? I'd hate for all the other variables like wind and temp and subtle throttling differences to create the bummer effect for you. The project is so good. A coast down test wouldn't consume a lot of fuel either.
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
MetroMPG (07-28-2014), t vago (07-30-2014)
Old 07-29-2014, 12:44 PM   #46 (permalink)
Another query: are you going to try tuft testing?
t vago (07-30-2014)
Old 07-29-2014, 06:11 PM   #47 (permalink)
66.3 mph
For all the driving,do we have a baseline mpg for this speed?
We'll need some similar trips with the 'naked' truck to questimate the new performance.
From the old 1963 GM Labs relationship we'd figure about a 5.5% mpg increase per 10% drag reduction in this speed range.
t vago (07-30-2014)
Old 07-30-2014, 11:55 AM   #48 (permalink)
MPGuino Supporter
t vago's Avatar
I have to find some relatively flat section of road around here. Luckily, this area does have some decently flat roads (near Amana, IA). Hopefully, I can do a few coastdown runs this upcoming weekend.
Yah, at some point, I want to film a tuft test session. I am also interested in what the airflow patterns look like.
Unfortunately, no. Since I had the previous aerocap installed, the truck has gathered a good amount of mileage (needs a tuneup), the A/C compressor failed (possible extra parasitic drag), the P/S pump is dying (more possible extra parasitic drag), the EVAP purge switch failed (Check-Engine-Light lit), and my mother-in-law smacked the front left fender of the truck into a telephone pole (front aero changed).
However, this weekend should hopefully give me some good A/B data.
aerohead (07-30-2014), BamZipPow (07-31-2014)
Old 08-02-2014, 04:01 PM   #49 (permalink)
MPGuino Supporter
t vago's Avatar
This is a link to a section of road, on which I intend to perform some coastdown tests. It is nice and flat, and not very busy.
Flat coastdown run - Iowa, IA
I will probably go ahead and hook up an MPGuino to the truck, once I find a nearby RadioShack to get the necessary interfacing components. I will then record the MPGuino output using my cellphone, and upload the videos to YouTube. Once done, I will crunch the numbers from reading the videos.
aerohead (08-02-2014)
Old 08-04-2014, 07:07 AM   #50 (permalink)
. . . I will then record the MPGuino output using my cellphone, and upload the videos to YouTube. Once done, I will crunch the numbers from reading the videos.
Sounds like a need-based opportunity to add MPGuino functionality!
aerocap, aeroshell, dakota, truck
