07-25-2014, 09:39 PM
#41 (permalink)
The rear corners work better than I expected. i guess I was thinking of a '56 Ford pickup bed.
Are you going to tighten up the top half of the gap at the cab?
07-26-2014, 12:08 PM
#42 (permalink)
MPGuino Supporter
iNXS - '10 Opel Zafira 111 Anniversary Suzi - '02 Suzuki Swift GL
Today, I will travel about 360 miles with this truck, on business. Prior to leaving, I will top off the tank.
Originally Posted by California98Civic
Those numbers and that picture tell the story well. So if the numbers hold when you get better instrumentation hooked-up you just gave yourself somewhere between a 10% or even 20% increase in FE. That would be pretty amazing.
Yah, I surely hope so. We shall soon see.
Yes, after I come up with the hinge mechanism for the cap itself. I figured that I could live with the slight reduction in efficiency due to the gap. There's already a comparably sized gap between the truck bed and the cab section. *shrugs*
The Following 2 Users Say Thank You to t vago For This Useful Post:
07-26-2014, 02:01 PM
#43 (permalink)
some Dakota mpg's
The 2001 Dakota Quad Cab was reported @:
11.3 mpg (worst)
13.6 mpg (average)
15.5 mpg (best)
in a long-term test by maybe Road and Track,I'd have to look.
*The 1986 2WD Dakota's Road Load was measured @ 19.0 hp @ 50 mph
*The 1989 Shelby Dakota Road Load was measured @ 19.0 hp @ 50 mph
*------------------------------------------------ @ 41.0 hp @ 70 mph
*The 1992 4X4 Dakota's Road Load was measured @ 25.0 hp @ 50 mph
07-27-2014, 09:09 AM
#44 (permalink)
MPGuino Supporter
Result's from yesterday's trip -
Distance: 354.6 miles
Time: 5 hrs, 21 minutes
Average Speed: 66.3 MPH
FE: 19.6 MPG
I am going to perform another ~250 mile trip today - this time, I will re-install the performance tune that I had removed a few months ago.
The Following User Says Thank You to t vago For This Useful Post:
07-27-2014, 12:38 PM
#45 (permalink)
Cyborg ECU
ABA testing?
Originally Posted by t vago
Result's from yesterday's trip ...
Any chance for ABA testing? Maybe a coast down test? I'd hate for all the other variables like wind and temp and subtle throttling differences to create the bummer effect for you. The project is so good. A coast down test wouldn't consume a lot of fuel either.
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
07-29-2014, 12:44 PM
#46 (permalink)
Another query: are you going to try tuft testing?
07-29-2014, 06:11 PM
#47 (permalink)
66.3 mph
For all the driving,do we have a baseline mpg for this speed?
We'll need some similar trips with the 'naked' truck to questimate the new performance.
From the old 1963 GM Labs relationship we'd figure about a 5.5% mpg increase per 10% drag reduction in this speed range.
07-30-2014, 11:55 AM
#48 (permalink)
MPGuino Supporter
I have to find some relatively flat section of road around here. Luckily, this area does have some decently flat roads (near Amana, IA). Hopefully, I can do a few coastdown runs this upcoming weekend.
Yah, at some point, I want to film a tuft test session. I am also interested in what the airflow patterns look like.
Unfortunately, no. Since I had the previous aerocap installed, the truck has gathered a good amount of mileage (needs a tuneup), the A/C compressor failed (possible extra parasitic drag), the P/S pump is dying (more possible extra parasitic drag), the EVAP purge switch failed (Check-Engine-Light lit), and my mother-in-law smacked the front left fender of the truck into a telephone pole (front aero changed).
However, this weekend should hopefully give me some good A/B data.
08-02-2014, 04:01 PM
#49 (permalink)
MPGuino Supporter
This is a link to a section of road, on which I intend to perform some coastdown tests. It is nice and flat, and not very busy.
Flat coastdown run - Iowa, IA
I will probably go ahead and hook up an MPGuino to the truck, once I find a nearby RadioShack to get the necessary interfacing components. I will then record the MPGuino output using my cellphone, and upload the videos to YouTube. Once done, I will crunch the numbers from reading the videos.
08-04-2014, 07:07 AM
#50 (permalink)
. . . I will then record the MPGuino output using my cellphone, and upload the videos to YouTube. Once done, I will crunch the numbers from reading the videos.
Sounds like a need-based opportunity to add MPGuino functionality!
