Old 09-15-2016, 06:59 PM   #41 (permalink)
MPGeo's Avatar
MPGeo - '93 Geo Metro Base
90 day: 67.51 mpg (US)
Going back to the degrees of advance info... I tried to purchase a custom sprocket from 3T but they haven't responded to my two emails...
So, for all of you out there who want to advance your cam for free here's the how to...
My factory cam gear has 40 teeth...
360 degrees divided by 40 teeth = 9degrees per tooth
So with ALL timing markings in the correct locations, I've made a new marking 1 tooth offset towards the direction of rotation (advance). This is now my "NEW" timing mark for the cam sprocket only, crank remains in TDC position.
Then I removed the belt and aligned cam sprocket with the "NEW" timing position for an effective cam advance of +/- 9 degrees... for FREE
IF ANYONE HAS ANY VALID REASONS WHY THIS IS INCORRECT... SPEAK NOW OR FOREVER HOLD YOUR PEACE
Old 09-15-2016, 07:19 PM   #42 (permalink)
Stock MPG 22city/32 hwy
06Aveo43061's Avatar
man, you've put a lot of effort into this car. I applaud your modifications and work
The Following User Says Thank You to 06Aveo43061 For This Useful Post:
MPGeo (09-16-2016)
Old 09-15-2016, 10:16 PM   #43 (permalink)
iveyjh's Avatar
none - '98 Honda Civic HX
none - '00 Chevy (Geo) Metro base
none - '00 Saturn SL1 base
Cam degree per tooth is 9 degrees but you have to consider that the crankshaft goes around twice for every one rotation of the cam shaft which translates to 18 crank degrees instead of 9 and advance/retard is based on crank degrees. Hope that helps.
The Following 2 Users Say Thank You to iveyjh For This Useful Post:
me and my metro (09-15-2016), MPGeo (09-16-2016)
Old 09-15-2016, 11:33 PM   #44 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
We have beat this to death over on the geo metro sites.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
The Following User Says Thank You to me and my metro For This Useful Post:
MPGeo (09-16-2016)
Old 09-16-2016, 12:35 AM   #45 (permalink)
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
Yep, and 18 degrees is a metric shizload of change. I would be careful about valves and pistons getting intimate in unintended ways. Have you checked the clearnace?
Simon
The Following User Says Thank You to LittleBlackDuck For This Useful Post:
MPGeo (09-16-2016)
Old 09-16-2016, 02:10 PM   #46 (permalink)
chips geo - '91 Geo Metro
90 day: 47.77 mpg (US)
welcome aboad
welcome aboard
Originally Posted by MPGeo View Post
Hello Everyone... New subscriber to the site, but have been following the site for a few years now.
But I have re-started my 93 Geo Metro project and wanted to share.
I drive 120 miles round trip to work everyday, and for obvious reasons a good fuel efficient vehicle helps.
I had owned a 91 Metro Convertible earlier in life, and I knew a bit about them then... so when I ran across my metro in 2011 I knew I had to make it into a reliable mode of transportation. I purchased the car for $200, not running but body was in excellent shape. It has factory 12's and was automatic.
Some tome in 2012 I purchased a second parts car metro with a non working engine and missing body panels and engine components and no wheels... But it had what I was looking full manual transmission setup... Bought that 2nd car also for $200.
So I have already performed the manual tranny swap back in 2012, and fixed the engine issues, and had it on the road for about 3wks and was loving it... but it started loosing compression in cyl #3... and loosing 1/3 of your power output on a Geo is not fun... So I parked the car, pulled the engine with intentions of completely rebuilding engine and transmission...and life has happened but I have been hanging on to both of my Geos for the last 5yrs against my wife's advice... Knowing that one day...
So the day arrived... last week I brought the car in my garage and it is currently undergoing massive heart surgery, but plan to have it on the road in the next two weeks.
My ULTIMATE goal with this project is to use it as a test bed and take all the lessons learned and apply them to an ELIO to get at least 120mpg.. so I can drive back and forth to work for 1gl us a day...
But in the mean time I have challenged myself to reach a 100MPG goal with this project... So, much work will be required but, it will be fun
The Following User Says Thank You to geo1991 For This Useful Post:
MPGeo (09-16-2016)
Old 09-16-2016, 06:32 PM   #47 (permalink)
MPGeo's Avatar
THANKS EVERYONE!!! Complete brain-fart on my part...
I knew it was 2:1 ratio, but complettly forgott (obviously) to think throuhg how that relationship would affect the event timing... That's what happens when you start improvising@ 2am...
I tried.... Now to figure how to accurately meassure 5degrees and drill/slot a new hole
Old 09-16-2016, 09:11 PM   #48 (permalink)
Pretty easy. Buy a degree wheel, bolt it onto the crank and follow any number of videos on how to degree a cam. Measure what the stock one's timing is then slot and play from there. A cheap way is to search google images for a degree wheel, print, glue onto a bit of tin or card and play...
You can also buy offset dowels and bushings - once you know the amounts talk to your local hotrod engine builder.
Simon
MPGeo (09-17-2016)
Old 09-17-2016, 05:04 AM   #49 (permalink)
MPGeo's Avatar
Simon
Thanks, I already own a motorcycle engine degree wheel so that's a plus... I will have to look into the offset dowels and bushings before I start improvising some more... Thanks
Old 09-17-2016, 09:48 AM   #50 (permalink)
I purchased a economy grind cam and a +10 from 3tech many years ago. I was very happy with the cam and gear, it did exactly as advertised. My car gave the best fuel economy with this setup. It is the best way to replicate an Xfi cam.
Mike has a full time job so he can be slow to respond to e-mail.
