11-20-2013, 01:47 PM
#311 (permalink)
Lots of Questions
Lookin' good! It's really starting to come together into a finished product. I really like how the cap opens up like a trunck to give you more access.
Don't forget to like our Facebook page!
Best EM Quotes:
Originally Posted by aerohead
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
The Following User Says Thank You to jeff88 For This Useful Post:
11-22-2013, 03:02 PM
#312 (permalink)
T-100 Road Warrior
Well...I'm committed to the new setup now. Removed all the remaining Coroplast from the aero cap.
With this cold front and rain, it's been rather fun to git the framing done...but it's done fer the most part.
I just have to size up the Foamular sides and hatch piece before I apply some 3M 77 spray to adhere the CommercialWrap Tyvek to it. The low temps will not be my friend when that happens. I'll be bolting the Foamular to the frame along with some washers or metal strips to make sure the Foamular won't git ripped off the frame.
Progress piccies so far...
New hatch frame...
Gas struts in place...
A quick overlay of the Foamular on the hatch...
I picked up some new J channels just in case I need to install them to keep the water from leaking into the bed from the hatch. I'll be installing some weather seal on the contact side of the aluminum angle in a bid to prevent water leakage.
This hatch setup is about 75% lighter than the wood framed Coroplast version. I'm guessing this version gonna weigh in around 25lbs.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 5 Users Say Thank You to BamZipPow For This Useful Post:
11-22-2013, 08:34 PM
#313 (permalink)
Lots of Questions
I was going to ask how much this weighs, because all that tubing and wood looks heavy, but 25lbs. doesn't seem like much at all, especially compared to the aero benefit you're going to gain. Lookin' sharp!
Best EM Quotes:
The Following 2 Users Say Thank You to jeff88 For This Useful Post:
11-23-2013, 02:56 PM
#314 (permalink)
T-100 Road Warrior
The Following 3 Users Say Thank You to BamZipPow For This Useful Post:
11-23-2013, 07:20 PM
#315 (permalink)
T-100 Road Warrior
...and the hatch lights are operational again!
Since it's too cold to apply the adhesive spray, I'll have to travel with the pink showing or I could try to paint it flat black and see how well the paint would take in this cold weather.
The Following User Says Thank You to BamZipPow For This Useful Post:
11-24-2013, 01:18 AM
#316 (permalink)
B.O. Zen
Pickup - '99 Toyota Tacoma 2wd, Regular Cab, Short Bed 90 day: 34.62 mpg (US)
I love how accessible your setup makes the back of the truck... If I were to re-create my setup, I'd definitely consider a configuration like you've engineered. Lookin' good.
The Following 2 Users Say Thank You to a8ksh4 For This Useful Post:
11-24-2013, 04:35 PM
#317 (permalink)
T-100 Road Warrior
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
11-25-2013, 02:19 AM
#318 (permalink)
B.O. Zen
BZP, you should make your way to CA some time and I'll help you weld up a bed extension to match your shell.
11-25-2013, 02:23 AM
#319 (permalink)
T-100 Road Warrior
Thanks! Don't fergit that I have a boat tail project based on a single wheel trailer...
http://ecomodder.com/forum/showthrea...ler-26997.html
11-26-2013, 02:47 PM
#320 (permalink)
T-100 Road Warrior
Christmas wrapped the hatch panel with Tyvek.
Stuffed some scrap Foamular between the inner liner and the hatch panel so I could match the profile of the cab. Used some washers with my pan screws so they would have more holding power on the hatch panel. It will also make it easier to remove when the time comes.
Piccies!
Sandwich...
Close transition from the cab to aero cap...
No pink on this trip!
The Following 4 Users Say Thank You to BamZipPow For This Useful Post:
