07-30-2008, 11:29 AM
#371 (permalink)
PaulH
switching direction
Want to know something funny? You changed yours to how mine started. Mine spun the wheels backward while in first gear, and I got panicked. So, I changed my wiring to how yours started, and it spun the right way. Can we officially add VW aircooled engines to the weirdo list like Honda???
07-30-2008, 11:44 AM
#372 (permalink)
EV test pilot
I think it's how the motors were designed, not the car transmissions that was the problem.
On my Metro - if I spin the tranny input shaft clockwise that makes the shaft move clockwise towards the front of the car. To match that, the motor's shaft needs to go counter-clockwise as viewed from the driveshaft end.
I don't think there is a default on the external wiring of a four-power-post series wound electric motor to indicate which direction it spins.
Do you have to spin the VW tranny shaft clockwise or counter clockwise to make the wheels go "forward" in a forward gear?
07-30-2008, 12:55 PM
#373 (permalink)
EV test pilot
Video of motor spinning the right way.
07-30-2008, 12:56 PM
#374 (permalink)
PaulH
If you are looking into the bell housing, spinning the shaft clockwise in 1st gear makes the car go forward.
07-30-2008, 01:03 PM
#375 (permalink)
EV test pilot
Yep, your transmission is "normal" then. It's definately that the motor can just be wound in different ways to make them spin clockwise or counterclockwise.
Good thing for those extra two posts! I wouldn't be real happy with my car having 5 reverse gears and only one forward!
07-31-2008, 12:24 AM
#376 (permalink)
EV test pilot
7-28-2008 Electro Metro Video Update
07-31-2008, 10:14 AM
#377 (permalink)
I like the last shot of the armature free spinning on the transaxle. Don't knock it over!
07-31-2008, 11:10 AM
#378 (permalink)
EV OR DIESEL
As a side note on the VW transaxle; you can swap the diff around to reverse the drive direction. Very common mod on Mid Engine Sand Rails + Kit cars using VW TransAxles.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
07-31-2008, 11:19 AM
#379 (permalink)
EV test pilot
So if you were doing a VW to electric conversion and had a motor that ran the wrong way, you could just flip the differential!
Cool.
07-31-2008, 07:40 PM
#380 (permalink)
EV test pilot
Controller!
Just got my controller in the mail!
8.8 lbs. of 72 Volt Fury!!!
(Curtis 1209B)
