Old 07-26-2008, 10:59 AM   #351 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Where are the backup light controls!!!
What runs the backup lights on this vehicle?
I put a battery in the car to run the electrical system. I can't get the backup lights to come on though.
Anyone know where the switch is that activates the backup lights?
On the transmission, there is one electrical connection. Is that it? I didn't label anything on the wire harness when I was taking out the engine, because all those wires went to weird little engine bits I didn't even know what they were.
There must be three or four female connectors on the wire harness that are all the same size and shape as the connection on the tranny.
Even if I can plug in the right wire to test it, I am not sure how to shift into reverse with the transmission out of the car!!!
I might just have to wait until the motor and tranny are in, but I am trying to do what ever I can when I have the time for it and am not waiting for parts, etc!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 07-26-2008, 11:25 AM   #352 (permalink)
90 day: 51.82 mpg (US)
That's the electrical connection you're after, on top of the transmission. The 12v ignition has to be ON for the lights to work (you probably knew that).
Old 07-26-2008, 11:39 AM   #353 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Hmmm - I found a connector on the wire harness that fits, but without the stick attached, I can only shift into 3 of the 6 (5 + reverse) gears!
None of the three activated the backup lights.
Will have to play with more of this later.
My YouTube Videos
Old 07-26-2008, 06:17 PM   #354 (permalink)
You should still be able to shift into all gears - but it sounds like you have to get under the car and move the shift linkage to get it into reverse. Twist the rod fully clockwise and push it into the tranny to get reverse (assuming you can find neutral to start!).
Old 07-27-2008, 12:32 PM   #355 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Rust!!!
I got the Front Driver side wheel off and finally really poked around in there. After knocking off some peeling paint. I poked at the control arm mount an went through on TWO sides on the bottom of it!
Looks like I need to do some re-inforcement welding on this! Too bad I don't have either the skill, or an actual welder!
Any SE Wisconsin Ecomodders want to lend a hand with this?
My YouTube Videos
Old 07-27-2008, 02:36 PM   #356 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
Did I mention I ordered a controller?
I ordered a 72V 400 amp Curtis controller from that guy on Ebay who has the pile of them.
Will let you know more when it shows up!
My YouTube Videos
Old 07-27-2008, 04:34 PM   #357 (permalink)
PaulH
MPaulHolmes's Avatar
Don't you just hate that?! I was feeling how firm the 18" x 40" area (or so) was behind the back seat, and the whole thing fell out on the ground! Here I was thinking it could hold batteries, and it would have caved in if I tried to store more than 1 AA cell back there.
Hmm, Harbor Freight has MIG welders for like $99 sometimes. That might be good.
Nice choice on the controller
kits and boards
Old 07-27-2008, 05:56 PM   #358 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
It's good to have small successes on a project like this.
While I am not excited to have to deal that the rusted holes on that support, I WAS able to figure out the backup lights!
I put a jumper through the end connector that I thought it was, and the backup lights came right on.
Then I set the transmission on the ground, as close to the car as I could, and plugged in the cable.
The tranmission is tricky to get into certain grears, especially when it's not in the car, with no stick shift attatched. Add to that how you have to visualize what actually happens when you shift into gear.
Based on that, I was able to get the gear selector rod on the transmission into the middle position, then twisted and pushed into reverse.
Sure enough, backup lights come on. I tested it going into and out of gears a few times. Works great.
Labeled the wire with masking tape and a note.
Back to working on something else now....
My YouTube Videos
Old 07-28-2008, 04:36 AM   #359 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I just finished repairing my frame that looked identical to the rot you are showing. I will have pics up on my "Metro Thread" in about 4-5 hours. I am not a great welder, but was very happy with the outcome!
I highly suggest fixing that before you go any further.
GeoMetroforum.com - got mpg?
Old 07-28-2008, 07:13 AM   #360 (permalink)
Future EV Owner
Wannabe - '05 Honda Civic LX
90 day: 40.53 mpg (US)
Originally Posted by bennelson View Post
Rust!
Say it with pride, Ben. After all, it's our state mineral.
electric car, electro metro, geo, metro
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 36 02-11-2015 11:08 AM
Daox's 1997 Paseo Build Thread Daox EcoModding Central 241 11-12-2013 11:23 PM
DPoV's Jeepin' Build Thread DifferentPointofView EcoModding Central 26 12-16-2009 04:31 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Margo II: the build (project thread) AndrewJ Alternative Transportation 26 04-23-2008 01:23 PM
