The MG, Bonneville streamliners, the .143 Sunraycer, etc all taken together show that there is something about them that is dramatically different than a Malibu -- it takes more than tapering the back to make a really low Cd. Quote:
As of 2010, the .143 number for the Sunraycer still stood as the lowest recorded at GM. Quote:
The Following User Says Thank You to Ken Fry For This Useful Post: | COcyclist ![]() |
#24 (permalink) |
Aero Wannabe
Ken, did you test the Citroen with a full boat tail? Was there a difference in mpg with or without?
60 mpg hwy highest, 50+mpg lifetime TDi=fast frugal fun ![]() https://ecomodder.com/forum/showthre...tml#post621801 ![]() |
#25 (permalink) | |
It's interesting, but when you think about it, the tail of the vehicle does not matter one hoot without attached air at the front.... This is important, so I will say it again in a different way. On a properly designed vehicle, the tail "will" give the greatest benefit aerodynamically, but not without a properly designed front. Sounds simple and somewhat trite, but very true non-the-less. So when it comes time to start aero improvements to a vehicle, the best place to start is at the front.... The tail will come, in it's own time! Jim.
Under-Belly Panels: http://ecomodder.com/forum/showthrea...els-10638.html Tail Extension: http://ecomodder.com/forum/showthrea...ect-13533.html |
The Following 2 Users Say Thank You to 3-Wheeler For This Useful Post: | jime57 (01-16-2012), landsailor (01-12-2012) |
#26 (permalink) | |
A Legend in his Own Mind
At the time (late 1970's) this was a pretty casual experiment. I didn't have access to really accurate fuel flow equipment, so used two 50 mile runs, filled at the same pump location at the same station, etc. and didn't observe any difference. At the time, I was half expecting to see a slight increase in drag from the tail, being, at the time, a half believer in the Kamm effect, but also thought that the flow was well enough attached (at least to the rear window to benefit from a boat tail. There is a little bump at the center of the trunk lid that I faired in crudely. Perhaps removing the bump (not something I would do for a test, of course) would have helped. Far to many variables at play to say what its real effect might have been. I picked a pretty still day, but could have had a slight tailwind on one trial and a slight headwind on the other. (Although both trials were out and back, but on a widely divided highway.) I think there was very little effect on this car that was already pretty clean and close to being boat-tailed... But I don't have a scientific leg to stand on. |
#27 (permalink) |
Aero Wannabe
Cool car Ken!
File:Citroen SM in Stockholm rear.jpg - Wikipedia, the free encyclopedia I do admit thinking they were a little odd looking back in the day. Now, thanks to Ecomodder, I understand what they were doing with that design.
60 mpg hwy highest, 50+mpg lifetime TDi=fast frugal fun ![]() https://ecomodder.com/forum/showthre...tml#post621801 ![]() Last edited by COcyclist; 01-12-2012 at 01:20 PM.. |
#28 (permalink) |
I have always admired them and thought them attractive for the form which follows function. But then again, I think the Gen 1 Insight is one of the prettiest cars ever built ;-)
#29 (permalink) | |
Aerodynamics A glutton for punishment, I had the SM and a DS21 at the same time. Both were fun to drive and own. Almost everything was different than in other cars. The SM had self-centering steering with just two turns lock to lock. The assist would vary with road speed, a new idea at the time. The self- centering worked even at a standstill, so you could crank the wheel over to full lock, release the wheel, and it would center itself. The ride height could be set anywhere from about 4" clearance to 12" clearance ( and it self-levelled to adjust for any load). The extremes were used for jacking the car: you raised it all the way, put a special jack stand on a boss on the chassis, and then lowered the car all the way, and the support-side wheel would be off the ground (lifted by the antisway bar). I used to lower the car when I parked. Then I'd come out, and if there were people around, I'd get in, start the car, set the ride height back to normal, and then get out. The back, being lighter always came up first. So I'd walk around to the back and pretend to lift that end. I'd have enough time to then walk to the front and pretend to lift that end. Got some great looks! The brakes were operated by a servo valve instead of a master cylinder. (Brakes, steering and suspension were all operated by the central hydraulic system.) There was a mushroom-shaped button on the floor that moved a total of about 1/4 - 1/2 inch. This had a feedback loop that pressed the button toward your foot according to brake pressure. Worked very well but took a few stops to get used to the quite powerful brakes -- which recorded shorter stopping distances than all other cars of the time in some tests. It was fun to have friends drive the car: most would weave all over the road, over-correcting steering, and many would come to a few quite abrupt stops. Then there was the great looking four cam Maserati engine, which performed pretty well and didn't catch on fire with every start... just a few. Three dual throat Webers were used with velocity stacks hidden by the aircleaner plenum. No chokes, just mixture enrichers -- which I think may have been manually operated. Lot's of overlap and low velocity through big throats lead to some spitting back and an occasional backfire. But what's an Italian engine without some drama? Mine had US headlights: just 4 ordinary fixed-mount sealed beams. You could not have covers over headlights back then in the US. The European lights were covered, so the whole front of the car was glass. There were 6 lights and the middle two steered and self-levelled, so that under hard braking, you could still see out ahead. |
#30 (permalink) | |
Apology to NUNA folks
The MG, Bonneville streamliners, the .143 Sunraycer, etc all taken together show that there is something about them that is dramatically different than a Malibu -- it takes more than tapering the back to make a really low Cd. I think you meant to say, perhaps, that sub .12 Cd's can result from wheel streamlining if everything else has been optimized. The MG's wheels are already quite well streamlined, and the body is extremely well streamlined, front and rear, but still it is not sub .12. The Aptera had well streamlined wheels but is a long way from sub .12. The VLC has well-streamlined wheels but is also a long way from .12 As of 2010, the .143 number for the Sunraycer still stood as the lowest recorded at GM. This makes it sound as if one merely puts a boat tail on a car according to the template, and a Cd of .12 results. I imagine that's not what you intended. My old Citroen SM was a reasonably good fit for the template, but gained very little from extending the rear into a full boat tail, vs the existing Kamm back. Its Cd was around .30 either way. |
