Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 01-06-2025, 04:35 PM   #211 (permalink)
We're 210 post in. I checked your Profile, twenty-one posts since you cared about Anthropogenic Climate Shenanigans. Are we all still doomed, anyway?
You never commented on the Photomolecular Effect
Old 01-07-2025, 07:30 AM   #212 (permalink)
These links are currently for my own edification and so I don't lose the links.
They have little to do with BA in engine oil at this point of study.
This is of interest (to me alone it would seem) as a means of understanding what happened upon adding BA (aq) to the engines I treated.
https://sci-hub.ru/https://pubmed.nc....gov/29505262/
Liquid Superlubricity of Polyethylene Glycol Aqueous Solution Achieved with Boric Acid Additive
The mixture of pure PEG200 and boric acid
was prepared by dissolving 4 mM of boric acid in 25 mM of PEG200 without pure water and
denoted as B-PEG200
Notably, the COF of H3BO3(aq) decreased from 0.5 to 0.03 after a running-in period of
approximately 800 s, indicating boric acid could greatly reduce the friction of pure water...
the superlubricity state was dominated by both the composite
tribochemical film formed via the tribochemical reaction on the contact surfaces and the
hydrodynamic lubricating film between the contact surface
a higher viscosity can result in a higher COF. Therefore, it is concluded
that the initial viscosity of the solution can influence both the running-in and superlubricity
periods...
superlow friction is closely related to the
concentration of residual water on the surface, and there is a critical concentration of residual
water for superlow friction...
the friction behavior of PEG200(aq) in the absence of boric acid
was also tested...After a running-in period of 1500 s, its COF
decreased to approximately 0.02... attributed to the presence of water, which leads to
the formation of an ultra-smooth surface after the running-in period...beneficial for
the hydrodynamic lubrication
... B-PEG200(aq)
could achieve superlubricity (μ<0.01). Its COF gradually decreased to less than 0.01, entered
the superlubricity state after a running-in of period 600 s, and thereafter decreased for a
further 300 s to reach the minimum value of 0.004...its specificity originates from the presence of BO3-
...It can be concluded from these results that there is an appropriate sliding speed range (0.05–0.25 m/s) to achieve superlubricity by B-PEG200(aq).
boric acid can react with polyols [in oil] such as glycerol and PEG
to form a boron chelate complex (BCC).36,37 Herein, during the running-in period, the rubbing
motion between asperities inputs energy into the lubricant and accelerates this chemical
reaction between PEG (marked as HOROH, R stands for alkyl chain) and boric acid
after short running-in period
results confirm that there is a tribofilm
deposited on the worn surface after the running-in period of superlubricity, which is believed
to contribute to the relatively low friction
residual water concentration
after the running-in period on the worn surface remains constant, which dominates the
solution viscosity; therefore, it is concluded that the hydrodynamic lubricating films are also
important for superlubricity
At the contact region of solid asperities, BCC is produced by the synergy
effect between boric acid and PEG200, and meanwhile provides sufficient H+ ions to realize
the running-in process, which contributes to the surface smoothening and contact pressure
reduction.
colloidal silica [in both Alu and steel alloys], which is a
good boundary lubricant, with electric double layer may be formed.33,34 And since the
superlubricity is achieved in neutral conditions (pH≈6), in which the colloidal silica system
can maintain stable, thus the sufficient electrostatic support can provide repulsive force to
increase the surface separation and avoid some direct contact
the existence of water makes it possible to form hydrated PEG
network, which might be cross-linked by hydrogen-bonding interactions mediated by boric
acid and ordered due to shear (like shear-thinning of branched polymer solutions). Thus, the
viscosity and shearing force of such solution are very low, leading to superlow friction
Decrease Friction with Hydrogen Ions
...reduction of friction by attachment of hydrogen ions to the rubbing surfaces. An ultra-low friction coefficient of \mu=0.004 was achieved between SiO_2 and Si_3N_4 in presence of ethylene glycol. Generation of ultra-low shear strength hydration layer \mu_r=0.0002 was claimed to be responsible for superlubricity regime.
During the running-in, the surfaces absorb hydrogen ions by means of tribochemical reaction induced by normal and shear pressures. The resultant hydrated layer is low-shear strength, but also delicate. It cannot carry much of the load and therefore, the researchers used a low-viscous lubricant to separate the surfaces by a thin film. This film protects the hydrogen layer from being worn, whereas hydrogen layer accommodates the difference in the wall velocity by its low shear strength and the resultant friction becomes low.
The researchers showed, that the proposed mechanism is applicable for any surfaces capable of absorbing hydrogen and aqueous lubricants with low viscosity
https://www.tribonet.org/news/decrea...hydrogen-ions/
Old 01-08-2025, 12:57 PM   #213 (permalink)
' appropriate sliding speed range for superlubricity '
denoted as B-PEG200
periods...
... B-PEG200(aq)
reduction.
1) I attempted to bring this to your attention, although you're not reading my posts ( notice in your source that their maximum surface velocity is 0.25 m/s, whereas in an automobile engine typical piston-to-cylinder speeds are 25 m/s, 100X 'faster' [ Dr. Erdemir's pin-on-disc test was at 0.18 m/s, even more out of range to 'automotive reality ' ).
2) Secondly, 'lubricity', and 'coefficients of friction' are not what engine designers use as a criteria during engine design ( there exists no clear comparison between 'viscosity' and ' coefficient of friction [ Red Line oil provides us with some data for this ] ).
3) They do every thing in their power to design an engine which will never make an excursion into a load region in which 'lubricity' matters.( AMSOIL makes this distinction in their literature, MotorSilk appears to be telling a lie about their 'solid boundary layer-boric oxide', getting confused with the 'hard' version of Boron Nitride ( which cannot exist inside an engine ).
Old 01-08-2025, 01:40 PM   #214 (permalink)
' Argonne's testing '
1) Dr. Erdemir never tested boric acid in 'motor oil'.
2) Erdemir, Fenske, and Erck primarily tested only with motor oil 'bases', containing nothing but 100% mineral oil, or 100% synthetic polyalphaolefin, never a commercially-available motor oil as we purchase, all of which contain complete additive packages.
3) One research you listed involved base oil with a rust inhibitor and one other additive that I can't recall.
4) Dr. Erdemir cautioned, ' Use only lubricants which are chemically unreactive with boric acid.' ( I found no research from Argonne in which all available commercial motor oils were ever tested for this ' unreactive' nature. Dr. Erdemir said that boric acid would require about two more years of 'batteries of tests' before its environmental and safety aspects were ascertained ).
5) The Nuclear Regulatory Commission found that boric acid was responsible for shutting down two nuclear reactors because of corrosion to low-alloy and carbon steels ( reactive chemistry ).
6) And we have Chevron's research which revealed that boric acid had the capacity to damage gears and bearings ( reactive chemistry ).
7) Presently, according to the US National Bureau of Standards, Flouramics' 'Tufoil' is 'The World's Most Efficient Lubricant', and a Canadian laboratory found that under 'extreme cold weather' Tufoil can produce up to 5% higher fuel economy.
Old 01-08-2025, 02:12 PM   #215 (permalink)
I'm glad I decided to skip to the last paragraph. Something actionable at last.
Originally Posted by DDG
fluoramics.com
Tufoil Engine Treatment makes your ordinary oil TUFOil! - Fluoramics
Tufoil Engine Treatment Guinness World Book of Records "The World's Most Efficient Lubricant." Engine oil additive help in creating improved engine efficiency
Tufoil for Engines
Guinness World Book of Record's "The World's Most Efficient Lubricant." Tufoil Engine Treatment reduces friction, sludge, corrosion, and excessive oil burning.
Tufoil Technology
Tufoil has a pure synthetic base of the highest quality possible. The magic in...
Old 01-09-2025, 05:39 AM   #216 (permalink)
Ah yes; PTFE
I have never got into the science here. IIRC there where issues..?
BA forms that hard, chemically inert, self fixing, oxide layer that none of the other solid lubricants do.
So lets say you have this BO layer on your engine and 2 high points somewhere touch causing the oxide to be shorn off:
The oxide particle/s reacts with water in the oil forming BA again and the BA, with no metal surfaces left to react with, reacts with that same bare spot (sans high point) again.
Judging by the look of the oil alone: The BO layer formed really does stop corrosion.
The oil just refuses to go that dark, old colour.
In my experiments this worried me in that: "We are at 20 000km (IIRC) since the last oil change! I don't care how good the oil looks; now I'm changing it!'
Old 01-09-2025, 10:31 AM   #217 (permalink)
TRIBOLOGICAL PROPERTIES OF BORIC ACID AND BORIC-ACID FORMING SURFACES: PART II:
FORMATION AND SELF-LUBRICATION MECHANISMS OF BORIC ACID FILMS ON BORON- AND BORIC-OXIDE-CONTAINING SURFACES
A. Erdemir, G.R. Fenske, R.A. Erck, F.A. Nichols, and D. Busch
Tribology Section
Materials and Components Technology Division
Argonne National Laboratory
Argonne IL 60439
...This paper introduces a solid lubricant film that can spontaneously
form on surfaces including a boron or boric oxide (B 203 ) coating.
The naturally occurring reaction film is boric acid, H3BO3...
https://www.osti.gov/servlets/purl/7257960
Old 01-10-2025, 05:05 PM   #218 (permalink)
Actionable..??
Old 01-11-2025, 05:21 AM   #219 (permalink)
I looked it up.
Haven't read Erdemir et al.
Old 01-11-2025, 01:25 PM   #220 (permalink)
' boric oxide solid lubricant film '
Tribology Section
Argonne IL 60439
I suspect that Toyota and the other manufacturers had secretly hidden the radio frequency- magnetron ( microwave radiation ) sputtering transmitters and crankcase vacuum-isolation devices inside the engines, in order to create the boron oxide plating that the nanometer boric acid platelets would eventually slide over.
Additionally, these secret engines also had the classified unobtainium cooling systems of which, even while the cars were pulling heavy trailers up mountain grades, at Furnace Creek, Death Valley, California, in peak Summer temperatures ( 122-F ), or ( negative - 50-F ) in Gunnison, Colorado, always had the capability to keep engine coolant and oil temperatures at 'room temperature.' Truly amazing !
Local car dealers have told me that these options were only available at Papoose Lake, Nevada, and only at the pleasure of the base commander.
