Old 02-26-2008, 04:21 PM   #1 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Car and Driver magazine ecomods a Pinto: MPG up +25%
The catch is that the car in question was a Pinto runabout, and the project took place 34 years ago "to ease the fuel shortage" of that era.
Nevertheless, most of their mods still apply today.
All we did was apply some race car technology to a street car. The result: a 25% increase in gas mileage from $10 worth of sheet aluminum, $1 worth of plexigass and a set of radial-ply tires. Gentlemen, man your tin snips.
Everything old is new again...
The Pinto came to my attention in a post Phil made in the "How to decide whether to remove a rear spoiler" thread. He mentioned the C&D article in that context about the "Crisis Fighter Pinto" because it had a sheet metal spoiler added on as part of its list of mods.
Phil must have also mentioned the article to the Edmunds.com writer who did the piece about ecomodding this week.
Here's what Car and Driver did:
- "LRR" (radial) tires replaced the OEM bias ply ones
- massive front air dam (2 inches clearance)
- partial grille block
- plexiglass headlight bucket covers
- 6 inch rear spoiler
- removed 2 blades from the OEM 4 blade radiator fan
End results: 18.2 mpg (US) in modded form, vs. 14.6 mpg in stock form, tested @ 70 mph.
Old 02-26-2008, 06:35 PM   #2 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
It is amazing what ratty MPG those old Pintos and Vegas got. My old Cosworth Vega got 24 MPG and I thought that was great. Now my truck does as well...in the winter. Of course, back then I drove like a crazed twentysomething.
Wish I had that car back but I don't think I could squeeze in anymore.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 02-26-2008, 07:12 PM   #3 (permalink)
H4MM3R's Avatar
Nice find. Thanks for sharing it.
Old 02-26-2008, 07:16 PM   #4 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Toyota Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 Trek 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Honda Civic DX
90 day: 33.29 mpg (US)
Very nice, I like seeing the "pros" do something with ecomodding every once and a while. Helps me gauge whether the stuff I do, or think about doing is really all that effective and if my findings of my efficiency gains were accurate.
Old 02-26-2008, 07:21 PM   #5 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Fan Mod
Too bad the fan mod won't make that big of a difference today: mechanical clutch vs. electric.
The Pinto/Maverick could have been so much more, but alas, Amerikanized.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 02-26-2008, 07:39 PM   #6 (permalink)
Woooo, I remember a pinto mod article in Popular Mechanics I believe, base line was 24mpg, and finish was 44. I know I have the article up stairs in among a box of magazines.
I recall an open air cleaner, header , carb rejet kit, header and several other things. If anyone is interested I will see if I can dig it out.
Old 02-26-2008, 07:52 PM   #7 (permalink)
oldschool -please do.
I suspect the main difference was that the C&D project intentionally avoided mods that would have interfered with emissions. We can all make our cars more efficient if we want to raise NOX, for example.
Old 02-26-2008, 08:19 PM   #8 (permalink)
Keep in mind, that's how the C&D people drive too!
The mileage quoted is @ 70 mph. At 55 it would be quite different.
Old 02-26-2008, 10:20 PM   #9 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
What we should do is make something that effectively cleans out NOX, like on a diesel, when you run biodiesel. All other green house gases are lowered, except NOx... So if we could get a filter with that we could run more efficient and not worry about nox.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 02-26-2008, 10:45 PM   #10 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
I agree
I agree -- and have thought quite a bit about this.
We can make engines more efficient from a consumption standpoint, but emissions nevertheless increase. A catalytic converter and EGR setup are supposed to remove most of the NOx. Newer tech (although more expensive) could be implemented.
Too bad it's one or the other right now...
RH77
_
_
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
The 100 MPG Challenge Revisited smartzuuk Success Stories 1 09-01-2009 02:01 AM
News: Smart testing a 70 mpg diesel in the US in 2nd gen car MetroMPG General Efficiency Discussion 4 07-02-2009 11:51 AM
Car & Driver disses buying old economy cars to save fuel MetroMPG General Efficiency Discussion 89 10-09-2008 06:47 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 09:37 PM
