Old 11-18-2009, 03:33 AM   #11 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by born2pdl View Post
I was wondering about using velcro around the perimeter, and a screw at each bottom corner.
MetroMPG tried velcro and it turned out to hold too well. Read about it here.
Old 11-18-2009, 05:56 PM   #12 (permalink)
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
BEFORE:
AFTER: Home Depot cabinet hinge and some nuts/bolts.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
Old 11-18-2009, 07:40 PM   #13 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
jedi_sol -
Wow. It took me a while to figure out the pictures, but it is very cool, . I would use much shorter bolts to avoid risk of damage to tires, but I think you are just showing proof-of-concept, not the final cut.
I was thinking that a hinge "should" be from the top, but yours is better because you are creating the strongest attachment where the wind would be trying to get under the skirt and rip it off the most.
That makes me ask the next question, how will you make it so that the skirt is attacheable/removeable along the curving line above the hinge? The hinge will be strong, but there needs to be a way to "seal" the rest of the skirt above the hinge. I'm asking because I'm always paranoid that the wind will get under and try to rip your wheel skirt off (I hate wasting hard work).
CarloSW2
American Solar Energy Society
Old 11-18-2009, 10:04 PM   #14 (permalink)
Cycling more to drive les
White 'rolla - '05 Toyota Corolla LE
90 day: 44.39 mpg (US)
Send a message via AIM to Chalupa102
Silly question, but where did u get the brackets themselves that go across?
Corolla aeromods thread:
http://ecomodder.com/forum/showthrea...ead-11210.html
Old 11-19-2009, 12:44 AM   #15 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
Originally Posted by cfg83 View Post
jedi_sol -
CarloSW2
Like the OP mentioned, my whole concept is to make the skirt easily detacheable for when i need to rotate/replace tires. So i randomly saw these in the cabinet hardware section of home depot
Amerock Friction Catch, Popular Value - BP3471-2G at The Home Depot
Ill screw the left side in the tirewell and the right side on the wheel skirt, so it should make the top half of the wheel skirt have the ability to pop in/out. Then swing the whole assembly away, giving me access to the wheel.
As far as durability goes...only testing will tell.
Old 11-19-2009, 01:26 AM   #16 (permalink)
jedi_sol's Avatar
Subaru
Sports Cars
Team Turbocharged!
Crown Bolt 3/4 In. X 48 In., 1/8 In. Thick Flat Plate Aluminum - 44650 at The Home Depot
Then i used a vice grip and a hammer to bang it into my desired shape
The Following User Says Thank You to jedi_sol For This Useful Post:
Chalupa102 (11-19-2009)
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Front Wheel Skirts; 1950 Nash Ambassador Rokeby Aerodynamics 18 04-06-2014 12:14 PM
2000 Mazda Protege Rear Wheel skirts Walk Through Blue Bomber Man Aerodynamics 13 08-29-2009 02:12 AM
Wheel skirts slowing me down? wagonman76 Aerodynamics 11 07-20-2009 12:41 PM
Wheel skirts for the aerodynamically minded Daox Aerodynamics 14 01-27-2008 11:23 PM
