Old 05-30-2008, 10:05 PM   #11 (permalink)
Boxhead
whokilledthejams's Avatar
Boxy Brown - '04 Scion xB
90 day: 35.48 mpg (US)
Send a message via AIM to whokilledthejams
Originally Posted by SuperTrooper View Post
In the late '70s Tyrrell built and raced a Formula 1 car with 4 wheels in the front that all steered. The idea was to use smaller wheels for reduced wind resistance while maintaining the same size tire contact patch.
Only raced 2 seasons due to lack of tire development and the extra weight involved with 2 steering sets in the front of the car.
If I recall correctly, the other reason they stopped using that car was that it was pretty much impossible, with the engineering of the time, to get the steering geometry just right since it was so complex. I think if F1 wasn't run by people with their heads in various places that they shouldn't be, that basic concept could work better with current technology.
Ok, I'm done threadjacking
Old 05-30-2008, 10:47 PM   #12 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
Teacher, I have a question ?
Regarding the video above about the 8 wheeled car, I see that a major challenge was winding the copper around the motor. My question is; Why not melt the copper and mold it to a thickness around the piece? Would a solid piece of copper conduct better than hundreds of wound turns?
Just seemed like the obvious answer ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 05-31-2008, 12:51 AM   #13 (permalink)
Danger Ranger - '01 Ford Ranger Edge 4x4
90 day: 14.52 mpg (US)
Moms car - '05 Ford Freestyle Limited
90 day: 21.92 mpg (US)
Mistress - '10 Harley-Davidson 883 Sportster 883 Iron
90 day: 42.53 mpg (US)
Send a message via AIM to meemooer
^^ i'm pretty sure no it wouldn't. audio guys like the thickest gauge cables with the most wires inside because there is more surface area. and if one wire goes bad, the cable is still ok. And with r/c car motors, the lower the windings the the faster it can spin to max speed, and more windings is usually more torque
Randy
Old 05-31-2008, 10:44 AM   #14 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Maybe you are making the common mistake of thinking that is bare copper wire.
It's insulated wire (with a clear coating). If it wasn't, the windings would be
a dead short, and not generate a magnetic field. (Just heat).
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 05-31-2008, 02:23 PM   #15 (permalink)
Fortuga - '03 Subaru Forester X
90 day: 21.68 mpg (US)
The Beater - '94 Nissan Sentra EX
90 day: 28.88 mpg (US)
In answer to the question "why 8 wheels?": I think it may have to do with acceleration, deceleration, braking and handling of this beast by a common mortal. The mechanics/electricians who will have to perform the maintenance, though, must be higher beings for sure.
Old 05-31-2008, 06:56 PM   #16 (permalink)
- - '10 Toyota Prius III w/Navi
Hi All,
Does this car have friction brakes ? I do not remember seeing any. So the 8 of the 100 HP wheel motor/brakes probably are needed to get the braking power needed.
Also, this car has a pretty heavy battery load. Tires with sufficient load rating might be quite large, and have lots of air drag. Where the 8 tires fit under the lower body work.
Old 06-01-2008, 12:02 AM   #17 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
If you know the name of the car or inventor you'll be able to find the car on youtube.
Like I said, it's called the Eliica.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Honda Insight Wheels Ryland Hybrids 24 04-20-2011 12:45 PM
WTB: Set of 13" Wheels for Geo Metro SirKeats For Sale 9 06-03-2008 06:40 PM
Civic with noisy wheels Twerp Off-Topic Tech 9 05-30-2008 11:22 AM
Wheels - Large or Small Diameter? Width? CorollaMaster EcoModding Central 30 05-14-2008 09:33 AM
WTB: Honda Civic HX Wheels XFi For Sale 2 01-26-2008 07:02 PM
