Old 12-18-2009, 04:08 PM   #141 (permalink)
The Enginer kit says it works on first gens...
I agree about preheating as much as possible and emissions.
The Following User Says Thank You to Daox For This Useful Post:
orange4boy (12-19-2009)
Old 12-18-2009, 06:19 PM   #142 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Originally Posted by orange4boy View Post
Bob has done this hack and probably knows the emissions angle.
I don't have emissions data. I live in a state that has no emissions testing and those machines are expensive. The only way to really know is to have an emissions tester and run controlled tests. Sad to say, this leaves me with 'analysis' and that gets to be a little wordy. Regardless this shows the effect and my thoughts:
Experimentally I've found that spoofing the thermostat can occur at just about any coolant temperature BUT at or below 30C, the engine is likely to stall-out or run rough. Triggering the 70C spoof at 40C works without engine running problems.
STARTUP FUEL FLOW
The following chart shows injector timing during warm-up of our NHW11:
The first 30 to 45 seconds the engine is heating up the catalytic converter. Since this is the primary emissions treatment device, this must proceed. This seems to be the prime directive for manual starts but thereafter, there is a distinct drop in fuel consumption. If the car is in gear, there was another distinct drop at 145 seconds, which may simply correspond to finishing an initial charge on the traction battery. Regardless, the catalytic converter is already warmed up.
HYDROCARBON CAPTURE DEVICE
The first device in the exhaust system is a hydrocarbon (HC) capture device that engages when the car is manually started. It has linkages (that can corrode and lock up) that operates a valve to direct the exhaust stream through a path to capture the startup HCs. If the catalytic converter is known to be at operating temperature, the HC is not needed. But manual starts appear to activate the linkages for this device until the catalytic converter operation can be confirmed, an estimated 5-10 seconds.
It appears that when the linkage has the valve closed, the control laws keep the engine running but lets us draw traction battery power to move the car. By parking near the exit of my work parking lot so I can see the on coming traffic on the road, I've timed my startup and with gentle accelerator, successfully achieved 35-40 mph on traction battery while the engine remains at warm-up idle. Once I hear the engine speed up to take the load, I can, traffic permitting, shift into "N" and see MPGs of 35-45 MPG.
Holding off an spoofing the thermistor to 40C allows the normal HC operation to operate as designed.
SIMILARITY TO NHW20 WARM-UP
Ken@Japan shared this warm-up profile on his Japanese NHW20, 2004 Prius, which does not have a thermos, warm-up bottle:
This is my warm-up profile from the NHW11, 2003 Prius:
Our ZVW30, 2010 Prius, has a similar warm-up profile to the Ken's NHW20. This suggests that auto-stop and start during the engine warm-up does not adversely impact warm-up emissions. This is distinctly different from a manual stop and start that seems to invoke other engine start-up, control laws.
SPOOFING ICE STOP AND COOLANT TEMPERATURE
Up until about 50C, the NHW11 engine can be 'tricked' into auto-stop by holding the brake hard at a stop, shifting into "R", and pulsing the accelerator. This trick causes the engine to stop and shifting into "N" leaves it stopped ... say at a light. When ready to proceed, I shift into "D" and the engine auto-starts and I'm off. But while the engine is off, the coolant temperature continues to rise.
Within the first ~15 seconds, there is a 3-4C rise in coolant temperature. The heat from the cylinders and exhaust manifold continues to flow through the engine block and warm the coolant. After about a minute (takes a long light,) the temperature slowly begins to go down.
What this tells me is the lowest engine idle provides substantially more heat than what it takes to warm-up the engine (not counting Canadian and Yankee winter temperatures!) Having the engine auto-stop during warm-up AFTER the catalytic converter is warmed up appears to optimally warm-up the engine block and coolant.
CONCLUSION
The gold standard is to use an emissions tester during warm-up and measure the emissions. However, the warm-up control laws of the Japanese NHW20; some obscure auto-stop tricks in the NHW11; and supporting observations suggest a thermostat hack that triggers at 40C is likely to be OK.
Bob Wilson
ps. If anyone knows how I can get or rent a portable, emissions tester for a reasonable price, please let me know. I'm loath to market a thermistor hack without credible data showing it does not impact vehicle emissions.
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
The Following 2 Users Say Thank You to bwilson4web For This Useful Post:
Daox (12-21-2009), orange4boy (12-19-2009)
Old 12-18-2009, 11:18 PM   #143 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
I don't know a lot about emissions technology. I do know there are all sorts of issues around enrichment of a cold engine just for driveability. My Previa does not switch into overdrive until the coolant is up to operating temp. This is just so it does not "lug" under power in the high gear with low engine speed and a cold intake.
It's possible in the Prius that the "cold enrichment past converter warmup" is just a drivability compromise so that if you floor it it will not stumble and that it has nothing to do with emissions. In fact it's possible that the coolant temp hack even reduces emissions.
Logically that makes some sense as an overly rich mixture spews unburned HCs. The converter deals with that.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 12-19-2009, 01:38 PM   #144 (permalink)
orange4boy's Avatar
90 day: 57 mpg (US)
I will have to take a closer look then. Thx.
OOH! I can use that.
Two good tips. Excellent thread.
Old 12-21-2009, 08:30 AM   #145 (permalink)
Thanks for the info Bob! That puts my mind a bit more at ease about possibly using the coolant temp hack.
Old 12-21-2009, 09:02 AM   #146 (permalink)
Engineering first
Here is a quick hack I used to initially test it:
The forward bias of the diode 'offloads' the resistor at higher temperatures. This means over temperature conditions are still detected.
Bob Wilson
Old 12-24-2009, 11:17 AM   #147 (permalink)
I've started the PHEV conversion, but broke it off in another thread.
http://ecomodder.com/forum/showthrea...tml#post149778
Old 02-01-2010, 09:39 PM   #148 (permalink)
The PHEV is installed for those who haven't followed that decent sized thread. However, it has some major problems and needs some help in the battery management system department. So, I'm not getting a ton of use out of it yet. I am working with some guys on priuschat to fix this and we think we have a solution. More info in that thread though.
I am posting here to say that I took some time tonight to install a block heater in the Prius. I've had it for months now, I've just debated using it since the Prius has a coolant thermos that holds warm coolant when the car is powered down. This coolant thermos works nearly as well as the block heater did on my Matrix, so I didn't see a huge need for it. Also, if the engine coolant is warmer than the thermos coolant temps, it won't dump the thermos coolant into the engine on power up. So, a block heater wouldn't be very useful, right? After a bit more thinking, I came to the conclusion that it definitely will be useful, and used right it will work very well in combination with the coolant thermos. I just have to run the block heater for a short enough time to keep the coolant temperature under what the thermos temperature is. That way, the coolant thermos will still dump into the engine upon power up, and I get the benefit of both. So, I installed it tonight and set the timer to run approximately 2 hrs before I leave for work in the morning. We'll see how this works.
Here is the kit contents. Installation is a pain in the butt, but not really that hard.
So, I now have two extension cords going to the car. When I get the phev kit automatic disconnect setup, I'll likely work on getting the arduino to be an onboard timer to power up the block heater too. But, that is a project quite a bit down the road.
And, yes Darin, it is about time.
Old 02-02-2010, 10:19 AM   #149 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
The installation of the EBH will be one of the best upgrades that you could had made to the Prius for the winter season.
A few hours of electricity for the warm-up will help the ICE to reach "Stealth" mode in a jiffy.
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 02-02-2010, 10:23 AM   #150 (permalink)
Do you have any recommendations on length of preheat?
Daox's 2003 Matrix Build Thread Daox EcoModding Central 76 01-11-2016 01:47 PM
Daox's 1997 Paseo Build Thread Daox EcoModding Central 241 11-12-2013 11:23 PM
PBS takes the Hummer v Prius bait SVOboy Hybrids 51 05-19-2010 12:35 PM
Toyota Drops Prius Base Price to $21,000 to Compete with Honda Insight SVOboy EcoModder Blog Discussion 5 04-22-2009 12:50 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
